Video plays in fast forward on PS3
Hey guys,
I've recently been having an issue with certain videos playing in fast forward while streaming to the PS3. A workaround is simply having the video play in slow motion on the PS3 to make it play at the proper speed; Is there a way to fix this issue without resorting to workarounds? I'm using a freshly installed copy of UMS version 5.0.1 Java8 (Java7 did the same thing). I checked the debug log and the only thing related to the playback of the problem videos is:
DEBUG 20:45:52.626 [ffmpeg.exe-60-2] Input #0, avi, from 'C:\Users\xxxx\Documents\Downloads\xxxx\Season 17\xxxxx.avi':
DEBUG 20:45:52.626 [ffmpeg.exe-60-2] Duration: 00:27:38.24, start: 0.000000, bitrate: 1076 kb/s
DEBUG 20:45:52.626 [ffmpeg.exe-60-2] Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 528x400 [SAR 1:1 DAR 33:25], 1021 kb/s, 25 fps, 25 tbr, 25 tbn, 30k tbc
DEBUG 20:45:52.626 [ffmpeg.exe-60-2] Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 24000 Hz, stereo, s16p, 48 kb/s
DEBUG 20:45:52.704 [ffmpeg.exe-60-2] [swscaler @ 051aef20] deprecated pixel format used, make sure you did set range correctly
DEBUG 20:45:52.735 [ffmpeg.exe-60-2] Output #0, image2, to 'pipe:':
DEBUG 20:45:52.735 [ffmpeg.exe-60-2] Metadata:
DEBUG 20:45:52.735 [ffmpeg.exe-60-2] encoder : Lavf56.16.102
DEBUG 20:45:52.735 [ffmpeg.exe-60-2] Stream #0:0: Video: mjpeg, yuvj420p(pc), 320x180 [SAR 594:595 DAR 1056:595], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc
DEBUG 20:45:52.735 [ffmpeg.exe-60-2] encoder : Lavc56.19.100 mjpeg
DEBUG 20:45:52.735 [ffmpeg.exe-60-2] Stream mapping:
DEBUG 20:45:52.735 [ffmpeg.exe-60-2] Stream #0:0 -> #0:0 (mpeg4 (native) -> mjpeg (native))
DEBUG 20:45:52.735 [ffmpeg.exe-60-2] Press [q] to stop, [?] for help
DEBUG 20:45:52.735 [ffmpeg.exe-60-2] [mpeg4 @ 051c36e0] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using a tool like VirtualDub or avidemux to fix it.
DEBUG 20:45:52.782 [ffmpeg.exe-60-2] [swscaler @ 051aef20] Warning: data is not aligned! This can lead to a speedloss
DEBUG 20:45:52.860 [ffmpeg.exe-60-2] frame= 1 fps=0.0 q=3.8 Lsize=N/A time=00:00:00.04 bitrate=N/A
DEBUG 20:45:52.860 [ffmpeg.exe-60-2] video:5kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Re: Video plays in fast forward on PS3
I am using 5.0.1 with no issues. I did have this problem when I used avisynth. I now just use FFmpeg transcoder with only the 'multithreading' set on the FFmpeg "general settings". Have you also tried any of the other transcode settings.
Please attach logs
