what would be the command line for ffmpeg to send a file to my renderer
nickhere
Post by nickhere »
I would like to play with different setting and do it from command prompt.
on another note ums needs a download to hard drive folder converted.
Jumpy and channel parse data to ffmpeg why cant the render be the hard drive with the format I would like
Re: what would be the command line for ffmpeg to send a file to my renderer
You can download via the web interface, and you can set custom commands in the program in Transcoding Settings, and in the renderer config files themselves.
You can see what the existing FFmpeg commands we use are, by playing a file and then opening your debug.log file, the command is in there.
