Version 5.2.3 is released
Post by SubJunk » Tue Sep 29, 2015 9:09 pm
General:
This release improves Windows 10 support, playback stability, support for TVs, translations, fixes bugs and more!
Important note: This is the last time we will release a version of UMS for Java 6. We will continue to release builds for Java 7 and Java 8.
Changes since 5.2.2:
  • General:
    • Improved logging and logging options
    • Improved language translations
    • Improved Windows 10 support
    • Improved playback stability
    • Changed default thumbnail seeking position from 2 seconds to 4 seconds
    • Minor status tab updates
    • Fixed the web interface Flash player
    • Fixed many bugs
  • Renderers:
    • Improved detection of AirPlayer
    • Improved folder population time on Panasonic TVs
    • Improved support for Samsung TVs
    • Improved support for Vizio TVs
  • Languages:
    • Improved accuracy of automatic subtitles language detection
    • Updated many languages based on contributions from Crowdin
  • External Components:
    • Updated AssertJ to 2.2.0
    • Updated h2database to 1.4.189
    • Updated FFmpeg for Windows
    • Updated Javassist to 3.20.0-GA
    • Updated jmustache to 1.10
    • Updated JNA to 4.2.0
    • Updated maven-antrun-plugin to 1.7
    • Updated Plexus-utils to 3.0.22
    • Updated Seamless to 1.1.1
Wolfgan
Re: Version 5.2.3 is released
Post by Wolfgan » Wed Sep 30, 2015 2:23 am
Thanks for the release! Updating it now...
goth1k
Post by goth1k » Wed Sep 30, 2015 5:27 am
I have been using version 5.2.2 and when I try to stream x265 files it cuts off every time.
Will this version fix this or is it a problem with my settings?
TIA
Forceflow
Post by Forceflow » Wed Sep 30, 2015 6:30 am
Thanks for the release! Will upgrade on both Win and Linux and report back if there are any problems.
HT1
Post by HT1 » Wed Sep 30, 2015 3:11 pm
thanks for this.
btw 5.2.2 didn't find a new version when i clicked check for new version. just fyi.
Win 10 64bits java 8
Qnap TS-212 2x3TB WD Red
Sony Bravia MN (my conf)
pipin
Post by pipin » Fri Oct 02, 2015 4:35 am
Working fine so long. Thanks.
Regards,
Jens
Panny
Post by Panny » Sat Oct 03, 2015 12:19 am
Does not start with Windows (8.1 Enterprise 64-bit) any more even though it's listed in the startup tasks. Didn't have this issue with 5.2.2. I have the Java 8 version installed.
EDIT: Clean install on Windows 10 and the auto start-up issue is resolved.
jps92
Post by jps92 » Sat Oct 03, 2015 3:04 am
It's worse that the previous version with a bravia EX (under Linux) : Loss of connection (in Wi-Fi), file which does not open. :( I go back to 5.2.2.
decadentdave
Post by decadentdave » Sun Oct 11, 2015 2:46 pm
Still no return of the Samsung Allshare renderer which has been mysteriously removed since version 5.0.1 so I have to go all the way back to that to have a working UMS again. Ffs. :evil:
Post by SubJunk » Sun Oct 11, 2015 9:03 pm
SamsungAllShare.conf was renamed to SamsungNotCD.conf a while ago, it's still there :) and if you're looking for SamsungAllShare-CD.conf, it was renamed to Samsung-CD.conf
