Borken (beeping) sound on Sony with mencoder
Hello.
OS: Ubuntu 14.04 with some PPA,
UMS: 5.2.3
Addition options are video-related were inspired by viewtopic.php?t=1959
Mencoder were started with options:
mencoder -ss 310.0 ......avi -msglevel statusline=2 -oac lavc -of mpeg -mpegopts format=mpeg2:muxrate=500000:vbuf_size=1194:abuf_size=64 -ovc lavc -channels 2 -vf softskip,expand=::::1:16/9:2,scale=1283:720 -lavcopts aspect=16/9 -lavdopts debug=0:threads=4 -lavcopts autoaspect=1:vcodec=mpeg2video:acodec=ac3:abitrate=448:threads=4:keyint=5:vqscale=1:vqmin=2:vqmax=3:vrc_maxrate=499000:vrc_buf_size=1835 -ass -ass-color ffffff00 -ass-border-color 00000000 -ass-font-scale 1.4 -font /usr/share/fonts/truetype/msttcorefonts/Arial.ttf -ass-force-style FontName=/usr/share/fonts/truetype/msttcorefonts/Arial.ttf,Outline=1,Shadow=1,MarginV=10 -noflip-hebrew -fontconfig -subcp enca
cp1251 -nosub -sub ......srt -ofps 24000/1001 -lavdopts fast -mc 0 -noskip -af lavcresample=48000 -srate 48000 -o /tmp/.....
Output from builtin ffmpeg:
Here is some (I hope useful) info from Mplayer:
UMS: 5.2.3
$ mplayer -vo null -ao null -identify -frames 0 ...
MPlayer SVN-r37401 (C) 2000-2012 MPlayer Team
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing ....
libavformat version 56.33.101 (internal)
AVI file format detected.
ID_VIDEO_ID=0
[aviheader] Video stream found, -vid 0
ID_AUDIO_ID=1
[aviheader] Audio stream found, -aid 1
AVI: ODML: Building ODML index (2 superindexchunks).
VIDEO: [XVID] 720x304 12bpp 23.976 fps 2032.8 kbps (248.1 kbyte/s)
Clip info:
Software: VirtualDubMod 1.5.10.3 | www.virtualdub-fr.org || (build 2550/release)
ID_CLIP_INFO_NAME0=Software
ID_CLIP_INFO_VALUE0=VirtualDubMod 1.5.10.3 | www.virtualdub-fr.org || (build 2550/release)
Comments: �� �������� (MECHANICAL ENGINEER)
ID_CLIP_INFO_NAME1=Comments
ID_CLIP_INFO_VALUE1=�� �������� (MECHANICAL ENGINEER)
ID_CLIP_INFO_N=2
Load subtitles in ./
ID_FILENAME=....
ID_DEMUXER=avi
ID_VIDEO_FORMAT=XVID
ID_VIDEO_BITRATE=2032776
ID_VIDEO_WIDTH=720
ID_VIDEO_HEIGHT=304
ID_VIDEO_FPS=23.976
ID_VIDEO_ASPECT=0.0000
ID_AUDIO_FORMAT=8192
ID_AUDIO_BITRATE=448000
ID_AUDIO_RATE=0
ID_AUDIO_NCH=0
ID_START_TIME=0.00
ID_LENGTH=9677.96
ID_SEEKABLE=1
ID_CHAPTERS=0
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
libavcodec version 56.39.101 (internal)
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
ID_VIDEO_CODEC=ffodivx
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 2 ch, floatle, 448.0 kbit/14.58% (ratio: 56000->384000)
ID_AUDIO_RATE=48000
ID_AUDIO_NCH=2
Selected audio codec: [ffac3] afm: ffmpeg (FFmpeg AC-3)
AO: [null] 48000Hz 2ch floatle (4 bytes per sample)
ID_AUDIO_CODEC=ffac3
Starting playback...
Exiting... (End of file)
ID_EXIT=EOF
- (81.36 KiB) Downloaded 320 times
