Playing TV shows on Panasonic Viera TX-L37ET5E
René
Post by René »
hello, watching The Big Bang Theory now. All works perfect but some episodes have bad audio, so I must play these episodes via #-TRANSCODE-# folder.
My question is: is there any way to automatically play next episode in this folder please? Currently I must run next episode manually.
Thank you.
Re: Playing TV shows on Panasonic Viera TX-L37ET5E
Hi Rene, since it's the TV that decides to play the next track we can't control that, sorry. If you can make logs by following the Problem Reporting Guidelines I can probably fix the issue with the audio though so you don't have to use the transcode folder anymore. Please play one file that works and one file that doesn't work so I can compare them.
