PS4 can't connect.
PS4 can't connect.
I was using UMS fine a few weeks ago on my PS4, however I've just tried it today and my PS4 can't see UMS, and vice versa. I decided to try PS3 Media Server on a whim and my PS3 picked it up straight away, unfortunately none of the media would play. Can anyone help?
Re: PS4 can't connect.
I included my log this time, whatever good that will do. It's almost identical to the PMS log, except it doesn't find a renderer.
- (23.51 KiB) Downloaded 541 times
Same problem here, did you find any solution?
sadly this doesn't seem to be the place to find answers in regards to UMS and Ps
Same Problem...
I bought a PS4 today. Ist connected like the PS3 (That works fine).
UMS dont find it, PS4 dont find UMS...
I´m crying, cauze i use it daily...
