[Solved] Samsung 48" UE48JU6400W cannot show subtitles
While trying to see what is wrong i opened the samsung no.tv conf. file and the it was changed with a conf file of my model. However while the first conf file has many settings, the second does not. I am not sure if this is any relevant.
Anyway i am stuck and i could really use your help! I use UMS Version 5.2.2.
I am attaching the debug log for extra info.
Re: Samsung 48" UE48JU6400W cannot show subtitles
I had the same problem: viewtopic.php?f=9&t=3874
Try this:
In the .conf change/add following
Try this:
1. Add
UseClosedCaption = true
2. Change
Supported = f:avi|mkv m:video/x-matroska
I am sorry but i am not so knowledgeable about all this, so may i ask how to change the .conf ? And which .conf do you mean and how to find it?
In fact i had seen your topic and the solutions, before i post my own, but when i accordingly tried to modify the conf file of the tv (Samsung-NotCD.conf), access was denied.
Ok, i edited your .conf
Hope it works, It's far from perfect, the transcoding part still doesent work.
You must replace the existing .conf ..it should be located in "C:\ProgramData\UMS\renderers" <--
Many thanks man, i believe it's working now!
If something else shows up, i''ll get back here, but most files i tested seem to play well with subtitles on!
Thanks again and keep up the good work all of you!
This is going into the next release, good work guys
Re: [Solved] Samsung 48" UE48JU6400W cannot show subtitles
I am still unclear on how do i find Samsung-NotCD.conf and make recommended changes.
can someone please give me step by step details on the TV itself of picture guide on how to resolve this symptom.
would really appreciate the help
thank in advance
thank in advance
Conf files should be worked server side (not at the TV). You may follow the guidelines in here http://www.universalmediaserver.com/faq ... erSupport1gazi099 wrote:I am still unclear on how do i find Samsung-NotCD.conf and make recommended changes.
thank in advance
