[Confirmed] Live Subtitles work on mkv files but not mp4/avi
Subject pretty much says it all. This is on a PS3 with the latest version of UMS. Tested on a tv episode with both an mkv version and an mp4 version. mkv live subs worked, mp4 live subs = no subs show. Tested with both ffmpeg and mencoder as the primary engine. Logs attached.
- ums_dbg1.zip
- (99.03 KiB) Downloaded 783 times
Re: Live Subtitles work on mkv files but not mp4/avi
You may convert mkv to mp4 or avi. As video conversion, you may use this free video converter
I have tried, it is free and it can worked
Indeed. I could also just go to subscene or opensubtitles myself and download subs because they work that way with avi/mp4 files, but I would prefer to not have to do either of these things.
This is still broken with the newest version: 5.1.0
With MEncoder as the top priority engine, Live Subtitles will display properly on mkv files, but with avi/mp4 files the file plays, but no subtitles are shown.
With FFmpeg as the top priority engine, mkv files will not even play when attempting Live Subtitles: This content cannot be played. (800288E1)
In a possibly related bug, FFmpeg will play mkv files with external subtitles (idx/sub) just fine, displaying subtitles properly. But with mkv files that have subtitles contained within the mkv container the files will not even play when selecting the subtitled file in the "Transcode" folder: This content cannot be played. (800288E1)
Log files from both MEncoder and FFmpeg attached.
- ums_dbg.ffmpeg.zip
- (96.93 KiB) Downloaded 583 times
- ums_dbg.mencoder.zip
- (91.99 KiB) Downloaded 710 times
Still broken with 5.1.1 live subtitles do not play on mp4/avi files.
attached are new log files. first file played is an mp4 tv ep. file plays fine under live subtitles but no subs show. the same ep is then plaed but as an mkv file. subtitles show correctly.
- ums_dbg2.zip
- (91.54 KiB) Downloaded 755 times
Thanks for the reports guys, I've confirmed the bug and made an issue on our issue tracker at https://github.com/UniversalMediaServer ... issues/515
