[Solved] UMS not seen anymore after change of router.
Dear,
First of all, thanks for the efforts in this product.
I am using UMS on Windows 7 to stream music. I control with and stream to BubbleUpnp on android.
Before , I could select perfectly music from UMS, i.e. the server was seen.
Now I changed router, and all of a sudden, this doesn't work anymore.
My BubbleUpnp renderer(s) are seen by UMS but I can't select on or stream from UMS.
My router settings are - as far as I can say - the same as they were before.
Any clue as what might cause this and how I can fix it ?
Jos
Jos
[Solved] Re: UMS not seen anymore after change of router.
Dear,
I solved my own problem.
Apparently, in the process of router replacement, Windows 7 has decided that my network is a "public" one instead of a "private" one, and thus applying different firewall rules.
Setting it to "private" again does the job.
Thanks once more for the product !
Jos
Jos
