Samsung ue32f5505 shows up as unknown device
wazer
Post by wazer »
Hello wanted to get my tv corrected as it shows up as unknown device under the list.
http://prntscr.com/65eomi
(22.19 KiB) Downloaded 492 times
Re: Samsung ue32f5505 shows up as unknown device
Hi wazer, that doesn't have the info we need so can you please try using this version http://www.spirton.com/uploads/UMS/UMS-764ce59.exe and turn on Trace mode (see the Problem Reporting Guidelines link up top) before turning on your Samsung TV
wazer
Post by wazer »
SubJunk wrote:Hi wazer, that doesn't have the info we need so can you please try using this version http://www.spirton.com/uploads/UMS/UMS-764ce59.exe and turn on Trace mode (see the Problem Reporting Guidelines link up top) before turning on your Samsung TV
Done attached it with that version.
Also those errros i get in console
02-24 04:21:42  The server is now available for renderers to find
02-24 04:21:42  No IP filter specified, access granted to /192.168.1.2
02-24 04:21:42  Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: DAFUPnP, Cache-Control: no-cache, Pragma: no-cache
02-24 04:21:42  No IP filter specified, access granted to /192.168.1.3
02-24 04:22:43  No IP filter specified, access granted to /192.168.1.6
02-24 04:22:50  Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
02-24 04:22:50  	at net.pms.newgui.StatusTab$2.run(StatusTab.java:371)
02-24 04:22:50  	at java.awt.event.InvocationEvent.dispatch(Unknown Source)
02-24 04:22:50  	at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
02-24 04:22:50  	at java.awt.EventQueue.access$400(Unknown Source)
02-24 04:22:50  	at java.awt.EventQueue$3.run(Unknown Source)
02-24 04:22:50  	at java.security.AccessController.doPrivileged(Native Method)
02-24 04:22:50  	at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
02-24 04:22:50  	at java.awt.EventQueue.dispatchEvent(Unknown Source)
02-24 04:22:50  	at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
02-24 04:22:50  	at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
02-24 04:22:50  	at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
02-24 04:22:50  	at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
02-24 04:22:50  	at java.awt.EventDispatchThread.run(Unknown Source)
(33.35 KiB) Downloaded 426 times
The new logs show that the Samsung TV was detected, did it still not show up?
wazer
Post by wazer »
SubJunk wrote:The new logs show that the Samsung TV was detected, did it still not show up?
I can find it on TV yes, but in UMS theres no pictures of it being shown.
