Dutch language update
leroy
Post by leroy »
Hi, first post on this forum.
Hereby an update for the Dutch translation, according the latest messages.properties
I do like the new GUI, but Unfortunately there is some text overlap in the mencoder tab, because of the long translated text.
messages_nl.zip
(6.47 KiB) Downloaded 825 times
SharkHunter
Re: Dutch language update
Post by SharkHunter »
Gr8 work. I'll add this to the git. You could (if it ain't that much work of course) do this via pull requests on github.
Edit. Added to code base
Thanks a lot, leroy!
leroy
Post by leroy »
Improved Dutch translation, according the latest messages.properties
messages_nl.zip
(7.32 KiB) Downloaded 1002 times
Thanks a lot, this will be in the next version :)
leroy
Post by leroy »
I managed to remove the slide bars, because of shorter translation and by moving some discription in tooltips.
As noted some extra spaces were needed to prevent overlap in the "Hide advanced options" mode.
Oh, and by the way, the tooltips is a great feature for a clear and organized GUI where in my opinion more settings should be added.
Keep up the great work with this awesome software.
messages_nl.zip
(8.58 KiB) Downloaded 1072 times
Thanks a lot, leroy. It will be in the next version :)
leroy
Post by leroy »
Improved Dutch translation.
messages_nl.zip
(8.61 KiB) Downloaded 929 times
leroy
Post by leroy »
Updated Duch translation, according the latest messages.properties
messages_nl.zip
(8.85 KiB) Downloaded 997 times
Thanks for this, it will be in the next release :)
