Playback issues with transcoded files
Aiari
Post by Aiari »
I have a weird issue when playing files on my Samsung TV (UE4848H5515AK, version 01). It is connected to my wireless network and plays supported files of all qualities without problems, but transcodes fail for some reason.
With the basic config file for the render (Samsung-NotCD.conf) any transcode stops after about a minute and just starts the next movie in the folder. I tried various settings to see if anything made a difference, but none have made
any noticeable change a part from changing the setting "ChunkedTransfer" to false in the render config. I got the movies to play almost to the end, but then got a network disconnect error from the TV. Despite the disconnect error I can
still browse the folder and start a new movie file (default behavior of the TV as far as I've been able to tell when a "true" disconnect occurs is to throw you back to the network device page).
I have attached debug files. Anyone have any idea what the issue might be?
(24.36 KiB) Downloaded 308 times
