Version 5.3.0 videos crash renderer
This is the same problem reported here & in the OS X forum before but with more testing and logs.
Also I will duplicate this with the full logs and title information in the OS X forum.
It seems to be data related in that some (13) videos out of 240, all Blu-ray, cause the TV to Crash/Reset about 5 seconds into the play.
Problem Titles & UPC's:
I have tried many combinations to extract multiple discs with multiple versions of MakeMKV, serving with multiple UMS versions. All show the same behavior: video starts to load, spinning circle, 5 sec later the TV goes black, audio pops and it looks like it reboots.
*** Is it possible to log the all data being sent to the renderer?
This is the crash event at 12:35:11:and the TV goes black.
This is a snippet from the full log showing a lot before and a bit around the crash event:
# UPC Title
# 043396160972 Tears Of The Sun.mkv
# 031398206972 Crank.mkv
# 085391117292 Departed.mkv
# 031398134848 No Country For Old Men.mkv
# 031398221890 3|10 To Yuma.mkv
# 043396185197 Ghost Rider.mkv
# 043396191723 Hellboy.mkv
# 043396163362 Casino Royale.mkv
# Harry Potter/
# 085391156987 Part 1 The Sorcerer's Stone.mkv
# 085391184720 Part 2 The Chamber Of Secrets.mkv
# 085391156970 Part 3 The Prisoner Of Azkaban.mkv
# 085391156925 Part 4 The Goblet Of Fire.mkv
# 085391156949 Part 5 The Order Of The Phoenix.mkv
DEBUG 2015-11-13 12:35:07.039 [New I/O worker #16] Connection error: java.io.IOException: Connection reset by peer
DEBUG 2015-11-13 12:35:07.039 [New I/O worker #16] Premature end, stopping...
DEBUG 2015-11-13 12:35:11.042 [StopPlaying Event] Matched media renderer "TV-55C8000" based on address /10.0.1.89
INFO 2015-11-13 12:35:11.042 [StopPlaying Event] Stopped playing Tears Of The Sun.mkv on your TV-55C8000
DEBUG 2015-11-13 12:35:11.043 [StopPlaying Event] The full filename of which is: /Users/umsmkv/aML/Video/Index/@Crash/Tears Of The Sun.mkv and the address of the renderer is: 10.0.1.89
DEBUG 2015-11-13 12:35:11.043 [StopPlaying Event] Reading resume: false (default: true)
TRACE 2015-11-13 12:35:00.868 [New I/O worker #7] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2015-11-13 12:35:00.868 [New I/O worker #7] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:00.869 [New I/O worker #7] Sent to socket: Content-Length: 448
TRACE 2015-11-13 12:35:00.871 [New I/O worker #8] Opened request handler on socket /10.0.1.89:38086
TRACE 2015-11-13 12:35:00.871 [New I/O worker #8] Request: HTTP/1.0 : POST : upnp/control/content_directory
DEBUG 2015-11-13 12:35:00.871 [New I/O worker #8] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:00.872 [New I/O worker #8] Received on socket: HOST: 10.0.1.50:5001
TRACE 2015-11-13 12:35:00.872 [New I/O worker #8] Received on socket: CONTENT-LENGTH: 415
TRACE 2015-11-13 12:35:00.872 [New I/O worker #8] Received on socket: CONTENT-TYPE: text/xml;charset="utf-8"
TRACE 2015-11-13 12:35:00.872 [New I/O worker #8] Received on socket: USER-AGENT: DLNADOC/1.50
TRACE 2015-11-13 12:35:00.872 [New I/O worker #8] Received on socket: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
TRACE 2015-11-13 12:35:00.872 [New I/O worker #8] HTTP User-Agent: DLNADOC/1.50
TRACE 2015-11-13 12:35:00.872 [New I/O worker #8] Recognized media renderer: TV-55C8000
TRACE 2015-11-13 12:35:00.872 [New I/O worker #8] HTTP: upnp/control/content_directory / 0-0
TRACE 2015-11-13 12:35:00.895 [New I/O worker #8] Matched format MKV to "/Users/umsmkv/aML/Video/Index/@Crash/Tears Of The Sun.mkv"
DEBUG 2015-11-13 12:35:01.084 [New I/O worker #8] Reading PrependTrackNumbers: true (default: false)
TRACE 2015-11-13 12:35:01.089 [New I/O worker #8] Parsing results for file "Tears Of The Sun.mkv": container: mkv, bitrate: 21411469, size: 19418232298, video tracks: 1, audio tracks: 2, subtitle tracks: 3, video codec: mpeg2, duration: 02:00:55.00, width: 1920, height: 1080, frame rate: 23.976, mime type: video/x-matroska, attached fonts: false
Audio track id: 0, lang: en, audio track title from metadata: Surround 5.1, audio codec: AC3, sample frequency:48000, number of channels: 6, bits per sample: 16
Audio track id: 1, lang: en, audio track title from metadata: Surround 5.1, audio codec: lpcm, sample frequency:48000, number of channels: 6, bits per sample: 16
Subtitle track id: 0, type: PGS, lang: en
Subtitle track id: 1, type: PGS, lang: en
Subtitle track id: 2, type: PGS, lang: en
TRACE 2015-11-13 12:35:01.090 [New I/O worker #8] Adding new child "Tears Of The Sun.mkv" with class "net.pms.dlna.RealFile"
DEBUG 2015-11-13 12:35:01.090 [New I/O worker #8] Reading disable_transcode_for_extensions: "mkv" (default: "")
TRACE 2015-11-13 12:35:01.090 [New I/O worker #8] File "Tears Of The Sun.mkv" will be forced to skip transcoding by configuration
TRACE 2015-11-13 12:35:01.090 [New I/O worker #8] Getting player for resource "Tears Of The Sun.mkv"
TRACE 2015-11-13 12:35:01.091 [New I/O worker #8] Returning compatible player "FFmpeg"
TRACE 2015-11-13 12:35:01.092 [New I/O worker #8] Looking for an audio track with lang: eng
TRACE 2015-11-13 12:35:01.097 [New I/O worker #8] Matched audio track: id: 0, lang: en, audio track title from metadata: Surround 5.1, audio codec: AC3, sample frequency:48000, number of channels: 6, bits per sample: 16
TRACE 2015-11-13 12:35:01.097 [New I/O worker #8] Searching for a match for: en with eng and off
TRACE 2015-11-13 12:35:01.097 [New I/O worker #8] Disabled the subtitles: id: 0, type: UNKNOWN, lang: off
TRACE 2015-11-13 12:35:01.098 [New I/O worker #8] Matched support line f:avi|mkv m:video/avi
DEBUG 2015-11-13 12:35:01.098 [New I/O worker #8] Reading MaxVideoBitrateMbps: "120" (default: "0")
TRACE 2015-11-13 12:35:01.098 [New I/O worker #8] Final verdict: "Tears Of The Sun.mkv" will be streamed
TRACE 2015-11-13 12:35:01.098 [New I/O worker #8] File "Tears Of The Sun.mkv" will be sent with MIME type "video/avi"
DEBUG 2015-11-13 12:35:01.099 [New I/O worker #8] Reading hide_transcode_folder: true (default: false)
DEBUG 2015-11-13 12:35:01.099 [New I/O worker #8] Reading autoload_external_subtitles: false (default: true)
TRACE 2015-11-13 12:35:01.099 [New I/O worker #8] End of analysis for /Users/umsmkv/aML/Video/Index/@Crash
TRACE 2015-11-13 12:35:01.100 [New I/O worker #8] Not setting subsAreValidForStreaming and it is false for Tears Of The Sun.mkv
TRACE 2015-11-13 12:35:01.101 [New I/O worker #8] Network debugger: "Tears Of The Sun" http-get:*:video/avi:DLNA.ORG_OP=01 size=19418232298 duration=02:00:55.00 http://10.0.1.50:5001/get/9/Tears+Of+The+Sun.mkv
TRACE 2015-11-13 12:35:01.101 [New I/O worker #8] <?xml version="1.0" encoding="utf-8"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1">
<Result><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><item id="9" parentID="3" restricted="true"><dc:title>Tears Of The Sun</dc:title><res xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" protocolInfo="http-get:*:video/avi:DLNA.ORG_OP=01" size="19418232298" duration="02:00:55.00" resolution="1920x1080" bitrate="2676433" nrAudioChannels="6" sampleFrequency="48000">http://10.0.1.50:5001/get/9/Tears+Of+The+Sun.mkv</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN">http://10.0.1.50:5001/get/9/thumbnail0000Tears+Of+The+Sun.mkv</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM">http://10.0.1.50:5001/get/9/thumbnail0000Tears+Of+The+Sun.mkv</res><dc:date>2015-10-08T20:09:24</dc:date><upnp:class>object.item.videoItem</upnp:class></item></DIDL-Lite></Result>
<NumberReturned>1</NumberReturned>
<TotalMatches>1</TotalMatches>
<UpdateID>2</UpdateID>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
TRACE 2015-11-13 12:35:01.102 [New I/O worker #8] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2015-11-13 12:35:01.102 [New I/O worker #8] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:01.102 [New I/O worker #8] Sent to socket: Content-Length: 1396
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] Opened request handler on socket /10.0.1.89:47329
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] Request: HTTP/1.0 : POST : upnp/control/content_directory
DEBUG 2015-11-13 12:35:01.105 [New I/O worker #9] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] Received on socket: HOST: 10.0.1.50:5001
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] Received on socket: CONTENT-LENGTH: 255
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] Received on socket: CONTENT-TYPE: text/xml;charset="utf-8"
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] Received on socket: USER-AGENT: DLNADOC/1.50
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] Received on socket: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] HTTP User-Agent: DLNADOC/1.50
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] Recognized media renderer: TV-55C8000
TRACE 2015-11-13 12:35:01.105 [New I/O worker #9] HTTP: upnp/control/content_directory / 0-0
DEBUG 2015-11-13 12:35:01.105 [New I/O worker #9] Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
TRACE 2015-11-13 12:35:01.106 [New I/O worker #9] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2015-11-13 12:35:01.106 [New I/O worker #9] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:01.106 [New I/O worker #9] Sent to socket: Content-Length: 448
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] Opened request handler on socket /10.0.1.89:37608
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] Request: HTTP/1.0 : POST : upnp/control/content_directory
DEBUG 2015-11-13 12:35:01.108 [New I/O worker #10] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] Received on socket: HOST: 10.0.1.50:5001
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] Received on socket: CONTENT-LENGTH: 417
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] Received on socket: CONTENT-TYPE: text/xml;charset="utf-8"
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] Received on socket: USER-AGENT: DLNADOC/1.50
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] Received on socket: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] HTTP User-Agent: DLNADOC/1.50
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] Recognized media renderer: TV-55C8000
TRACE 2015-11-13 12:35:01.108 [New I/O worker #10] HTTP: upnp/control/content_directory / 0-0
TRACE 2015-11-13 12:35:01.109 [New I/O worker #10] <?xml version="1.0" encoding="utf-8"?>
<s:Body>
<Result><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><container id="3" childCount="1" parentID="1" restricted="true"><dc:title>@Crash</dc:title><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN">http://10.0.1.50:5001/get/3/thumbnail0000%40Crash</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM">http://10.0.1.50:5001/get/3/thumbnail0000%40Crash</res><dc:date>2015-11-13T11:32:04</dc:date><upnp:class>object.container.storageFolder</upnp:class></container></DIDL-Lite></Result>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
TRACE 2015-11-13 12:35:01.109 [New I/O worker #10] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2015-11-13 12:35:01.109 [New I/O worker #10] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:01.109 [New I/O worker #10] Sent to socket: Content-Length: 1099
TRACE 2015-11-13 12:35:01.116 [New I/O worker #11] Opened request handler on socket /10.0.1.89:48470
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] Request: HTTP/1.0 : POST : upnp/control/content_directory
DEBUG 2015-11-13 12:35:01.117 [New I/O worker #11] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] Received on socket: HOST: 10.0.1.50:5001
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] Received on socket: CONTENT-LENGTH: 656
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] Received on socket: CONTENT-TYPE: text/xml;charset="utf-8"
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] Received on socket: USER-AGENT: DLNADOC/1.50
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] Received on socket: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] HTTP User-Agent: DLNADOC/1.50
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] Recognized media renderer: TV-55C8000
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] HTTP: upnp/control/content_directory / 0-0
TRACE 2015-11-13 12:35:01.117 [New I/O worker #11] discover 3 refresh forced: true
TRACE 2015-11-13 12:35:01.118 [New I/O worker #11] End of analysis for /Users/umsmkv/aML/Video/Index/@Crash
TRACE 2015-11-13 12:35:01.118 [New I/O worker #11] Not setting subsAreValidForStreaming and it is false for Tears Of The Sun.mkv
TRACE 2015-11-13 12:35:01.119 [New I/O worker #11] Network debugger: "Tears Of The Sun" http-get:*:video/avi:DLNA.ORG_OP=01 size=19418232298 duration=02:00:55.00 http://10.0.1.50:5001/get/9/Tears+Of+The+Sun.mkv
TRACE 2015-11-13 12:35:01.119 [New I/O worker #11] <?xml version="1.0" encoding="utf-8"?>
<s:Body>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
TRACE 2015-11-13 12:35:01.120 [New I/O worker #11] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2015-11-13 12:35:01.120 [New I/O worker #11] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:01.120 [New I/O worker #11] Sent to socket: Content-Length: 1396
TRACE 2015-11-13 12:35:01.282 [New I/O worker #12] Opened request handler on socket /10.0.1.89:59891
TRACE 2015-11-13 12:35:01.283 [New I/O worker #12] Request: HTTP/1.0 : GET : get/9/thumbnail0000Tears+Of+The+Sun.mkv
DEBUG 2015-11-13 12:35:01.283 [New I/O worker #12] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:01.283 [New I/O worker #12] Received on socket: HOST: 10.0.1.50:5001
TRACE 2015-11-13 12:35:01.283 [New I/O worker #12] Received on socket: ACCEPT-LANGUAGE: en-us
TRACE 2015-11-13 12:35:01.283 [New I/O worker #12] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-11-13 12:35:01.283 [New I/O worker #12] Received on socket: transferMode.dlna.org: Interactive
TRACE 2015-11-13 12:35:01.283 [New I/O worker #12] Recognized media renderer: TV-55C8000
TRACE 2015-11-13 12:35:01.283 [New I/O worker #12] HTTP: get/9/thumbnail0000Tears+Of+The+Sun.mkv / 0-0
DEBUG 2015-11-13 12:35:01.284 [New I/O worker #12] Reading thumbnail_seek_position: 80 (default: 4)
DEBUG 2015-11-13 12:35:01.286 [New I/O worker #12] Starting /Users/umsmkv/bin/Universal Media Server 530J8.app/Contents/Resources/osx/ffmpeg -ss 80 -i /Users/umsmkv/aML/Video/Index/@Crash/Tears Of The Sun.mkv -an -an -vf scale='if(gt(a,1.78),320,-1)':'if(gt(a,1.78),-1,180)', pad=320:180:(320-iw)/2:(180-ih)/2 -vframes 1 -f image2 pipe:
TRACE 2015-11-13 12:35:01.286 [New I/O worker #12] Setting FONTCONFIG_PATH to "/Users/umsmkv/bin/Universal Media Server 530J8.app/Contents/Resources/fonts"
TRACE 2015-11-13 12:35:01.647 [New I/O worker #12] Successfully initialized buffer to 1,048,576 bytes.
DEBUG 2015-11-13 12:35:01.647 [New I/O worker #12] Attaching thread: ffmpeg-2
DEBUG 2015-11-13 12:35:01.648 [New I/O worker #12] Unix process ID (/Users/umsmkv/bin/Universal Media Server 530J8.app/Contents/Resources/osx/ffmpeg): 45445
TRACE 2015-11-13 12:35:01.648 [New I/O worker #12] EOF
TRACE 2015-11-13 12:35:01.648 [New I/O worker #12] Ready to Stop: true
DEBUG 2015-11-13 12:35:01.649 [New I/O worker #12] Reading alternate_thumb_folder: "/Users/umsmkv/aML/VideoIndex/CoverArt" (default: "")
DEBUG 2015-11-13 12:35:01.649 [New I/O worker #12] use def thumb images/thumbnail-video-256.png
TRACE 2015-11-13 12:35:01.650 [New I/O worker #12] Available Content-Length: 19803
TRACE 2015-11-13 12:35:01.653 [New I/O worker #12] Sent to socket: TransferMode.DLNA.ORG: Interactive
TRACE 2015-11-13 12:35:01.653 [New I/O worker #12] Sent to socket: Content-Type: image/jpeg
TRACE 2015-11-13 12:35:01.653 [New I/O worker #12] Sent to socket: Accept-Ranges: bytes
TRACE 2015-11-13 12:35:01.653 [New I/O worker #12] Sent to socket: Expires: Tue, 08 Mar 2016 11:21:41 GMT
TRACE 2015-11-13 12:35:01.653 [New I/O worker #12] Sent to socket: Connection: keep-alive
TRACE 2015-11-13 12:35:01.654 [New I/O worker #12] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:01.654 [New I/O worker #12] Sent to socket: Content-Length: 19803
DEBUG 2015-11-13 12:35:04.150 [ffmpeg-2-Cleanup] Stopping Unix process 45445: ffmpeg-2
TRACE 2015-11-13 12:35:04.150 [ffmpeg-2-Cleanup] Killing the Unix process: 45445
TRACE 2015-11-13 12:35:04.151 [ffmpeg-2-Cleanup] Destroying buffer
TRACE 2015-11-13 12:35:06.766 [New I/O worker #13] Opened request handler on socket /10.0.1.89:47981
TRACE 2015-11-13 12:35:06.767 [New I/O worker #13] Request: HTTP/1.0 : HEAD : get/9/Tears+Of+The+Sun.mkv
DEBUG 2015-11-13 12:35:06.767 [New I/O worker #13] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:06.767 [New I/O worker #13] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-11-13 12:35:06.767 [New I/O worker #13] Received on socket: Host: 10.0.1.50:5001
TRACE 2015-11-13 12:35:06.767 [New I/O worker #13] Recognized media renderer: TV-55C8000
TRACE 2015-11-13 12:35:06.767 [New I/O worker #13] HTTP: get/9/Tears+Of+The+Sun.mkv / 0-0
TRACE 2015-11-13 12:35:06.767 [New I/O worker #13] Asked stream chunk : TimeRange [start=null, end=null] of Tears Of The Sun.mkv and player null
DEBUG 2015-11-13 12:35:06.768 [New I/O worker #13] Reading SubtitleHttpHeader: "CaptionInfo.sec" (default: "")
TRACE 2015-11-13 12:35:06.768 [New I/O worker #13] Did not send subtitle headers because dlna.getMediaSubtitle returned null
DEBUG 2015-11-13 12:35:06.769 [StartPlaying Event] Matched media renderer "TV-55C8000" based on address /10.0.1.89
INFO 2015-11-13 12:35:06.770 [StartPlaying Event] Started playing Tears Of The Sun.mkv on your TV-55C8000
DEBUG 2015-11-13 12:35:06.771 [StartPlaying Event] The full filename of which is: /Users/umsmkv/aML/Video/Index/@Crash/Tears Of The Sun.mkv and the address of the renderer is: 10.0.1.89
TRACE 2015-11-13 12:35:06.772 [New I/O worker #13] Sent to socket: Content-Type: video/avi
TRACE 2015-11-13 12:35:06.772 [New I/O worker #13] Sent to socket: ContentFeatures.DLNA.ORG: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000
TRACE 2015-11-13 12:35:06.772 [New I/O worker #13] Sent to socket: Accept-Ranges: bytes
TRACE 2015-11-13 12:35:06.772 [New I/O worker #13] Sent to socket: Connection: keep-alive
TRACE 2015-11-13 12:35:06.772 [New I/O worker #13] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:06.772 [New I/O worker #13] Sent to socket: Content-Length: 19418232298
TRACE 2015-11-13 12:35:06.776 [New I/O worker #14] Opened request handler on socket /10.0.1.89:48830
TRACE 2015-11-13 12:35:06.778 [New I/O worker #14] Request: HTTP/1.0 : GET : get/9/Tears+Of+The+Sun.mkv
DEBUG 2015-11-13 12:35:06.780 [New I/O worker #14] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:06.781 [New I/O worker #14] Received on socket: Range: bytes=0-
TRACE 2015-11-13 12:35:06.781 [New I/O worker #14] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-11-13 12:35:06.781 [New I/O worker #14] Received on socket: transferMode.dlna.org: Streaming
TRACE 2015-11-13 12:35:06.781 [New I/O worker #14] Received on socket: getMediaInfo.sec: 1
TRACE 2015-11-13 12:35:06.781 [New I/O worker #14] Received on socket: Host: 10.0.1.50:5001
TRACE 2015-11-13 12:35:06.781 [New I/O worker #14] Recognized media renderer: TV-55C8000
TRACE 2015-11-13 12:35:06.781 [New I/O worker #14] HTTP: get/9/Tears+Of+The+Sun.mkv / 0--1
TRACE 2015-11-13 12:35:06.781 [New I/O worker #14] Asked stream chunk : TimeRange [start=null, end=null] of Tears Of The Sun.mkv and player null
TRACE 2015-11-13 12:35:06.782 [New I/O worker #14] Did not send subtitle headers because dlna.getMediaSubtitle returned null
TRACE 2015-11-13 12:35:06.782 [New I/O worker #14] Sending 19418232298 bytes.
TRACE 2015-11-13 12:35:06.784 [New I/O worker #14] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2015-11-13 12:35:06.785 [New I/O worker #14] Sent to socket: Content-Type: video/avi
TRACE 2015-11-13 12:35:06.785 [New I/O worker #14] Sent to socket: Content-Range: bytes 0-19418232297/19418232298
TRACE 2015-11-13 12:35:06.785 [New I/O worker #14] Sent to socket: ContentFeatures.DLNA.ORG: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000
TRACE 2015-11-13 12:35:06.785 [New I/O worker #14] Sent to socket: Accept-Ranges: bytes
TRACE 2015-11-13 12:35:06.785 [New I/O worker #14] Sent to socket: Connection: keep-alive
TRACE 2015-11-13 12:35:06.785 [New I/O worker #14] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:06.785 [New I/O worker #14] Sent to socket: Content-Length: 19418232298
DEBUG 2015-11-13 12:35:06.819 [New I/O worker #14] Connection error: java.io.IOException: Connection reset by peer
TRACE 2015-11-13 12:35:06.819 [New I/O worker #15] Opened request handler on socket /10.0.1.89:34277
DEBUG 2015-11-13 12:35:06.819 [New I/O worker #14] Premature end, stopping...
TRACE 2015-11-13 12:35:06.819 [New I/O worker #15] Request: HTTP/1.0 : GET : get/9/Tears+Of+The+Sun.mkv
DEBUG 2015-11-13 12:35:06.819 [New I/O worker #15] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:06.820 [New I/O worker #15] Received on socket: Range: bytes=19418018784-
TRACE 2015-11-13 12:35:06.820 [New I/O worker #15] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-11-13 12:35:06.820 [New I/O worker #15] Received on socket: transferMode.dlna.org: Streaming
TRACE 2015-11-13 12:35:06.820 [New I/O worker #15] Received on socket: Host: 10.0.1.50:5001
TRACE 2015-11-13 12:35:06.820 [New I/O worker #15] Recognized media renderer: TV-55C8000
TRACE 2015-11-13 12:35:06.820 [New I/O worker #15] HTTP: get/9/Tears+Of+The+Sun.mkv / 19418018784--1
TRACE 2015-11-13 12:35:06.821 [New I/O worker #15] Asked stream chunk : ByteRange [start=19418018784, end=-1] of Tears Of The Sun.mkv and player null
TRACE 2015-11-13 12:35:06.821 [New I/O worker #15] Did not send subtitle headers because dlna.getMediaSubtitle returned null
TRACE 2015-11-13 12:35:06.822 [New I/O worker #15] Sending 213514 bytes.
TRACE 2015-11-13 12:35:06.823 [New I/O worker #15] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2015-11-13 12:35:06.824 [New I/O worker #15] Sent to socket: Content-Type: video/avi
TRACE 2015-11-13 12:35:06.824 [New I/O worker #15] Sent to socket: Content-Range: bytes 19418018784-19418232297/19418232298
TRACE 2015-11-13 12:35:06.824 [New I/O worker #15] Sent to socket: ContentFeatures.DLNA.ORG: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000
TRACE 2015-11-13 12:35:06.824 [New I/O worker #15] Sent to socket: Accept-Ranges: bytes
TRACE 2015-11-13 12:35:06.824 [New I/O worker #15] Sent to socket: Connection: keep-alive
TRACE 2015-11-13 12:35:06.824 [New I/O worker #15] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:06.824 [New I/O worker #15] Sent to socket: Content-Length: 213514
TRACE 2015-11-13 12:35:06.889 [New I/O worker #16] Opened request handler on socket /10.0.1.89:38445
TRACE 2015-11-13 12:35:06.889 [New I/O worker #16] Request: HTTP/1.0 : GET : get/9/Tears+Of+The+Sun.mkv
DEBUG 2015-11-13 12:35:06.889 [New I/O worker #16] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:06.890 [New I/O worker #16] Received on socket: Range: bytes=3903-
TRACE 2015-11-13 12:35:06.890 [New I/O worker #16] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-11-13 12:35:06.890 [New I/O worker #16] Received on socket: transferMode.dlna.org: Streaming
TRACE 2015-11-13 12:35:06.890 [New I/O worker #16] Received on socket: Host: 10.0.1.50:5001
TRACE 2015-11-13 12:35:06.890 [New I/O worker #16] Recognized media renderer: TV-55C8000
TRACE 2015-11-13 12:35:06.890 [New I/O worker #16] HTTP: get/9/Tears+Of+The+Sun.mkv / 3903--1
TRACE 2015-11-13 12:35:06.890 [New I/O worker #16] Asked stream chunk : ByteRange [start=3903, end=-1] of Tears Of The Sun.mkv and player null
TRACE 2015-11-13 12:35:06.890 [New I/O worker #16] Did not send subtitle headers because dlna.getMediaSubtitle returned null
TRACE 2015-11-13 12:35:06.890 [New I/O worker #16] Sending 19418228395 bytes.
TRACE 2015-11-13 12:35:06.893 [New I/O worker #16] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2015-11-13 12:35:06.893 [New I/O worker #16] Sent to socket: Content-Type: video/avi
TRACE 2015-11-13 12:35:06.893 [New I/O worker #16] Sent to socket: Content-Range: bytes 3903-19418232297/19418232298
TRACE 2015-11-13 12:35:06.893 [New I/O worker #16] Sent to socket: ContentFeatures.DLNA.ORG: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000
TRACE 2015-11-13 12:35:06.893 [New I/O worker #16] Sent to socket: Accept-Ranges: bytes
TRACE 2015-11-13 12:35:06.893 [New I/O worker #16] Sent to socket: Connection: keep-alive
TRACE 2015-11-13 12:35:06.893 [New I/O worker #16] Sent to socket: Server: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0
TRACE 2015-11-13 12:35:06.893 [New I/O worker #16] Sent to socket: Content-Length: 19418228395
TRACE 2015-11-13 12:35:33.341 [UPNPHelper] Receiving a M-SEARCH from [10.0.1.89:1025]
DEBUG 2015-11-13 12:35:33.345 [cling-42] Subscription cancelled: ConnectionManager on uuid:3a3e65ac-abf0-4e93-5488-d2f1c2b5ef41: DEVICE_WAS_REMOVED
DEBUG 2015-11-13 12:35:33.345 [cling-44] Subscription cancelled: AVTransport on uuid:3a3e65ac-abf0-4e93-5488-d2f1c2b5ef41: DEVICE_WAS_REMOVED
DEBUG 2015-11-13 12:35:33.345 [cling-40] Subscription cancelled: RenderingControl on uuid:3a3e65ac-abf0-4e93-5488-d2f1c2b5ef41: DEVICE_WAS_REMOVED
DEBUG 2015-11-13 12:35:33.347 [cling-47] TV-55C8000 is now offline.
TRACE 2015-11-13 12:35:33.351 [UPNPHelper] Sending discovery [10.0.1.89:1027]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Fri, 13 Nov 2015 17:35:33 GMT<CRLF>LOCATION: http://10.0.1.50:5001/description/fetch<CRLF>SERVER: Mac_OS_X-x86_64-10.7.5, UPnP/1.0, UMS/5.3.0<CRLF>ST: urn:schemas-upnp-org:device:MediaServer:1<CRLF>EXT: <CRLF>USN: uuid:3d7edd4a-31e0-4758-9169-eb3f39a36933::urn:schemas-upnp-org:device:MediaServer:1<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2015-11-13 12:35:33.362 [New I/O worker #1] Opened request handler on socket /10.0.1.89:53828
TRACE 2015-11-13 12:35:33.362 [New I/O worker #1] Request: HTTP/1.0 : GET : description/fetch
DEBUG 2015-11-13 12:35:33.362 [New I/O worker #1] Matched media renderer "TV-55C8000" based on address /10.0.1.89
TRACE 2015-11-13 12:35:33.362 [New I/O worker #1] Received on socket: HOST: 10.0.1.50:5001
TRACE 2015-11-13 12:35:33.362 [New I/O worker #1] Received on socket: USER-AGENT: SEC_HHP_TV-55C8000/1.0
TRACE 2015-11-13 12:35:33.362 [New I/O worker #1] Received on socket: ACCEPT-LANGUAGE: en-us
TRACE 2015-11-13 12:35:33.362 [New I/O worker #1] HTTP User-Agent: SEC_HHP_TV-55C8000/1.0
TRACE 2015-11-13 12:35:33.362 [New I/O worker #1] Recognized media renderer: TV-55C8000
- ums_dbg-530-CrashTV.zip
- (30.67 KiB) Downloaded 512 times
. . . . and a few others.
Samsung UN55C8000
Samsung UN55C8000
