Version 5.1.1 Bad News
michaelt
Post by michaelt »
Bad News:
The "Not Supported Video Format" is now hard for me - nothing works (but it was working fine for a while until ????).
The 5.1.0J8 fixes itself after a "Restart Server"
ums_dbg-13a_510J8_NotSUPP+Parse_OK.zip
(23.37 KiB) Downloaded 553 times
ums_dbg-13b_511J8_NotSupp+Parse_NFG.zip
(8.27 KiB) Downloaded 563 times
. . . . and a few others.
Samsung UN55C8000
Re: Version 5.1.1 Bad News
Hi michaelt, we're releasing a fix for the MediaInfo error within the next few hours, thanks for reporting :)
michaelt
Post by michaelt »
SubJunk wrote:Hi michaelt, we're releasing a fix for the MediaInfo error within the next few hours, thanks for reporting :)
Excellent!!
When will the Mac OS X be posted?
One more item off the checklist.
BTW - is this also related to the Parse error seen with '*' in title names?
Samsung UN55C8000
Re: [Solved] Version 5.1.1 Bad News
Woops, sorry for marking it as fixed, this is a different bug to the one fixed in 5.1.1.1. That was a Windows-only bug.
michaelt
Post by michaelt »
Nuts - thought the battle was won!!
I'll wait.
Samsung UN55C8000
I had a look through the logs and we need trace level to be enabled for both. Also please describe the problem completely. Thanks :)
michaelt
Post by michaelt »
Can do.
Samsung UN55C8000
michaelt
Post by michaelt »
Got them:
- 5.1.0 J8 - always OK
- 5.1.1 J8 - always Fail
I can't get either to do both as before - smells like an uninitialized variable somewhere.
Also, when it was doing both, it the "M*A*S*H (MASH| 1970)" "Parse" error message was in sync with it. Now it does not show at all and there are no "Parse" error messages!
Hope it helps.
ums_dbg-15_511J8_UnSup_BAD.zip
(48.13 KiB) Downloaded 522 times
ums_dbg-16_510J8_UnSupp_OK.zip
(74.56 KiB) Downloaded 500 times
Samsung UN55C8000
michaelt
Post by michaelt »
I went after this again. Don't know why the 'Parse' messages suddenly disappeared.
Tried a test folder with just a few files:
Screen Shot 2015-04-13 at 10.39.39 AM.png (12.61 KiB) Viewed 11168 times
The two highlighted do not show on the tv.
I have tried all the J8 versions from 5.0.0 to 5.1.1 - they all fail the same way. I included the 5.0.0 & 5.1.1 Trace logs.
Also another bug in 5.1.1: all files are coming up as "Not Supported File Format".
I tried installing globally and locally - same results.
Next???
ums_dbg-18_500J8_Parse_NoDataErr.zip
(8.19 KiB) Downloaded 540 times
ums_dbg-21_511J8_Parse_DataErr.zip
(17.24 KiB) Downloaded 505 times
Samsung UN55C8000
valib
Post by valib »
michaelt wrote:I went after this again. Don't know why the 'Parse' messages suddenly disappeared.
Next???
michael what does it mean .mkvx extension? Try to rename both not working videos to .mkv and test it again. I think that also sign "*" can cause the problem.
