Issue with mencoder.exe of UMS 2.0.0 build
Re: Issue with mencoder.exe of UMS 2.0.0 build
OK attached is a new version to test :)
mencoder.zip
(6.95 MiB) Downloaded 886 times
SpeedyQ
Post by SpeedyQ »
Tested, still same problems. debug.log attached...
debug.log
(226.39 KiB) Downloaded 926 times
gottoast
Post by gottoast »
I don't know that this has anything to do with your issue but noticed that your version of VLC is pretty old @ 1.1.5, latest version is 2.0.4
,____
||_|__\\__
|(0)___(o)|
SpeedyQ
Post by SpeedyQ »
We have already isolated the problem as an issue with mencoder.exe. But anyway thanks for the good intention. :)
Oh, and I don't really use vlc...
gottoast
Post by gottoast »
No prob just and observation... now if I could just isolate my problem :lol:
,____
||_|__\\__
|(0)___(o)|
OK, couple more tests :)
mencoder-2.zip
MEncoder test 2
(7.16 MiB) Downloaded 887 times
mencoder-1.zip
MEncoder test 1
(7.15 MiB) Downloaded 965 times
SpeedyQ
Post by SpeedyQ »
mencoder1.zip, this one seems to run just fine!!! (but it seems like an old version MEncoder SB37:
DEBUG 2012-11-19 02:33:50.781 [WrapperSimpleAppMain] My PID is 5484
INFO  2012-11-19 02:33:51.848 [WrapperSimpleAppMain] An invalid plugin was ignored
INFO  2012-11-19 02:33:52.168 [WrapperSimpleAppMain] Starting Universal Media Server 2.0.0
INFO  2012-11-19 02:33:52.178 [WrapperSimpleAppMain] Based on PS3 Media Server by shagrath, copyright 2008-2012
INFO  2012-11-19 02:33:52.188 [WrapperSimpleAppMain] http://www.universalmediaserver.com
INFO  2012-11-19 02:33:52.188 [WrapperSimpleAppMain] Build: 9456e1544 (2012-10-31)
INFO  2012-11-19 02:33:52.188 [WrapperSimpleAppMain] Java: 1.7.0_02-Oracle Corporation
INFO  2012-11-19 02:33:52.188 [WrapperSimpleAppMain] OS: Windows 7 64-bit 6.1
INFO  2012-11-19 02:33:52.188 [WrapperSimpleAppMain] Encoding: Cp1252
INFO  2012-11-19 02:33:52.188 [WrapperSimpleAppMain] Memory: 2730 MB
INFO  2012-11-19 02:33:52.188 [WrapperSimpleAppMain] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-11-19 02:33:52.198 [WrapperSimpleAppMain] Temp directory: C:\Windows\TEMP\universalmediaserver
INFO  2012-11-19 02:33:52.198 [WrapperSimpleAppMain] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2012-11-19 02:33:52.198 [WrapperSimpleAppMain] debug.log: C:\Program Files (x86)\Universal Media Server\debug.log
INFO  2012-11-19 02:33:52.198 [WrapperSimpleAppMain] Profile directory: C:\ProgramData\UMS
INFO  2012-11-19 02:33:52.198 [WrapperSimpleAppMain] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2012-11-19 02:33:52.198 [WrapperSimpleAppMain] Profile permissions: rw
INFO  2012-11-19 02:33:52.208 [WrapperSimpleAppMain] Profile name: MediaServer2009
INFO  2012-11-19 02:33:52.208 [WrapperSimpleAppMain] Loading MediaInfo library
INFO  2012-11-19 02:33:52.298 [WrapperSimpleAppMain] Loaded MediaInfoLib - v0.7.61
INFO  2012-11-19 02:33:52.308 [WrapperSimpleAppMain] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2012-11-19 02:33:52.308 [WrapperSimpleAppMain] Loading configuration file: AirPlayer.conf
INFO  2012-11-19 02:33:52.308 [WrapperSimpleAppMain] Loading configuration file: Android.conf
INFO  2012-11-19 02:33:52.318 [WrapperSimpleAppMain] Loading configuration file: Bravia4500.conf
INFO  2012-11-19 02:33:52.318 [WrapperSimpleAppMain] Loading configuration file: Bravia5500.conf
INFO  2012-11-19 02:33:52.328 [WrapperSimpleAppMain] Loading configuration file: BraviaEX.conf
INFO  2012-11-19 02:33:52.338 [WrapperSimpleAppMain] Loading configuration file: DirecTVHR.conf
INFO  2012-11-19 02:33:52.338 [WrapperSimpleAppMain] Loading configuration file: DLinkDSM510.conf
INFO  2012-11-19 02:33:52.348 [WrapperSimpleAppMain] Loading configuration file: FreeboxHD.conf
INFO  2012-11-19 02:33:52.348 [WrapperSimpleAppMain] Loading configuration file: FreecomMusicPal.conf
INFO  2012-11-19 02:33:52.348 [WrapperSimpleAppMain] Loading configuration file: iPad-iPhone.conf
INFO  2012-11-19 02:33:52.358 [WrapperSimpleAppMain] Loading configuration file: Kuro.conf
INFO  2012-11-19 02:33:52.368 [WrapperSimpleAppMain] Loading configuration file: LGST600.conf
INFO  2012-11-19 02:33:52.368 [WrapperSimpleAppMain] Loading configuration file: N900.conf
INFO  2012-11-19 02:33:52.378 [WrapperSimpleAppMain] Loading configuration file: OPPOBDP83.conf
INFO  2012-11-19 02:33:52.378 [WrapperSimpleAppMain] Loading configuration file: OPPOBDP93.conf
INFO  2012-11-19 02:33:52.388 [WrapperSimpleAppMain] Loading configuration file: Panasonic.conf
INFO  2012-11-19 02:33:52.388 [WrapperSimpleAppMain] Loading configuration file: Philips.conf
INFO  2012-11-19 02:33:52.398 [WrapperSimpleAppMain] Loading configuration file: PhilipsPFL.conf
INFO  2012-11-19 02:33:52.408 [WrapperSimpleAppMain] Loading configuration file: PopcornHour.conf
INFO  2012-11-19 02:33:52.408 [WrapperSimpleAppMain] Loading configuration file: PS3.conf
INFO  2012-11-19 02:33:52.418 [WrapperSimpleAppMain] Loading configuration file: Realtek.conf
INFO  2012-11-19 02:33:52.418 [WrapperSimpleAppMain] Loading configuration file: Samsung-SMT-G7400.conf
INFO  2012-11-19 02:33:52.428 [WrapperSimpleAppMain] Loading configuration file: SamsungAllShare.conf
INFO  2012-11-19 02:33:52.428 [WrapperSimpleAppMain] Loading configuration file: SamsungWiseLink.conf
INFO  2012-11-19 02:33:52.438 [WrapperSimpleAppMain] Loading configuration file: Showtime3.conf
INFO  2012-11-19 02:33:52.438 [WrapperSimpleAppMain] Loading configuration file: SMP-N100.conf
INFO  2012-11-19 02:33:52.438 [WrapperSimpleAppMain] Loading configuration file: SonyBluray.conf
INFO  2012-11-19 02:33:52.448 [WrapperSimpleAppMain] Loading configuration file: SonyBraviaHX800.conf
INFO  2012-11-19 02:33:52.448 [WrapperSimpleAppMain] Loading configuration file: Streamium.conf
INFO  2012-11-19 02:33:52.458 [WrapperSimpleAppMain] Loading configuration file: WDTVLive.conf
INFO  2012-11-19 02:33:52.458 [WrapperSimpleAppMain] Loading configuration file: WMP.conf
INFO  2012-11-19 02:33:52.458 [WrapperSimpleAppMain] Loading configuration file: XBMC.conf
INFO  2012-11-19 02:33:52.458 [WrapperSimpleAppMain] Loading configuration file: XBOX360.conf
INFO  2012-11-19 02:33:52.468 [WrapperSimpleAppMain] Loading configuration file: YamahaRXA1010.conf
INFO  2012-11-19 02:33:52.468 [WrapperSimpleAppMain] Loading configuration file: YamahaRXV671.conf
INFO  2012-11-19 02:33:52.468 [WrapperSimpleAppMain] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-11-19 02:33:52.468 [WrapperSimpleAppMain] launching: win32/mplayer.exe
DEBUG 2012-11-19 02:33:52.719 [WrapperSimpleAppMain] launching: win32/mplayer.exe
INFO  2012-11-19 02:33:52.842 [WrapperSimpleAppMain] Done!
INFO  2012-11-19 02:33:52.842 [WrapperSimpleAppMain] Found VideoLAN version 1.1.5 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-11-19 02:33:52.852 [WrapperSimpleAppMain] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2012-11-19 02:33:52.862 [WrapperSimpleAppMain] Found plugin: net.sharkhunter.gmusic.Gm_plugin
INFO  2012-11-19 02:33:52.862 [WrapperSimpleAppMain] Found plugin: net.pms.movieinfo.MovieInfo
INFO  2012-11-19 02:33:52.872 [WrapperSimpleAppMain] Found plugin: com.chocolatey.pmsencoder.Plugin
INFO  2012-11-19 02:33:52.872 [WrapperSimpleAppMain] Found plugin: com.sharkhunter.channel.CH_plugin
INFO  2012-11-19 02:33:52.892 [WrapperSimpleAppMain] PMSEncoder: initializing PMSEncoder 1.6.2
INFO  2012-11-19 02:33:52.962 [WrapperSimpleAppMain] PMSEncoder: script directory: C:\Program Files (x86)\Universal Media Server\scripts
INFO  2012-11-19 02:33:52.962 [WrapperSimpleAppMain] PMSEncoder: log directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-11-19 02:33:52.962 [WrapperSimpleAppMain] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files%20(x86)/Universal%20Media%20Server/plugins/pmsencoder-1.6.2.jar!/log4j_default.xml
INFO  2012-11-19 02:33:55.212 [WrapperSimpleAppMain] Registering transcoding engine: PMSEncoder
INFO  2012-11-19 02:33:55.212 [WrapperSimpleAppMain] PMSEncoder: checking engine list: [pmsencoder, mencoder, ffmpegaudio, mplayeraudio, tsmuxeraudio, ffmpegwebvideo, vlcvideo, mencoderwebvideo, mplayervideodump, mplayerwebaudio, vlcaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-11-19 02:33:55.212 [WrapperSimpleAppMain] PMSEncoder: already enabled
INFO  2012-11-19 02:33:55.212 [WrapperSimpleAppMain] Registering transcoding engine: AviSynth/FFmpeg
INFO  2012-11-19 02:33:55.222 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg Audio
INFO  2012-11-19 02:33:55.222 [WrapperSimpleAppMain] Registering transcoding engine: MEncoder
INFO  2012-11-19 02:33:55.222 [WrapperSimpleAppMain] Registering transcoding engine: AviSynth/MEncoder
INFO  2012-11-19 02:33:55.222 [WrapperSimpleAppMain] Registering transcoding engine: MPlayer Audio
INFO  2012-11-19 02:33:55.222 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg Web Video
INFO  2012-11-19 02:33:55.222 [WrapperSimpleAppMain] Registering transcoding engine: MEncoder Web
INFO  2012-11-19 02:33:55.222 [WrapperSimpleAppMain] Registering transcoding engine: MPlayer Video Dump
INFO  2012-11-19 02:33:55.222 [WrapperSimpleAppMain] Registering transcoding engine: MPlayer Web
INFO  2012-11-19 02:33:55.232 [WrapperSimpleAppMain] Registering transcoding engine: tsMuxeR
INFO  2012-11-19 02:33:55.232 [WrapperSimpleAppMain] Registering transcoding engine: Audio High Fidelity
DEBUG 2012-11-19 02:33:55.232 [WrapperSimpleAppMain] Found VLC version 1.1.5 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-11-19 02:33:55.232 [WrapperSimpleAppMain] Registering transcoding engine: VLC Audio Streaming
INFO  2012-11-19 02:33:55.232 [WrapperSimpleAppMain] Registering transcoding engine: VLC Video Streaming
INFO  2012-11-19 02:33:55.232 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-11-19 02:33:55.232 [WrapperSimpleAppMain] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-11-19 02:33:55.242 [WrapperSimpleAppMain] GoogleMusic plugin missing credentials
INFO  2012-11-19 02:33:55.282 [WrapperSimpleAppMain] Start channel 2.05
INFO  2012-11-19 02:33:55.342 [WrapperSimpleAppMain] Configuration saved to: C:\ProgramData\UMS\UMS.conf
INFO  2012-11-19 02:33:55.522 [WrapperSimpleAppMain] Using address /192.168.31.100 found on network interface: name:eth3 (Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20))
INFO  2012-11-19 02:33:55.522 [WrapperSimpleAppMain] Created socket: /192.168.31.100:5001
INFO  2012-11-19 02:33:55.602 [WrapperSimpleAppMain] Checking shared folder: D:\Movie-D-drive
INFO  2012-11-19 02:33:55.602 [WrapperSimpleAppMain] Checking shared folder: F:\Movie-F-drive
INFO  2012-11-19 02:33:55.602 [WrapperSimpleAppMain] Checking shared folder: M:\Movie-M-drive
INFO  2012-11-19 02:33:55.602 [WrapperSimpleAppMain] Checking shared folder: F:\Music
ERROR 2012-11-19 02:33:55.682 [WrapperSimpleAppMain] Attempt to add a null child to root
java.lang.NullPointerException: Invalid DLNA resource
	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:450) [ums.jar:na]
	at net.pms.dlna.RootFolder.discoverChildren(RootFolder.java:148) [ums.jar:na]
	at net.pms.configuration.RendererConfiguration.getRootFolder(RendererConfiguration.java:198) [ums.jar:na]
	at net.pms.PMS.getRootFolder(PMS.java:110) [ums.jar:na]
	at net.pms.PMS.init(PMS.java:510) [ums.jar:na]
	at net.pms.PMS.createInstance(PMS.java:858) [ums.jar:na]
	at net.pms.PMS.main(PMS.java:933) [ums.jar:na]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.7.0_02]
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.7.0_02]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.7.0_02]
	at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.7.0_02]
	at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:290) [wrapper.jar:3.5.15]
	at java.lang.Thread.run(Unknown Source) [na:1.7.0_02]
DEBUG 2012-11-19 02:33:55.722 [WrapperSimpleAppMain] Sending ALIVE...
INFO  2012-11-19 02:33:55.792 [WrapperSimpleAppMain] Using the following UUID configured in UMS.conf: ebbb7981-ccd8-3252-ad23-83e32f84c363
INFO  2012-11-19 02:33:57.724 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.31.102
INFO  2012-11-19 02:33:57.733 [pool-7-thread-1] Checking IP: 192.168.31.102 for Philips TV
INFO  2012-11-19 02:33:58.137 [New I/O server worker #1-4] Checking shared folder: D:\Movie-D-drive
INFO  2012-11-19 02:33:58.138 [New I/O server worker #1-4] Checking shared folder: F:\Movie-F-drive
INFO  2012-11-19 02:33:58.138 [New I/O server worker #1-4] Checking shared folder: M:\Movie-M-drive
INFO  2012-11-19 02:33:58.138 [New I/O server worker #1-4] Checking shared folder: F:\Music
ERROR 2012-11-19 02:33:58.145 [New I/O server worker #1-4] Attempt to add a null child to root
	at net.pms.network.RequestV2.answer(RequestV2.java:628) [ums.jar:na]
	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:299) [ums.jar:na]
	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:257) [ums.jar:na]
	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:80) [ums.jar:na]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [ums.jar:na]
	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:783) [ums.jar:na]
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:149) [ums.jar:na]
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) [ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) [ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndFireMessageReceived(ReplayingDecoder.java:527) [ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) [ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) [ums.jar:na]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) [ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) [ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:351) [ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:282) [ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:202) [ums.jar:na]
	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [ums.jar:na]
	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:44) [ums.jar:na]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_02]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_02]
INFO  2012-11-19 02:33:58.148 [New I/O server worker #1-4] Node(com.sharkhunter.channel.Channels) already has an ID=0$6, which is overriden now. The previous parent node was:RootFolder[[MapFile [name=Movie-D-drive, id=0$1, format=null, children=[]], MapFile [name=Movie-F-drive, id=0$2, format=null, children=[]], MapFile [name=Movie-M-drive, id=0$3, format=null, children=[]], MapFile [name=Music, id=0$4, format=null, children=[]], VirtualFolder [id=5, name=Web, full path=0$5, ext=null, discovered=false]]]
INFO  2012-11-19 02:34:00.673 [WrapperSimpleAppMain] The server should now appear on your renderer
INFO  2012-11-19 02:34:02.357 [pool-7-thread-1] Renderer Philips TV found on this address: 192.168.31.102
DEBUG 2012-11-19 02:34:02.357 [pool-7-thread-1] Starting ping -n 3 -l 64000 192.168.31.102
DEBUG 2012-11-19 02:34:04.370 [SpeedStats Failsafe] Stopping process: ping-0
DEBUG 2012-11-19 02:34:10.688 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-19 02:34:16.875 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Bad.Ass(2012).srt is WINDOWS-1252.
DEBUG 2012-11-19 02:34:17.312 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Bad.Ass(2012).srt is WINDOWS-1252.
DEBUG 2012-11-19 02:34:18.747 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Re-animator(1985).srt is WINDOWS-1252.
DEBUG 2012-11-19 02:34:18.888 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Re-animator(1985).srt is WINDOWS-1252.
DEBUG 2012-11-19 02:34:27.156 [New I/O server worker #1-4] Could not parse year "utc 2011-02-25 07:00:00"
DEBUG 2012-11-19 02:34:27.671 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Kamui-cd1.sub.
DEBUG 2012-11-19 02:34:27.858 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Kamui-cd2.sub.
DEBUG 2012-11-19 02:34:30.479 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Thunderbolt(1995)-cd1.sub.
DEBUG 2012-11-19 02:34:30.681 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Thunderbolt(1995)-cd2.sub.
DEBUG 2012-11-19 02:34:35.263 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-19 02:34:35.971 [pool-19-thread-3] Duplicate Angel.And.The.Badman.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.971 [pool-19-thread-2] Duplicate Against.The.Dark.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.971 [pool-19-thread-1] Duplicate A.Dangerous.Man.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.980 [pool-19-thread-1] Duplicate Armored.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.981 [pool-19-thread-2] Duplicate Bad.Boys.mp4 for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.981 [pool-19-thread-3] Duplicate Bad.Boys.II.mp4 for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.982 [pool-19-thread-3] Duplicate Blade.II(2002).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.982 [pool-19-thread-2] Duplicate Blade.Trinity(2004).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.983 [pool-19-thread-1] Duplicate Born.To.Raise.Hell(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.986 [pool-19-thread-1] Duplicate Bunraku(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.987 [pool-19-thread-3] Duplicate Cash.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.989 [pool-19-thread-2] Duplicate Casino.Royale(2006).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.990 [pool-19-thread-1] Duplicate City.Hunter.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.990 [pool-19-thread-3] Duplicate Chocolate.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.993 [pool-19-thread-3] Duplicate Crank.2.Hi.Voltage(2009).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.995 [pool-19-thread-2] Duplicate Death.Race.cd1.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.995 [pool-19-thread-1] Duplicate Death.Race.cd2.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.996 [pool-19-thread-2] Duplicate Dragon.Eyes(2012).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.997 [pool-19-thread-2] Duplicate Eraser.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.998 [pool-19-thread-2] Duplicate Fast.Five(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.998 [pool-19-thread-1] Duplicate Fire.of.conscience.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:35.999 [pool-19-thread-1] Duplicate G.I.Joe.The.Rise.Of.Cobra.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.000 [pool-19-thread-1] Duplicate Game.Of.Death(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.001 [pool-19-thread-2] Duplicate Hellbinders.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.001 [pool-19-thread-1] Duplicate Iron.Man(2008).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.002 [pool-19-thread-2] Duplicate Kamui-cd1.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.002 [pool-19-thread-3] Duplicate Kamui-cd2.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.004 [pool-19-thread-3] Duplicate Limitless(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.004 [pool-19-thread-2] Duplicate Les.Formidables.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.005 [pool-19-thread-2] Duplicate Mission.Impossible.1(1996).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.005 [pool-19-thread-3] Duplicate Mission.Impossible.2(2000).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.005 [pool-19-thread-1] Duplicate Mission.Impossible.3(2006).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.006 [pool-19-thread-3] Duplicate Mission.Impossible.4.Ghost.Protocol(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.007 [pool-19-thread-1] Duplicate My.Wife.Is.A.Gangster.3.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.007 [pool-19-thread-2] Duplicate Nude.Nuns.with.Big.Guns(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.008 [pool-19-thread-1] Duplicate Ocean's 11.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.008 [pool-19-thread-3] Duplicate Ocean's 12.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.008 [pool-19-thread-2] Duplicate Ocean's.13.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.009 [pool-19-thread-2] Duplicate Operation.Condor.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.009 [pool-19-thread-1] Duplicate Paintball.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.011 [pool-19-thread-1] Duplicate Project.A.2(1987).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.011 [pool-19-thread-3] Duplicate Project.A(1983).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.012 [pool-19-thread-2] Duplicate Priest(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.012 [pool-19-thread-2] Duplicate Quantum.of.Solace(2008).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.013 [pool-19-thread-3] Duplicate Rampage.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.014 [pool-19-thread-2] Duplicate Real.Steel(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.014 [pool-19-thread-3] Duplicate Recoil(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.015 [pool-19-thread-3] Duplicate Repo.Men.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.015 [pool-19-thread-1] Duplicate Rush.Hour.1.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.015 [pool-19-thread-3] Duplicate Rush.Hour.2.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.015 [pool-19-thread-1] Duplicate Rush.Hour.3.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.016 [pool-19-thread-3] Duplicate Salt.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.016 [pool-19-thread-1] Duplicate Shoot.Em.Up.Wide.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.016 [pool-19-thread-2] Duplicate Smokin.Aces.2.Assassins.Ball.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.017 [pool-19-thread-1] Duplicate Snatch.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.017 [pool-19-thread-3] Duplicate Sniper(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.017 [pool-19-thread-2] Duplicate Special.Forces(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.017 [pool-19-thread-1] Duplicate Steve.McQueen.Bullit.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.018 [pool-19-thread-3] Duplicate Steve.McQueen.The.Cincinnati.Kid.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.018 [pool-19-thread-1] Duplicate Steve.McQueen.The.Getaway.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.019 [pool-19-thread-3] Duplicate The.Bank.Job.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.019 [pool-19-thread-2] Duplicate The.Burma.Conspiracy(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.019 [pool-19-thread-1] Duplicate The.Expendables(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.019 [pool-19-thread-3] Duplicate The.Italian.Job.1969.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.020 [pool-19-thread-3] Duplicate The.Italian.Job.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.021 [pool-19-thread-1] Duplicate The.Keeper.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.021 [pool-19-thread-3] Duplicate The.Mechanic(1972).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.021 [pool-19-thread-2] Duplicate The.Mechanic(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.021 [pool-19-thread-1] Duplicate The.Mechanik.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.022 [pool-19-thread-1] Duplicate The.Outlaw.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.022 [pool-19-thread-3] Duplicate The.Phanton.CD1.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.023 [pool-19-thread-1] Duplicate The.Spy.Next.Door.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.023 [pool-19-thread-2] Duplicate The.Phanton.CD2.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.023 [pool-19-thread-3] Duplicate The.Shepherd.Border.Patrol.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.024 [pool-19-thread-1] Duplicate The.Tournament.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.024 [pool-19-thread-2] Duplicate The.Warriors.Way(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.025 [pool-19-thread-1] Duplicate Thunderbolt(1995)-cd2.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.025 [pool-19-thread-3] Duplicate Thunderbolt(1995)-cd1.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.025 [pool-19-thread-2] Duplicate Tower.Heist(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.026 [pool-19-thread-2] Duplicate Undisputed.III-Redemption.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.027 [pool-19-thread-3] Duplicate Universal.Soldier.Regeneration.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.028 [pool-19-thread-3] Duplicate Wedlock.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.028 [pool-19-thread-1] Duplicate xXx.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.029 [pool-19-thread-3] Duplicate xXx.State.Of.The.Union.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:34:36.029 [pool-19-thread-2] Duplicate Unstoppable(2010).mkv for direct streaming to renderer: Philips TV
INFO  2012-11-19 02:35:09.662 [New I/O server worker #1-8] Starting transcode/remux of Quantum.of.Solace(2008).mkv
DEBUG 2012-11-19 02:35:09.771 [New I/O server worker #1-8] Creating pipe \\.\pipe\mencoder1353288909755
DEBUG 2012-11-19 02:35:09.802 [Thread-16] Waiting for pipe connection \\.\pipe\mencoder1353288909755
DEBUG 2012-11-19 02:35:09.865 [mencoder.exe-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 M:\Movie-M-drive\Action\Quantum.of.Solace(2008).mkv -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=4 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=4:keyint=5:vqscale=1:vqmin=1:vrc_maxrate=36000:vrc_buf_size=7000 -ass -ass-color ffffff00 -ass-border-color 00000000 -ass-font-scale 1.4 -font C:\Windows\Fonts\Arial.ttf -ass-force-style FontName=C:\Windows\Fonts\Arial.ttf,Outline=1,Shadow=1,MarginV=10 -fontconfig -sid 0 -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1353288909755
DEBUG 2012-11-19 02:35:10.223 [mencoder.exe-1] Reading pipe: \\.\pipe\mencoder1353288909755
DEBUG 2012-11-19 02:35:10.223 [mencoder.exe-1] Attaching thread: mencoder.exe-1
DEBUG 2012-11-19 02:35:10.941 [Thread-20] MEncoder SB37 (C) 2000-2012 MPlayer Team
DEBUG 2012-11-19 02:35:10.941 [Thread-20] Custom build by SubJunk, http://www.spirton.com
DEBUG 2012-11-19 02:35:10.941 [Thread-20] success: format: 0  data: 0x0 - 0x4997a96f
DEBUG 2012-11-19 02:35:10.941 [Thread-20] libavformat version 54.25.104 (internal)
DEBUG 2012-11-19 02:35:10.941 [Thread-20] libavformat file format detected.
DEBUG 2012-11-19 02:35:10.957 [Thread-20] [lavf] stream 0: video (h264), -vid 0
DEBUG 2012-11-19 02:35:10.957 [Thread-20] [lavf] stream 1: audio (aac), -aid 0, -alang eng
DEBUG 2012-11-19 02:35:10.957 [Thread-20] [lavf] stream 2: subtitle (subrip), -sid 0, -slang nld
DEBUG 2012-11-19 02:35:10.957 [Thread-20] VIDEO:  [H264]  1920x800  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2012-11-19 02:35:10.957 [Thread-20] [V] filefmt:44  fourcc:0x34363248  size:1920x800  fps:23.976  ftime:=0.0417
DEBUG 2012-11-19 02:35:10.957 [Thread-20] ==========================================================================
DEBUG 2012-11-19 02:35:10.957 [Thread-20] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2012-11-19 02:35:10.957 [Thread-20] libavcodec version 54.54.100 (internal)
DEBUG 2012-11-19 02:35:10.973 [Thread-20] AUDIO: 48000 Hz, 2 ch, s16le, 0.0 kbit/0.00% (ratio: 0->192000)
DEBUG 2012-11-19 02:35:10.974 [Thread-20] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2012-11-19 02:35:10.974 [Thread-20] ==========================================================================
DEBUG 2012-11-19 02:35:10.974 [Thread-16] Result of \\.\pipe\mencoder1353288909755 : true
DEBUG 2012-11-19 02:35:10.975 [Thread-20] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2012-11-19 02:35:10.976 [Thread-20] Opening video filter: [ass auto=1]
DEBUG 2012-11-19 02:35:10.976 [Thread-20] [ass] auto-open
DEBUG 2012-11-19 02:35:10.993 [Thread-20] ==========================================================================
DEBUG 2012-11-19 02:35:10.995 [Thread-20] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2012-11-19 02:35:10.998 [Thread-20] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2012-11-19 02:35:10.998 [Thread-20] ==========================================================================
DEBUG 2012-11-19 02:35:10.998 [Thread-19] [ac3 @ 01130de0]channel_layout not specified
DEBUG 2012-11-19 02:35:10.998 [Thread-19] [ac3 @ 01130de0]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2012-11-19 02:35:10.999 [Thread-19] Limiting audio preload to 0.4s.
DEBUG 2012-11-19 02:35:10.999 [Thread-19] Increasing audio density to 4.
DEBUG 2012-11-19 02:35:11.002 [Thread-19] Unsupported PixelFormat 61
DEBUG 2012-11-19 02:35:11.002 [Thread-19] Unsupported PixelFormat 53
DEBUG 2012-11-19 02:35:11.002 [Thread-19] Unsupported PixelFormat 81
DEBUG 2012-11-19 02:35:11.028 [Thread-20] Movie-Aspect is 2.40:1 - prescaling to correct movie aspect.
DEBUG 2012-11-19 02:35:11.028 [Thread-20] videocodec: libavcodec (1920x800 fourcc=3267706d [mpg2])
DEBUG 2012-11-19 02:35:11.028 [Thread-20] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2012-11-19 02:35:11.066 [Thread-20] Writing header...
DEBUG 2012-11-19 02:35:11.066 [Thread-20] INITV: 0.200, 0.158, fps: 23.976
INFO  2012-11-19 02:35:15.993 [StartPlaying Event] renderer: 192.168.31.102, file: M:\Movie-M-drive\Action\Quantum.of.Solace(2008).mkv
DEBUG 2012-11-19 02:35:44.794 [New I/O server worker #1-2] Setting margin to 2Mb
DEBUG 2012-11-19 02:36:17.820 [Thread-19] [ass] PlayResX undefined, setting to 384
DEBUG 2012-11-19 02:37:39.290 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-19 02:38:06.071 [Buffered IO End Checker] Stopping process: mencoder.exe-1
INFO  2012-11-19 02:38:07.573 [StopPlaying Event] renderer: 192.168.31.102, file: M:\Movie-M-drive\Action\Quantum.of.Solace(2008).mkv
INFO  2012-11-19 02:38:27.338 [PMS Listeners Stopper] Sending BYEBYE...
DEBUG 2012-11-19 02:38:27.338 [UPNP-AliveMessageSender] Error while sending periodic alive message: sleep interrupted
DEBUG 2012-11-19 02:38:29.165 [PMS Listeners Stopper] Forcing shutdown of all active processes
INFO  2012-11-19 02:38:29.165 [PMS Listeners Stopper] Stopping server on host 192.168.31.100 and port 5001...
SpeedyQ
Post by SpeedyQ »
mencoder2.zip also runs fine same version SB37?!?:
DEBUG 2012-11-19 02:46:19.025 [WrapperSimpleAppMain] My PID is 6104
INFO  2012-11-19 02:46:20.089 [WrapperSimpleAppMain] An invalid plugin was ignored
INFO  2012-11-19 02:46:20.379 [WrapperSimpleAppMain] Starting Universal Media Server 2.0.0
INFO  2012-11-19 02:46:20.389 [WrapperSimpleAppMain] Based on PS3 Media Server by shagrath, copyright 2008-2012
INFO  2012-11-19 02:46:20.399 [WrapperSimpleAppMain] http://www.universalmediaserver.com
INFO  2012-11-19 02:46:20.399 [WrapperSimpleAppMain] Build: 9456e1544 (2012-10-31)
INFO  2012-11-19 02:46:20.399 [WrapperSimpleAppMain] Java: 1.7.0_02-Oracle Corporation
INFO  2012-11-19 02:46:20.399 [WrapperSimpleAppMain] OS: Windows 7 64-bit 6.1
INFO  2012-11-19 02:46:20.399 [WrapperSimpleAppMain] Encoding: Cp1252
INFO  2012-11-19 02:46:20.399 [WrapperSimpleAppMain] Memory: 2730 MB
INFO  2012-11-19 02:46:20.399 [WrapperSimpleAppMain] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-11-19 02:46:20.409 [WrapperSimpleAppMain] Temp directory: C:\Windows\TEMP\universalmediaserver
INFO  2012-11-19 02:46:20.409 [WrapperSimpleAppMain] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2012-11-19 02:46:20.409 [WrapperSimpleAppMain] debug.log: C:\Program Files (x86)\Universal Media Server\debug.log
INFO  2012-11-19 02:46:20.409 [WrapperSimpleAppMain] Profile directory: C:\ProgramData\UMS
INFO  2012-11-19 02:46:20.409 [WrapperSimpleAppMain] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2012-11-19 02:46:20.409 [WrapperSimpleAppMain] Profile permissions: rw
INFO  2012-11-19 02:46:20.409 [WrapperSimpleAppMain] Profile name: MediaServer2009
INFO  2012-11-19 02:46:20.419 [WrapperSimpleAppMain] Loading MediaInfo library
INFO  2012-11-19 02:46:20.509 [WrapperSimpleAppMain] Loaded MediaInfoLib - v0.7.61
INFO  2012-11-19 02:46:20.519 [WrapperSimpleAppMain] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2012-11-19 02:46:20.519 [WrapperSimpleAppMain] Loading configuration file: AirPlayer.conf
INFO  2012-11-19 02:46:20.529 [WrapperSimpleAppMain] Loading configuration file: Android.conf
INFO  2012-11-19 02:46:20.549 [WrapperSimpleAppMain] Loading configuration file: Bravia4500.conf
INFO  2012-11-19 02:46:20.549 [WrapperSimpleAppMain] Loading configuration file: Bravia5500.conf
INFO  2012-11-19 02:46:20.559 [WrapperSimpleAppMain] Loading configuration file: BraviaEX.conf
INFO  2012-11-19 02:46:20.569 [WrapperSimpleAppMain] Loading configuration file: DirecTVHR.conf
INFO  2012-11-19 02:46:20.579 [WrapperSimpleAppMain] Loading configuration file: DLinkDSM510.conf
INFO  2012-11-19 02:46:20.589 [WrapperSimpleAppMain] Loading configuration file: FreeboxHD.conf
INFO  2012-11-19 02:46:20.599 [WrapperSimpleAppMain] Loading configuration file: FreecomMusicPal.conf
INFO  2012-11-19 02:46:20.609 [WrapperSimpleAppMain] Loading configuration file: iPad-iPhone.conf
INFO  2012-11-19 02:46:20.619 [WrapperSimpleAppMain] Loading configuration file: Kuro.conf
INFO  2012-11-19 02:46:20.629 [WrapperSimpleAppMain] Loading configuration file: LGST600.conf
INFO  2012-11-19 02:46:20.639 [WrapperSimpleAppMain] Loading configuration file: N900.conf
INFO  2012-11-19 02:46:20.649 [WrapperSimpleAppMain] Loading configuration file: OPPOBDP83.conf
INFO  2012-11-19 02:46:20.649 [WrapperSimpleAppMain] Loading configuration file: OPPOBDP93.conf
INFO  2012-11-19 02:46:20.659 [WrapperSimpleAppMain] Loading configuration file: Panasonic.conf
INFO  2012-11-19 02:46:20.669 [WrapperSimpleAppMain] Loading configuration file: Philips.conf
INFO  2012-11-19 02:46:20.689 [WrapperSimpleAppMain] Loading configuration file: PhilipsPFL.conf
INFO  2012-11-19 02:46:20.699 [WrapperSimpleAppMain] Loading configuration file: PopcornHour.conf
INFO  2012-11-19 02:46:20.699 [WrapperSimpleAppMain] Loading configuration file: PS3.conf
INFO  2012-11-19 02:46:20.719 [WrapperSimpleAppMain] Loading configuration file: Realtek.conf
INFO  2012-11-19 02:46:20.719 [WrapperSimpleAppMain] Loading configuration file: Samsung-SMT-G7400.conf
INFO  2012-11-19 02:46:20.729 [WrapperSimpleAppMain] Loading configuration file: SamsungAllShare.conf
INFO  2012-11-19 02:46:20.739 [WrapperSimpleAppMain] Loading configuration file: SamsungWiseLink.conf
INFO  2012-11-19 02:46:20.739 [WrapperSimpleAppMain] Loading configuration file: Showtime3.conf
INFO  2012-11-19 02:46:20.749 [WrapperSimpleAppMain] Loading configuration file: SMP-N100.conf
INFO  2012-11-19 02:46:20.759 [WrapperSimpleAppMain] Loading configuration file: SonyBluray.conf
INFO  2012-11-19 02:46:20.769 [WrapperSimpleAppMain] Loading configuration file: SonyBraviaHX800.conf
INFO  2012-11-19 02:46:20.789 [WrapperSimpleAppMain] Loading configuration file: Streamium.conf
INFO  2012-11-19 02:46:20.799 [WrapperSimpleAppMain] Loading configuration file: WDTVLive.conf
INFO  2012-11-19 02:46:20.799 [WrapperSimpleAppMain] Loading configuration file: WMP.conf
INFO  2012-11-19 02:46:20.809 [WrapperSimpleAppMain] Loading configuration file: XBMC.conf
INFO  2012-11-19 02:46:20.809 [WrapperSimpleAppMain] Loading configuration file: XBOX360.conf
INFO  2012-11-19 02:46:20.819 [WrapperSimpleAppMain] Loading configuration file: YamahaRXA1010.conf
INFO  2012-11-19 02:46:20.819 [WrapperSimpleAppMain] Loading configuration file: YamahaRXV671.conf
INFO  2012-11-19 02:46:20.819 [WrapperSimpleAppMain] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-11-19 02:46:20.819 [WrapperSimpleAppMain] launching: win32/mplayer.exe
DEBUG 2012-11-19 02:46:20.978 [WrapperSimpleAppMain] launching: win32/mplayer.exe
INFO  2012-11-19 02:46:21.105 [WrapperSimpleAppMain] Done!
INFO  2012-11-19 02:46:21.105 [WrapperSimpleAppMain] Found VideoLAN version 1.1.5 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-11-19 02:46:21.115 [WrapperSimpleAppMain] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2012-11-19 02:46:21.125 [WrapperSimpleAppMain] Found plugin: net.sharkhunter.gmusic.Gm_plugin
INFO  2012-11-19 02:46:21.125 [WrapperSimpleAppMain] Found plugin: net.pms.movieinfo.MovieInfo
INFO  2012-11-19 02:46:21.135 [WrapperSimpleAppMain] Found plugin: com.chocolatey.pmsencoder.Plugin
INFO  2012-11-19 02:46:21.135 [WrapperSimpleAppMain] Found plugin: com.sharkhunter.channel.CH_plugin
INFO  2012-11-19 02:46:21.155 [WrapperSimpleAppMain] PMSEncoder: initializing PMSEncoder 1.6.2
INFO  2012-11-19 02:46:21.215 [WrapperSimpleAppMain] PMSEncoder: script directory: C:\Program Files (x86)\Universal Media Server\scripts
INFO  2012-11-19 02:46:21.215 [WrapperSimpleAppMain] PMSEncoder: log directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-11-19 02:46:21.215 [WrapperSimpleAppMain] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files%20(x86)/Universal%20Media%20Server/plugins/pmsencoder-1.6.2.jar!/log4j_default.xml
INFO  2012-11-19 02:46:23.391 [WrapperSimpleAppMain] Registering transcoding engine: PMSEncoder
INFO  2012-11-19 02:46:23.391 [WrapperSimpleAppMain] PMSEncoder: checking engine list: [pmsencoder, mencoder, ffmpegaudio, mplayeraudio, tsmuxeraudio, ffmpegwebvideo, vlcvideo, mencoderwebvideo, mplayervideodump, mplayerwebaudio, vlcaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-11-19 02:46:23.391 [WrapperSimpleAppMain] PMSEncoder: already enabled
INFO  2012-11-19 02:46:23.391 [WrapperSimpleAppMain] Registering transcoding engine: AviSynth/FFmpeg
INFO  2012-11-19 02:46:23.391 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg Audio
INFO  2012-11-19 02:46:23.401 [WrapperSimpleAppMain] Registering transcoding engine: MEncoder
INFO  2012-11-19 02:46:23.401 [WrapperSimpleAppMain] Registering transcoding engine: AviSynth/MEncoder
INFO  2012-11-19 02:46:23.401 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg
INFO  2012-11-19 02:46:23.401 [WrapperSimpleAppMain] Registering transcoding engine: MPlayer Audio
INFO  2012-11-19 02:46:23.401 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg Web Video
INFO  2012-11-19 02:46:23.401 [WrapperSimpleAppMain] Registering transcoding engine: MEncoder Web
INFO  2012-11-19 02:46:23.401 [WrapperSimpleAppMain] Registering transcoding engine: MPlayer Video Dump
INFO  2012-11-19 02:46:23.401 [WrapperSimpleAppMain] Registering transcoding engine: MPlayer Web
INFO  2012-11-19 02:46:23.401 [WrapperSimpleAppMain] Registering transcoding engine: tsMuxeR
INFO  2012-11-19 02:46:23.411 [WrapperSimpleAppMain] Registering transcoding engine: Audio High Fidelity
DEBUG 2012-11-19 02:46:23.411 [WrapperSimpleAppMain] Found VLC version 1.1.5 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-11-19 02:46:23.411 [WrapperSimpleAppMain] Registering transcoding engine: VLC Audio Streaming
INFO  2012-11-19 02:46:23.411 [WrapperSimpleAppMain] Registering transcoding engine: VLC Video Streaming
INFO  2012-11-19 02:46:23.411 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-11-19 02:46:23.411 [WrapperSimpleAppMain] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-11-19 02:46:23.421 [WrapperSimpleAppMain] GoogleMusic plugin missing credentials
INFO  2012-11-19 02:46:23.451 [WrapperSimpleAppMain] Start channel 2.05
INFO  2012-11-19 02:46:23.491 [WrapperSimpleAppMain] Configuration saved to: C:\ProgramData\UMS\UMS.conf
INFO  2012-11-19 02:46:23.681 [WrapperSimpleAppMain] Using address /192.168.31.100 found on network interface: name:eth3 (Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20))
INFO  2012-11-19 02:46:23.681 [WrapperSimpleAppMain] Created socket: /192.168.31.100:5001
INFO  2012-11-19 02:46:23.791 [WrapperSimpleAppMain] Checking shared folder: D:\Movie-D-drive
INFO  2012-11-19 02:46:23.791 [WrapperSimpleAppMain] Checking shared folder: F:\Movie-F-drive
INFO  2012-11-19 02:46:23.791 [WrapperSimpleAppMain] Checking shared folder: M:\Movie-M-drive
INFO  2012-11-19 02:46:23.791 [WrapperSimpleAppMain] Checking shared folder: F:\Music
ERROR 2012-11-19 02:46:23.851 [WrapperSimpleAppMain] Attempt to add a null child to root
DEBUG 2012-11-19 02:46:23.881 [WrapperSimpleAppMain] Sending ALIVE...
INFO  2012-11-19 02:46:23.951 [WrapperSimpleAppMain] Using the following UUID configured in UMS.conf: ebbb7981-ccd8-3252-ad23-83e32f84c363
INFO  2012-11-19 02:46:25.690 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.31.102
INFO  2012-11-19 02:46:25.700 [pool-7-thread-1] Checking IP: 192.168.31.102 for Philips TV
INFO  2012-11-19 02:46:26.104 [New I/O server worker #1-4] Checking shared folder: D:\Movie-D-drive
INFO  2012-11-19 02:46:26.104 [New I/O server worker #1-4] Checking shared folder: F:\Movie-F-drive
INFO  2012-11-19 02:46:26.105 [New I/O server worker #1-4] Checking shared folder: M:\Movie-M-drive
INFO  2012-11-19 02:46:26.105 [New I/O server worker #1-4] Checking shared folder: F:\Music
ERROR 2012-11-19 02:46:26.112 [New I/O server worker #1-4] Attempt to add a null child to root
INFO  2012-11-19 02:46:26.115 [New I/O server worker #1-4] Node(com.sharkhunter.channel.Channels) already has an ID=0$6, which is overriden now. The previous parent node was:RootFolder[[MapFile [name=Movie-D-drive, id=0$1, format=null, children=[]], MapFile [name=Movie-F-drive, id=0$2, format=null, children=[]], MapFile [name=Movie-M-drive, id=0$3, format=null, children=[]], MapFile [name=Music, id=0$4, format=null, children=[]], VirtualFolder [id=5, name=Web, full path=0$5, ext=null, discovered=false]]]
INFO  2012-11-19 02:46:29.041 [WrapperSimpleAppMain] The server should now appear on your renderer
INFO  2012-11-19 02:46:30.321 [pool-7-thread-1] Renderer Philips TV found on this address: 192.168.31.102
DEBUG 2012-11-19 02:46:30.321 [pool-7-thread-1] Starting ping -n 3 -l 64000 192.168.31.102
DEBUG 2012-11-19 02:46:32.333 [SpeedStats Failsafe] Stopping process: ping-0
DEBUG 2012-11-19 02:46:39.057 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-19 02:46:39.328 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Bad.Ass(2012).srt is WINDOWS-1252.
DEBUG 2012-11-19 02:46:39.709 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Bad.Ass(2012).srt is WINDOWS-1252.
DEBUG 2012-11-19 02:46:41.192 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Re-animator(1985).srt is WINDOWS-1252.
DEBUG 2012-11-19 02:46:41.333 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Re-animator(1985).srt is WINDOWS-1252.
DEBUG 2012-11-19 02:46:49.859 [New I/O server worker #1-4] Could not parse year "utc 2011-02-25 07:00:00"
DEBUG 2012-11-19 02:46:50.342 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Kamui-cd1.sub.
DEBUG 2012-11-19 02:46:50.545 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Kamui-cd2.sub.
DEBUG 2012-11-19 02:46:53.135 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Thunderbolt(1995)-cd1.sub.
DEBUG 2012-11-19 02:46:53.369 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Thunderbolt(1995)-cd2.sub.
DEBUG 2012-11-19 02:46:58.922 [pool-19-thread-1] Duplicate A.Dangerous.Man.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.922 [pool-19-thread-2] Duplicate Against.The.Dark.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.922 [pool-19-thread-3] Duplicate Angel.And.The.Badman.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.922 [pool-19-thread-1] Duplicate Armored.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.922 [pool-19-thread-2] Duplicate Bad.Boys.II.mp4 for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.922 [pool-19-thread-3] Duplicate Bad.Boys.mp4 for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.922 [pool-19-thread-1] Duplicate Blade.II(2002).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.922 [pool-19-thread-3] Duplicate Blade.Trinity(2004).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.938 [pool-19-thread-2] Duplicate Born.To.Raise.Hell(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.938 [pool-19-thread-1] Duplicate Bunraku(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.938 [pool-19-thread-2] Duplicate Cash.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.938 [pool-19-thread-3] Duplicate Casino.Royale(2006).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.938 [pool-19-thread-2] Duplicate Chocolate.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.938 [pool-19-thread-1] Duplicate City.Hunter.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.938 [pool-19-thread-2] Duplicate Crank.2.Hi.Voltage(2009).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.938 [pool-19-thread-3] Duplicate Death.Race.cd1.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.938 [pool-19-thread-1] Duplicate Death.Race.cd2.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Dragon.Eyes(2012).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-2] Duplicate Eraser.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Fast.Five(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-2] Duplicate Fire.of.conscience.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-2] Duplicate G.I.Joe.The.Rise.Of.Cobra.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Game.Of.Death(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-3] Duplicate Hellbinders.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-3] Duplicate Iron.Man(2008).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Kamui-cd1.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-2] Duplicate Kamui-cd2.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-3] Duplicate Les.Formidables.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-2] Duplicate Limitless(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-3] Duplicate Mission.Impossible.1(1996).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Mission.Impossible.3(2006).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-3] Duplicate Mission.Impossible.4.Ghost.Protocol(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate My.Wife.Is.A.Gangster.3.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-3] Duplicate Nude.Nuns.with.Big.Guns(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Ocean's 11.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-3] Duplicate Ocean's 12.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Ocean's.13.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Operation.Condor.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Paintball.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-1] Duplicate Priest(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.954 [pool-19-thread-3] Duplicate Project.A.2(1987).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate Project.A(1983).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate Quantum.of.Solace(2008).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate Rampage.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate Real.Steel(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate Recoil(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate Repo.Men.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate Rush.Hour.1.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate Rush.Hour.2.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate Rush.Hour.3.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate Salt.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate Shoot.Em.Up.Wide.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-2] Duplicate Mission.Impossible.2(2000).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate Smokin.Aces.2.Assassins.Ball.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate Snatch.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-2] Duplicate Special.Forces(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate Sniper(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate Steve.McQueen.Bullit.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-2] Duplicate Steve.McQueen.The.Cincinnati.Kid.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate Steve.McQueen.The.Getaway.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate The.Bank.Job.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-2] Duplicate The.Burma.Conspiracy(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate The.Expendables(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate The.Italian.Job.1969.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate The.Italian.Job.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-2] Duplicate The.Keeper.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate The.Mechanic(1972).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate The.Mechanic(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-2] Duplicate The.Mechanik.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate The.Outlaw.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-2] Duplicate The.Phanton.CD1.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate The.Phanton.CD2.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate The.Shepherd.Border.Patrol.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-2] Duplicate The.Spy.Next.Door.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate The.Tournament.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-1] Duplicate The.Warriors.Way(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-2] Duplicate Thunderbolt(1995)-cd1.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.969 [pool-19-thread-3] Duplicate Thunderbolt(1995)-cd2.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.985 [pool-19-thread-1] Duplicate Tower.Heist(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.985 [pool-19-thread-3] Duplicate Undisputed.III-Redemption.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.985 [pool-19-thread-1] Duplicate Universal.Soldier.Regeneration.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.985 [pool-19-thread-3] Duplicate Unstoppable(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.985 [pool-19-thread-1] Duplicate Wedlock.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.985 [pool-19-thread-1] Duplicate xXx.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:46:58.985 [pool-19-thread-2] Duplicate xXx.State.Of.The.Union.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 02:47:03.556 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2012-11-19 02:47:34.428 [New I/O server worker #1-7] Starting transcode/remux of Quantum.of.Solace(2008).mkv
DEBUG 2012-11-19 02:47:34.506 [New I/O server worker #1-7] Creating pipe \\.\pipe\mencoder1353289654490
DEBUG 2012-11-19 02:47:34.537 [Thread-16] Waiting for pipe connection \\.\pipe\mencoder1353289654490
DEBUG 2012-11-19 02:47:34.600 [mencoder.exe-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 M:\Movie-M-drive\Action\Quantum.of.Solace(2008).mkv -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=4 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=4:keyint=5:vqscale=1:vqmin=1:vrc_maxrate=36000:vrc_buf_size=7000 -ass -ass-color ffffff00 -ass-border-color 00000000 -ass-font-scale 1.4 -font C:\Windows\Fonts\Arial.ttf -ass-force-style FontName=C:\Windows\Fonts\Arial.ttf,Outline=1,Shadow=1,MarginV=10 -fontconfig -sid 0 -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1353289654490
DEBUG 2012-11-19 02:47:35.208 [mencoder.exe-1] Reading pipe: \\.\pipe\mencoder1353289654490
DEBUG 2012-11-19 02:47:35.208 [mencoder.exe-1] Attaching thread: mencoder.exe-1
DEBUG 2012-11-19 02:47:35.816 [Thread-20] MEncoder SB37 (C) 2000-2012 MPlayer Team
DEBUG 2012-11-19 02:47:35.816 [Thread-20] Custom build by SubJunk, http://www.spirton.com
DEBUG 2012-11-19 02:47:35.816 [Thread-20] success: format: 0  data: 0x0 - 0x4997a96f
DEBUG 2012-11-19 02:47:35.816 [Thread-20] libavformat version 54.25.104 (internal)
DEBUG 2012-11-19 02:47:35.832 [Thread-20] libavformat file format detected.
DEBUG 2012-11-19 02:47:35.852 [Thread-20] [lavf] stream 0: video (h264), -vid 0
DEBUG 2012-11-19 02:47:35.852 [Thread-20] [lavf] stream 1: audio (aac), -aid 0, -alang eng
DEBUG 2012-11-19 02:47:35.852 [Thread-20] [lavf] stream 2: subtitle (subrip), -sid 0, -slang nld
DEBUG 2012-11-19 02:47:35.852 [Thread-20] VIDEO:  [H264]  1920x800  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2012-11-19 02:47:35.852 [Thread-20] [V] filefmt:44  fourcc:0x34363248  size:1920x800  fps:23.976  ftime:=0.0417
DEBUG 2012-11-19 02:47:35.852 [Thread-20] ==========================================================================
DEBUG 2012-11-19 02:47:35.853 [Thread-20] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2012-11-19 02:47:35.854 [Thread-20] libavcodec version 54.55.100 (internal)
DEBUG 2012-11-19 02:47:35.856 [Thread-20] AUDIO: 48000 Hz, 2 ch, s16le, 0.0 kbit/0.00% (ratio: 0->192000)
DEBUG 2012-11-19 02:47:35.856 [Thread-20] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2012-11-19 02:47:35.856 [Thread-20] ==========================================================================
DEBUG 2012-11-19 02:47:35.856 [Thread-16] Result of \\.\pipe\mencoder1353289654490 : true
DEBUG 2012-11-19 02:47:35.858 [Thread-20] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2012-11-19 02:47:35.858 [Thread-20] Opening video filter: [ass auto=1]
DEBUG 2012-11-19 02:47:35.858 [Thread-20] [ass] auto-open
DEBUG 2012-11-19 02:47:35.878 [Thread-20] ==========================================================================
DEBUG 2012-11-19 02:47:35.879 [Thread-20] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2012-11-19 02:47:35.883 [Thread-20] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2012-11-19 02:47:35.883 [Thread-20] ==========================================================================
DEBUG 2012-11-19 02:47:35.883 [Thread-19] [ac3 @ 01136220]channel_layout not specified
DEBUG 2012-11-19 02:47:35.883 [Thread-19] [ac3 @ 01136220]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2012-11-19 02:47:35.883 [Thread-19] Limiting audio preload to 0.4s.
DEBUG 2012-11-19 02:47:35.883 [Thread-19] Increasing audio density to 4.
DEBUG 2012-11-19 02:47:35.887 [Thread-19] Unsupported PixelFormat 61
DEBUG 2012-11-19 02:47:35.887 [Thread-19] Unsupported PixelFormat 53
DEBUG 2012-11-19 02:47:35.887 [Thread-19] Unsupported PixelFormat 81
DEBUG 2012-11-19 02:47:35.916 [Thread-20] Movie-Aspect is 2.40:1 - prescaling to correct movie aspect.
DEBUG 2012-11-19 02:47:35.916 [Thread-20] videocodec: libavcodec (1920x800 fourcc=3267706d [mpg2])
DEBUG 2012-11-19 02:47:35.916 [Thread-20] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2012-11-19 02:47:35.992 [Thread-20] Writing header...
DEBUG 2012-11-19 02:47:35.992 [Thread-20] INITV: 0.200, 0.158, fps: 23.976
DEBUG 2012-11-19 02:47:35.993 [Thread-20]
INFO  2012-11-19 02:47:40.717 [StartPlaying Event] renderer: 192.168.31.102, file: M:\Movie-M-drive\Action\Quantum.of.Solace(2008).mkv
DEBUG 2012-11-19 02:48:08.718 [New I/O server worker #1-2] Setting margin to 2Mb
DEBUG 2012-11-19 02:48:39.715 [Thread-19] [ass] PlayResX undefined, setting to 384
DEBUG 2012-11-19 02:50:07.703 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-19 02:50:43.780 [Buffered IO End Checker] Stopping process: mencoder.exe-1
INFO  2012-11-19 02:50:45.282 [StopPlaying Event] renderer: 192.168.31.102, file: M:\Movie-M-drive\Action\Quantum.of.Solace(2008).mkv
INFO  2012-11-19 02:51:02.099 [PMS Listeners Stopper] Sending BYEBYE...
DEBUG 2012-11-19 02:51:02.099 [UPNP-AliveMessageSender] Error while sending periodic alive message: sleep interrupted
DEBUG 2012-11-19 02:51:07.090 [PMS Listeners Stopper] Forcing shutdown of all active processes
INFO  2012-11-19 02:51:07.090 [PMS Listeners Stopper] Stopping server on host 192.168.31.100 and port 5001...
Also odd but probably not related to the issue, 2 java exception errors in both logfiles...
Re: Issue with mencoder.exe of UMS 2.0.0 build
Great, we are narrowing it down now :)
Here's another one
mencoder.zip
(7.17 MiB) Downloaded 888 times
SpeedyQ
Post by SpeedyQ »
Hi Subjunk,
This one also runs just fine...
DEBUG 2012-11-19 18:19:31.742 [WrapperSimpleAppMain] My PID is 3360
INFO  2012-11-19 18:19:36.984 [WrapperSimpleAppMain] An invalid plugin was ignored
INFO  2012-11-19 18:19:38.076 [WrapperSimpleAppMain] Starting Universal Media Server 2.0.0
INFO  2012-11-19 18:19:38.122 [WrapperSimpleAppMain] Based on PS3 Media Server by shagrath, copyright 2008-2012
INFO  2012-11-19 18:19:38.122 [WrapperSimpleAppMain] http://www.universalmediaserver.com
INFO  2012-11-19 18:19:38.138 [WrapperSimpleAppMain]
INFO  2012-11-19 18:19:38.138 [WrapperSimpleAppMain] Build: 9456e1544 (2012-10-31)
INFO  2012-11-19 18:19:38.138 [WrapperSimpleAppMain] Java: 1.7.0_02-Oracle Corporation
INFO  2012-11-19 18:19:38.138 [WrapperSimpleAppMain] OS: Windows 7 64-bit 6.1
INFO  2012-11-19 18:19:38.138 [WrapperSimpleAppMain] Encoding: Cp1252
INFO  2012-11-19 18:19:38.138 [WrapperSimpleAppMain] Memory: 2730 MB
INFO  2012-11-19 18:19:38.138 [WrapperSimpleAppMain] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-11-19 18:19:38.169 [WrapperSimpleAppMain] Temp directory: C:\Windows\TEMP\universalmediaserver
INFO  2012-11-19 18:19:38.169 [WrapperSimpleAppMain] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2012-11-19 18:19:38.169 [WrapperSimpleAppMain] debug.log: C:\Program Files (x86)\Universal Media Server\debug.log
INFO  2012-11-19 18:19:38.169 [WrapperSimpleAppMain] Profile directory: C:\ProgramData\UMS
INFO  2012-11-19 18:19:38.169 [WrapperSimpleAppMain] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2012-11-19 18:19:38.169 [WrapperSimpleAppMain] Profile permissions: rw
INFO  2012-11-19 18:19:38.169 [WrapperSimpleAppMain] Profile name: MediaServer2009
INFO  2012-11-19 18:19:38.200 [WrapperSimpleAppMain] Loading MediaInfo library
INFO  2012-11-19 18:19:38.544 [WrapperSimpleAppMain] Loaded MediaInfoLib - v0.7.61
INFO  2012-11-19 18:19:38.575 [WrapperSimpleAppMain] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2012-11-19 18:19:38.575 [WrapperSimpleAppMain] Loading configuration file: AirPlayer.conf
INFO  2012-11-19 18:19:38.590 [WrapperSimpleAppMain] Loading configuration file: Android.conf
INFO  2012-11-19 18:19:38.590 [WrapperSimpleAppMain] Loading configuration file: Bravia4500.conf
INFO  2012-11-19 18:19:38.606 [WrapperSimpleAppMain] Loading configuration file: Bravia5500.conf
INFO  2012-11-19 18:19:38.606 [WrapperSimpleAppMain] Loading configuration file: BraviaEX.conf
INFO  2012-11-19 18:19:38.622 [WrapperSimpleAppMain] Loading configuration file: DirecTVHR.conf
INFO  2012-11-19 18:19:38.637 [WrapperSimpleAppMain] Loading configuration file: DLinkDSM510.conf
INFO  2012-11-19 18:19:38.637 [WrapperSimpleAppMain] Loading configuration file: FreeboxHD.conf
INFO  2012-11-19 18:19:38.653 [WrapperSimpleAppMain] Loading configuration file: FreecomMusicPal.conf
INFO  2012-11-19 18:19:38.653 [WrapperSimpleAppMain] Loading configuration file: iPad-iPhone.conf
INFO  2012-11-19 18:19:38.668 [WrapperSimpleAppMain] Loading configuration file: Kuro.conf
INFO  2012-11-19 18:19:38.668 [WrapperSimpleAppMain] Loading configuration file: LGST600.conf
INFO  2012-11-19 18:19:38.684 [WrapperSimpleAppMain] Loading configuration file: N900.conf
INFO  2012-11-19 18:19:38.684 [WrapperSimpleAppMain] Loading configuration file: OPPOBDP83.conf
INFO  2012-11-19 18:19:38.700 [WrapperSimpleAppMain] Loading configuration file: OPPOBDP93.conf
INFO  2012-11-19 18:19:38.700 [WrapperSimpleAppMain] Loading configuration file: Panasonic.conf
INFO  2012-11-19 18:19:38.715 [WrapperSimpleAppMain] Loading configuration file: Philips.conf
INFO  2012-11-19 18:19:38.715 [WrapperSimpleAppMain] Loading configuration file: PhilipsPFL.conf
INFO  2012-11-19 18:19:38.731 [WrapperSimpleAppMain] Loading configuration file: PopcornHour.conf
INFO  2012-11-19 18:19:38.731 [WrapperSimpleAppMain] Loading configuration file: PS3.conf
INFO  2012-11-19 18:19:38.746 [WrapperSimpleAppMain] Loading configuration file: Realtek.conf
INFO  2012-11-19 18:19:38.746 [WrapperSimpleAppMain] Loading configuration file: Samsung-SMT-G7400.conf
INFO  2012-11-19 18:19:38.762 [WrapperSimpleAppMain] Loading configuration file: SamsungAllShare.conf
INFO  2012-11-19 18:19:38.778 [WrapperSimpleAppMain] Loading configuration file: SamsungWiseLink.conf
INFO  2012-11-19 18:19:38.778 [WrapperSimpleAppMain] Loading configuration file: Showtime3.conf
INFO  2012-11-19 18:19:38.778 [WrapperSimpleAppMain] Loading configuration file: SMP-N100.conf
INFO  2012-11-19 18:19:38.793 [WrapperSimpleAppMain] Loading configuration file: SonyBluray.conf
INFO  2012-11-19 18:19:38.809 [WrapperSimpleAppMain] Loading configuration file: SonyBraviaHX800.conf
INFO  2012-11-19 18:19:38.824 [WrapperSimpleAppMain] Loading configuration file: Streamium.conf
INFO  2012-11-19 18:19:38.824 [WrapperSimpleAppMain] Loading configuration file: WDTVLive.conf
INFO  2012-11-19 18:19:38.840 [WrapperSimpleAppMain] Loading configuration file: WMP.conf
INFO  2012-11-19 18:19:38.856 [WrapperSimpleAppMain] Loading configuration file: XBMC.conf
INFO  2012-11-19 18:19:38.856 [WrapperSimpleAppMain] Loading configuration file: XBOX360.conf
INFO  2012-11-19 18:19:38.856 [WrapperSimpleAppMain] Loading configuration file: YamahaRXA1010.conf
INFO  2012-11-19 18:19:38.871 [WrapperSimpleAppMain] Loading configuration file: YamahaRXV671.conf
INFO  2012-11-19 18:19:38.871 [WrapperSimpleAppMain] Checking MPlayer font cache. It can take a minute or so.
DEBUG 2012-11-19 18:19:38.871 [WrapperSimpleAppMain] launching: win32/mplayer.exe
DEBUG 2012-11-19 18:19:40.986 [WrapperSimpleAppMain] launching: win32/mplayer.exe
INFO  2012-11-19 18:19:41.096 [WrapperSimpleAppMain] Done!
INFO  2012-11-19 18:19:41.096 [WrapperSimpleAppMain] Found VideoLAN version 1.1.5 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-11-19 18:19:41.158 [WrapperSimpleAppMain] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2012-11-19 18:19:41.346 [WrapperSimpleAppMain] Found plugin: net.sharkhunter.gmusic.Gm_plugin
INFO  2012-11-19 18:19:41.346 [WrapperSimpleAppMain] Found plugin: net.pms.movieinfo.MovieInfo
INFO  2012-11-19 18:19:41.346 [WrapperSimpleAppMain] Found plugin: com.chocolatey.pmsencoder.Plugin
INFO  2012-11-19 18:19:41.377 [WrapperSimpleAppMain] Found plugin: com.sharkhunter.channel.CH_plugin
INFO  2012-11-19 18:19:41.439 [WrapperSimpleAppMain] PMSEncoder: initializing PMSEncoder 1.6.2
INFO  2012-11-19 18:19:41.595 [WrapperSimpleAppMain] PMSEncoder: script directory: C:\Program Files (x86)\Universal Media Server\scripts
INFO  2012-11-19 18:19:41.595 [WrapperSimpleAppMain] PMSEncoder: log directory: C:\Program Files (x86)\Universal Media Server
INFO  2012-11-19 18:19:41.595 [WrapperSimpleAppMain] PMSEncoder: loading built-in log4j config file: jar:file:/C:/Program%20Files%20(x86)/Universal%20Media%20Server/plugins/pmsencoder-1.6.2.jar!/log4j_default.xml
INFO  2012-11-19 18:19:44.871 [WrapperSimpleAppMain] Registering transcoding engine: PMSEncoder
INFO  2012-11-19 18:19:44.871 [WrapperSimpleAppMain] PMSEncoder: checking engine list: [pmsencoder, mencoder, ffmpegaudio, mplayeraudio, tsmuxeraudio, ffmpegwebvideo, vlcvideo, mencoderwebvideo, mplayervideodump, mplayerwebaudio, vlcaudio, ffmpegdvrmsremux, rawthumbs]
INFO  2012-11-19 18:19:44.871 [WrapperSimpleAppMain] PMSEncoder: already enabled
INFO  2012-11-19 18:19:44.871 [WrapperSimpleAppMain] Registering transcoding engine: AviSynth/FFmpeg
INFO  2012-11-19 18:19:44.887 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg Audio
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: MEncoder
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: AviSynth/MEncoder
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: MPlayer Audio
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg Web Video
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: MEncoder Web
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: MPlayer Video Dump
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: MPlayer Web
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: tsMuxeR
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: Audio High Fidelity
DEBUG 2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Found VLC version 1.1.5 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: VLC Audio Streaming
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: VLC Video Streaming
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2012-11-19 18:19:44.902 [WrapperSimpleAppMain] Registering transcoding engine: dcraw Thumbnailer
INFO  2012-11-19 18:19:44.934 [WrapperSimpleAppMain] GoogleMusic plugin missing credentials
INFO  2012-11-19 18:19:44.980 [WrapperSimpleAppMain] Start channel 2.05
INFO  2012-11-19 18:19:45.105 [WrapperSimpleAppMain] Configuration saved to: C:\ProgramData\UMS\UMS.conf
INFO  2012-11-19 18:19:45.246 [WrapperSimpleAppMain] Using address /192.168.31.100 found on network interface: name:eth3 (Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20))
INFO  2012-11-19 18:19:45.246 [WrapperSimpleAppMain] Created socket: /192.168.31.100:5001
INFO  2012-11-19 18:19:45.495 [WrapperSimpleAppMain] Checking shared folder: D:\Movie-D-drive
INFO  2012-11-19 18:19:45.495 [WrapperSimpleAppMain] Checking shared folder: F:\Movie-F-drive
INFO  2012-11-19 18:19:45.495 [WrapperSimpleAppMain] Checking shared folder: M:\Movie-M-drive
INFO  2012-11-19 18:19:45.495 [WrapperSimpleAppMain] Checking shared folder: F:\Music
ERROR 2012-11-19 18:19:45.620 [WrapperSimpleAppMain] Attempt to add a null child to root
java.lang.NullPointerException: Invalid DLNA resource
	at net.pms.dlna.DLNAResource.addChild(DLNAResource.java:450) [ums.jar:na]
	at net.pms.dlna.RootFolder.discoverChildren(RootFolder.java:148) [ums.jar:na]
	at net.pms.configuration.RendererConfiguration.getRootFolder(RendererConfiguration.java:198) [ums.jar:na]
	at net.pms.PMS.getRootFolder(PMS.java:110) [ums.jar:na]
	at net.pms.PMS.init(PMS.java:510) [ums.jar:na]
	at net.pms.PMS.createInstance(PMS.java:858) [ums.jar:na]
	at net.pms.PMS.main(PMS.java:933) [ums.jar:na]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.7.0_02]
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.7.0_02]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.7.0_02]
	at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.7.0_02]
	at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:290) [wrapper.jar:3.5.15]
	at java.lang.Thread.run(Unknown Source) [na:1.7.0_02]
DEBUG 2012-11-19 18:19:45.682 [WrapperSimpleAppMain] Sending ALIVE...
INFO  2012-11-19 18:19:45.729 [WrapperSimpleAppMain] Using the following UUID configured in UMS.conf: ebbb7981-ccd8-3252-ad23-83e32f84c363
INFO  2012-11-19 18:19:48.378 [New I/O server worker #1-1] No IP filter specified, access granted to /192.168.31.102
INFO  2012-11-19 18:19:48.407 [pool-7-thread-1] Checking IP: 192.168.31.102 for Philips TV
INFO  2012-11-19 18:19:51.208 [WrapperSimpleAppMain] The server should now appear on your renderer
INFO  2012-11-19 18:19:53.376 [pool-7-thread-1] Renderer Philips TV found on this address: 192.168.31.102
DEBUG 2012-11-19 18:19:53.392 [pool-7-thread-1] Starting ping -n 3 -l 64000 192.168.31.102
DEBUG 2012-11-19 18:19:55.404 [SpeedStats Failsafe] Stopping process: ping-0
INFO  2012-11-19 18:19:59.944 [New I/O server worker #1-4] Checking shared folder: D:\Movie-D-drive
INFO  2012-11-19 18:19:59.944 [New I/O server worker #1-4] Checking shared folder: F:\Movie-F-drive
INFO  2012-11-19 18:19:59.944 [New I/O server worker #1-4] Checking shared folder: M:\Movie-M-drive
INFO  2012-11-19 18:19:59.944 [New I/O server worker #1-4] Checking shared folder: F:\Music
ERROR 2012-11-19 18:19:59.944 [New I/O server worker #1-4] Attempt to add a null child to root
	at net.pms.network.RequestV2.answer(RequestV2.java:628) [ums.jar:na]
	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:299) [ums.jar:na]
	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:257) [ums.jar:na]
	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:80) [ums.jar:na]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [ums.jar:na]
	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:783) [ums.jar:na]
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:149) [ums.jar:na]
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) [ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) [ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndFireMessageReceived(ReplayingDecoder.java:527) [ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) [ums.jar:na]
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) [ums.jar:na]
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) [ums.jar:na]
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) [ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:351) [ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:282) [ums.jar:na]
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:202) [ums.jar:na]
	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [ums.jar:na]
	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:44) [ums.jar:na]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_02]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_02]
INFO  2012-11-19 18:19:59.944 [New I/O server worker #1-4] Node(com.sharkhunter.channel.Channels) already has an ID=0$6, which is overriden now. The previous parent node was:RootFolder[[MapFile [name=Movie-D-drive, id=0$1, format=null, children=[]], MapFile [name=Movie-F-drive, id=0$2, format=null, children=[]], MapFile [name=Movie-M-drive, id=0$3, format=null, children=[]], MapFile [name=Music, id=0$4, format=null, children=[]], VirtualFolder [id=5, name=Web, full path=0$5, ext=null, discovered=false]]]
DEBUG 2012-11-19 18:20:01.223 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-19 18:20:05.728 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Bad.Ass(2012).srt is WINDOWS-1252.
DEBUG 2012-11-19 18:20:06.197 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Bad.Ass(2012).srt is WINDOWS-1252.
DEBUG 2012-11-19 18:20:08.023 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Re-animator(1985).srt is WINDOWS-1252.
DEBUG 2012-11-19 18:20:08.210 [New I/O server worker #1-6] Detected encoding for D:\Movie-D-drive\Re-animator(1985).srt is WINDOWS-1252.
DEBUG 2012-11-19 18:20:21.610 [New I/O server worker #1-4] Could not parse year "utc 2011-02-25 07:00:00"
DEBUG 2012-11-19 18:20:23.045 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Kamui-cd1.sub.
DEBUG 2012-11-19 18:20:23.373 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Kamui-cd2.sub.
DEBUG 2012-11-19 18:20:26.165 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-19 18:20:31.201 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Thunderbolt(1995)-cd1.sub.
DEBUG 2012-11-19 18:20:31.544 [New I/O server worker #1-4] No encoding detected for M:\Movie-M-drive\Action\Thunderbolt(1995)-cd2.sub.
DEBUG 2012-11-19 18:20:37.800 [pool-19-thread-2] Duplicate Against.The.Dark.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.800 [pool-19-thread-3] Duplicate Angel.And.The.Badman.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.800 [pool-19-thread-1] Duplicate A.Dangerous.Man.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.831 [pool-19-thread-1] Duplicate Bad.Boys.mp4 for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.831 [pool-19-thread-2] Duplicate Armored.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.831 [pool-19-thread-3] Duplicate Bad.Boys.II.mp4 for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.831 [pool-19-thread-1] Duplicate Blade.II(2002).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.831 [pool-19-thread-3] Duplicate Blade.Trinity(2004).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.831 [pool-19-thread-2] Duplicate Born.To.Raise.Hell(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.831 [pool-19-thread-3] Duplicate Bunraku(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.831 [pool-19-thread-2] Duplicate Cash.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-2] Duplicate Chocolate.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-3] Duplicate Crank.2.Hi.Voltage(2009).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-2] Duplicate City.Hunter.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-1] Duplicate Casino.Royale(2006).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-1] Duplicate Death.Race.cd1.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-2] Duplicate Dragon.Eyes(2012).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-3] Duplicate Eraser.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-3] Duplicate Fast.Five(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-2] Duplicate Fire.of.conscience.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-2] Duplicate G.I.Joe.The.Rise.Of.Cobra.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-3] Duplicate Game.Of.Death(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.846 [pool-19-thread-2] Duplicate Hellbinders.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Iron.Man(2008).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Kamui-cd1.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Kamui-cd2.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-1] Duplicate Death.Race.cd2.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Les.Formidables.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-1] Duplicate Limitless(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Mission.Impossible.1(1996).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-1] Duplicate Mission.Impossible.2(2000).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Mission.Impossible.3(2006).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Mission.Impossible.4.Ghost.Protocol(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-1] Duplicate My.Wife.Is.A.Gangster.3.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-1] Duplicate Nude.Nuns.with.Big.Guns(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Ocean's 11.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Ocean's 12.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Operation.Condor.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-1] Duplicate Ocean's.13.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Paintball.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-1] Duplicate Priest(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-1] Duplicate Project.A.2(1987).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Quantum.of.Solace(2008).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Project.A(1983).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Rampage.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Real.Steel(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Recoil(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Repo.Men.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Rush.Hour.1.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Rush.Hour.2.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-3] Duplicate Rush.Hour.3.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.862 [pool-19-thread-2] Duplicate Salt.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate Shoot.Em.Up.Wide.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate Smokin.Aces.2.Assassins.Ball.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate Snatch.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate Sniper(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate Special.Forces(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate Steve.McQueen.Bullit.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate Steve.McQueen.The.Cincinnati.Kid.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate Steve.McQueen.The.Getaway.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate The.Bank.Job.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate The.Burma.Conspiracy(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-1] Duplicate The.Italian.Job.1969.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate The.Expendables(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-1] Duplicate The.Italian.Job.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate The.Keeper.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate The.Mechanic(1972).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-1] Duplicate The.Mechanic(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate The.Mechanik.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate The.Outlaw.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate The.Phanton.CD1.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate The.Phanton.CD2.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate The.Shepherd.Border.Patrol.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate The.Spy.Next.Door.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate The.Tournament.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate The.Warriors.Way(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-1] Duplicate Thunderbolt(1995)-cd1.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate Thunderbolt(1995)-cd2.avi for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-1] Duplicate Tower.Heist(2011).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate Undisputed.III-Redemption.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-1] Duplicate Universal.Soldier.Regeneration.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-2] Duplicate Unstoppable(2010).mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-1] Duplicate Wedlock.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-1] Duplicate xXx.mkv for direct streaming to renderer: Philips TV
DEBUG 2012-11-19 18:20:37.878 [pool-19-thread-3] Duplicate xXx.State.Of.The.Union.mkv for direct streaming to renderer: Philips TV
INFO  2012-11-19 18:21:13.820 [New I/O server worker #1-8] Starting transcode/remux of Quantum.of.Solace(2008).mkv
DEBUG 2012-11-19 18:21:13.929 [New I/O server worker #1-8] Creating pipe \\.\pipe\mencoder1353345673929
DEBUG 2012-11-19 18:21:13.960 [Thread-16] Waiting for pipe connection \\.\pipe\mencoder1353345673929
DEBUG 2012-11-19 18:21:14.023 [mencoder.exe-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe" -ss 0 M:\Movie-M-drive\Action\Quantum.of.Solace(2008).mkv -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 6 -lavdopts debug=0:threads=4 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=4:keyint=5:vqscale=1:vqmin=1:vrc_maxrate=36000:vrc_buf_size=7000 -ass -ass-color ffffff00 -ass-border-color 00000000 -ass-font-scale 1.4 -font C:\Windows\Fonts\Arial.ttf -ass-force-style FontName=C:\Windows\Fonts\Arial.ttf,Outline=1,Shadow=1,MarginV=10 -fontconfig -sid 0 -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o \\.\pipe\mencoder1353345673929
DEBUG 2012-11-19 18:21:14.694 [mencoder.exe-1] Reading pipe: \\.\pipe\mencoder1353345673929
DEBUG 2012-11-19 18:21:14.694 [mencoder.exe-1] Attaching thread: mencoder.exe-1
DEBUG 2012-11-19 18:21:15.333 [Thread-20] MEncoder SB37 (C) 2000-2012 MPlayer Team
DEBUG 2012-11-19 18:21:15.333 [Thread-20] Custom build by SubJunk, http://www.spirton.com
DEBUG 2012-11-19 18:21:15.349 [Thread-20] success: format: 0  data: 0x0 - 0x4997a96f
DEBUG 2012-11-19 18:21:15.349 [Thread-20] libavformat version 54.25.104 (internal)
DEBUG 2012-11-19 18:21:15.349 [Thread-20] libavformat file format detected.
DEBUG 2012-11-19 18:21:15.364 [Thread-20] [lavf] stream 0: video (h264), -vid 0
DEBUG 2012-11-19 18:21:15.364 [Thread-20] [lavf] stream 1: audio (aac), -aid 0, -alang eng
DEBUG 2012-11-19 18:21:15.364 [Thread-20] [lavf] stream 2: subtitle (subrip), -sid 0, -slang nld
DEBUG 2012-11-19 18:21:15.364 [Thread-20] VIDEO:  [H264]  1920x800  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
DEBUG 2012-11-19 18:21:15.364 [Thread-20] [V] filefmt:44  fourcc:0x34363248  size:1920x800  fps:23.976  ftime:=0.0417
DEBUG 2012-11-19 18:21:15.364 [Thread-20] ==========================================================================
DEBUG 2012-11-19 18:21:15.364 [Thread-20] Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
DEBUG 2012-11-19 18:21:15.364 [Thread-20] libavcodec version 54.55.100 (internal)
DEBUG 2012-11-19 18:21:15.364 [Thread-20] AUDIO: 48000 Hz, 2 ch, s16le, 0.0 kbit/0.00% (ratio: 0->192000)
DEBUG 2012-11-19 18:21:15.364 [Thread-20] Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
DEBUG 2012-11-19 18:21:15.364 [Thread-16] Result of \\.\pipe\mencoder1353345673929 : true
DEBUG 2012-11-19 18:21:15.364 [Thread-20] PACKET SIZE: 2048 bytes, deltascr: 884
DEBUG 2012-11-19 18:21:15.364 [Thread-20] Opening video filter: [ass auto=1]
DEBUG 2012-11-19 18:21:15.364 [Thread-20] [ass] auto-open
DEBUG 2012-11-19 18:21:15.393 [Thread-20] ==========================================================================
DEBUG 2012-11-19 18:21:15.395 [Thread-20] Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
DEBUG 2012-11-19 18:21:15.397 [Thread-20] Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
DEBUG 2012-11-19 18:21:15.397 [Thread-20] ==========================================================================
DEBUG 2012-11-19 18:21:15.397 [Thread-19] [ac3 @ 0113c280]channel_layout not specified
DEBUG 2012-11-19 18:21:15.398 [Thread-19] [ac3 @ 0113c280]No channel layout specified. The encoder will guess the layout, but it might be incorrect.
DEBUG 2012-11-19 18:21:15.398 [Thread-19] Limiting audio preload to 0.4s.
DEBUG 2012-11-19 18:21:15.398 [Thread-19] Increasing audio density to 4.
DEBUG 2012-11-19 18:21:15.401 [Thread-19] Unsupported PixelFormat 61
DEBUG 2012-11-19 18:21:15.401 [Thread-19] Unsupported PixelFormat 53
DEBUG 2012-11-19 18:21:15.401 [Thread-19] Unsupported PixelFormat 81
DEBUG 2012-11-19 18:21:15.426 [Thread-20] Movie-Aspect is 2.40:1 - prescaling to correct movie aspect.
DEBUG 2012-11-19 18:21:15.426 [Thread-20] videocodec: libavcodec (1920x800 fourcc=3267706d [mpg2])
DEBUG 2012-11-19 18:21:15.426 [Thread-20] [VE_LAVC] Using constant qscale = 1.000000 (VBR).
DEBUG 2012-11-19 18:21:15.479 [Thread-20] Writing header...
DEBUG 2012-11-19 18:21:15.479 [Thread-20] INITV: 0.200, 0.158, fps: 23.976
DEBUG 2012-11-19 18:21:15.480 [Thread-20]
INFO  2012-11-19 18:21:20.135 [StartPlaying Event] renderer: 192.168.31.102, file: M:\Movie-M-drive\Action\Quantum.of.Solace(2008).mkv
DEBUG 2012-11-19 18:21:48.538 [New I/O server worker #1-2] Setting margin to 2Mb
DEBUG 2012-11-19 18:22:19.986 [Thread-19] [ass] PlayResX undefined, setting to 384
DEBUG 2012-11-19 18:23:29.484 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-11-19 18:24:20.614 [Buffered IO End Checker] Stopping process: mencoder.exe-1
INFO  2012-11-19 18:24:22.114 [StopPlaying Event] renderer: 192.168.31.102, file: M:\Movie-M-drive\Action\Quantum.of.Solace(2008).mkv
INFO  2012-11-19 18:24:48.416 [PMS Listeners Stopper] Sending BYEBYE...
DEBUG 2012-11-19 18:24:48.416 [UPNP-AliveMessageSender] Error while sending periodic alive message: sleep interrupted
DEBUG 2012-11-19 18:24:52.414 [PMS Listeners Stopper] Forcing shutdown of all active processes
INFO  2012-11-19 18:24:52.414 [PMS Listeners Stopper] Stopping server on host 192.168.31.100 and port 5001...
