Version 2.1.1 is released
General:
This release fixes the startup bug some Windows users were experiencing.
Changes since 2.1.0:
  • General:
    • Fixed a bug preventing UMS from starting
    • Improved Plugin Management page design
    • Minor language update
Upgrade Notes:
For versions prior to 1.5.0:
It is recommended to delete your UMS.conf file prior to installing this version. For Windows users it is in ProgramData/UMS/.
For all versions:
glebb for building UMS for OS X
gottoast
Re: Version 2.1.1 is released
Post by gottoast »
BINGO! None of the install issues I encountered with 2.0 or mentioned in the 2.1.1 temporary post! Cleanest install so far... lets see the rest goes. THANK YOU :-)
Thanks, gottoast :)
squadjot
Post by squadjot »
Is "Pack debug files" supposed to work.. hasnt been working lately.. (incomplete archive)
Another question, is jawaw.exe suppose to hang for minutes after PMS shuts down? (this often results in renders not being able to connect/see, when i start PMS up again)..
squadjot wrote:Is "Pack debug files" supposed to work.. hasnt been working lately.. (incomplete archive)
Works for me.
squadjot wrote:Another question, is jawaw.exe suppose to hang for minutes after PMS shuts down? (this often results in renders not being able to connect/see, when i start PMS up again)..
I don't know about PMS, but I just tested it with UMS and it shut down almost instantly
squadjot
Post by squadjot »
Sorry meant UMS.. =)
Made a post here: viewtopic.php?f=9&t=384
Madoka
Post by Madoka »
That was like calling your current girlfriend by your ex-girlfriend's name. :)
lol!
gottoast
Post by gottoast »
I still get this ffmpeg error almost every time I try to view something;
ffmpeg.exe has a return code of 1! Maybe an error occured...
And the folders on the PS3 screen act funny once the folder limit is hit and folder limit folder is used.
Can you please have a look at the logs and see if you can make out anything? I'm at a loss.
**EDIT**
Forgot to set to TRACE, reuploaded.
I try to give support in the support category, not the announcements one :) Please make a thread there
