Subtitles wont show (mkv - external srt)
SaileNav
Post by SaileNav »
UMS version: 2.2.6
TV: Samsung ue46d5000 (allshare)
OS: Mac OS X 10.8.2
I tried to play an mp4 with an external srt file and everything worked fine,
but when I tried play to play an mkv file with an external srt file, the external subtitles won't show on the TV. However the TV shows the following title when playing the mkv file "<filename>{External Subtitles}"
Can you help me?
(10.47 KiB) Downloaded 850 times
ual
Re: Subtitles wont show (mkv - external srt)
Post by ual »
2.2.6 doesn't display subs with mkv files for me either. The titles are listed as having {External Subtitles} but they don't display. It may have reverted to not displaying them only if the mkv has embedded subs (as all of mine do ... I'm waiting for that golden hour when UMS will display the embedded subs so I don't need a bunch of extra srt files laying about, but ...) I haven't tested it on a file without embedded subs, yet.
[UPDATE] If the mkv file has an embedded sub, the external subs don't display. The subs do display if the mkv doesn't have an embedded sub.
OS X 10.8.2
SaileNav
Post by SaileNav »
Thanks for the update, I will have to strip the mkv's of their subs. That should not be so hard with mkvtoolnix.
ual
Post by ual »
Ahhh, I'm going to look at alternatives to UMS. These kinds of regressive bugs are not a good sign that devs are in control of their code.
After some investigation I've found that this isn't a new bug, it has been around for 3+ years in PMS, it just didn't show itself until the default settings were changed.
You can go back to the previous behaviour by going to the MEncoder settings page on the Transcoding Settings tab, and clearing the "audio/subtitles language priority" input box. By default it is *,* but it used to be blank.
ExSport
Post by ExSport »
Do you read my posts SubJunk? It seems not ;)
viewtopic.php?f=9&t=488&p=2586#p2611
ExSport wrote:Do you read my posts SubJunk? It seems not ;)
Yeah I read it but the bug was something different.
ExSport
Post by ExSport »
Ok, maybe I didn't read post carefully so understood it in wrong manner 8-)
But it will be good to fix default settings "*,*" to something else because it will broke all the separate audio or subs settings.
UMS will always take anything due to *,* instead of audio or subs preference set.
I never spotted it because I never used empty audio/sub preference :mrgreen:
What do you think would be a better default value?
ExSport
Post by ExSport »
UmsLang,off? 8-)
Better than *,* but not ideal. I am from Czech but using Ums GUI in Eng :-)
The best way would be ignoring aud/sub and its default *,* when separate aud,sub is set so it will not override it.
But when aud/sub will be defined so it will not be *,*, it will override separate aud and sub settings :idea:
