Exception in thread?
starterz
Post by starterz »
Hello again,
I am constantly using UMS for movies with subs and music, thank you again for your great effort.
I am seeing a confusing message in the log, so I would ask someone for an explanation what this means.
At this moment, I am playing an album via UMS, FLAC transcoded to WAV for my Philips 40PFL6606H/12 TV. The music plays just fine, but I see many instances like this in the log:
01-25 21:03:44 Starting transcode/remux of 01 - Weather Report - Procession.flac
01-25 21:03:45 Exception in thread "pool-157-thread-1" java.lang.NullPointerException
01-25 21:03:45 at net.pms.dlna.CueFolder.resolve(CueFolder.java:171)
01-25 21:03:45 at net.pms.dlna.DLNAResource.run(DLNAResource.java:830)
01-25 21:03:45 at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
01-25 21:03:45 at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
01-25 21:03:45 at java.lang.Thread.run(Unknown Source)
01-25 21:03:46 Started playing 01 - Weather Report - Procession.flac on your Philips TV
Am I seeing some kind of a problem? Is it connected to the .cue file in the same folder? I see that UMS shows the .cue as a folder, but I still haven't tested this enough (to play separate songs from the .cue). I just play the music file directly, no matter if it is one big flac or separate flacs.
Thanks for any help on this issue. All best.
(16.71 KiB) Downloaded 463 times
starterz
Re: Exception in thread?
Post by starterz »
Same issue is being discussed in this thread:
viewtopic.php?f=9&t=520
This one can be closed.
