French does not work since update 5.2
Hello everyone,
I need your help, since update 5.2 when I want to wacth french (yep I'm french) videos it does not work. I have to use version 5.1.4.
I don't know if iy comes from my computer or my PS3 but with the same UMS configuration it does not work, on the screen I can read the support is not supported or something like that.
Thank for your help
Thank for your help
Re: French does not work since update 5.2
Find here the log file:
- (33.39 KiB) Downloaded 309 times
