Possible Expert Render Option?
Madoka
Post by Madoka »
I use subtitles and usually watch TV shows and movies in 16:9 ratio. I set the styled subtitle font size to 1.1. When I watch a really wide screen movie in like 2.35:1 ratio, the 1.1 size setting is a bit too small. I manually change it to 1.4 before these movies, but I was wondering if there is an expert option I can put in that says:
If picture ratio is greater than 16:9, then set styled subtitle font size to 1.4
I have no idea how to effectively use that section. Sorry.
And thanks in advance.
squadjot
Re: Possible Expert Render Option?
Post by squadjot »
have you tried:
-subfont-text-scale 3
squadjot
Post by squadjot »
So something like
(width/height > 2) :: -subfont-text-scale 2
Not sure 2 is a good value.. but the syntax should be ok.
squadjot
Post by squadjot »
Other prarms you might find useful
-subpos 100
-subwidth 100
-subalign 2
-subfont-osd-scale 4
-subfont-autoscale 2
-spuaa 20
-spualign 2
found at http://midekra.tumblr.com/post/29493057 ... h-mencoder
Madoka
Post by Madoka »
Thanks for the suggestions, but none of that worked. I'm trying to change the mencoder_ass_scale value in the UMS.conf file or something equivalent.
