Unable to read AVC on Bravia with windows 10
I was using WMP on Windows 7 with my TV Bravia Z5500, without anly issues, for various file formats, including AVCHD files.
With WMP on Windows 7, I dont even see the files that are in other formats than MP2.
This is why, I try to use UMS.
With UMS, I see all my files on the tv, but I am unable to read the ones that are not MP2.
Below is an example.
Thanks in advance for your help.
Jean-Pierre
As an example, I unable to read the following file :
Complete name : C:\Users\Jean-Pierre\Videos\2014-08 Mayotte.mpeg
Format : MPEG-TS
File size : 6,10 Gio
Duration : 28mn 13s
Overall bit rate mode : Constant
Overall bit rate : 30,9 Mb/s
Vidéo
Menu ID : 1 (0x1)
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Oui
Format settings, ReFrames : 3 images
Format settings, GOP : M=3, N=18
Codec ID : 27
Duration : 28mn 12s
Bit rate mode : Variable
Bit rate : 29,2 Mb/s
Maximum bit rate : 30,0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 25,000 Im/s
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Entrelacé
Scan type, store method : Trames séparées
Scan order : Ligne du haut d'abord
Bits/(Pixel*Frame) : 0.564
Stream size : 5,76 Gio (94%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 129
Duration : 28mn 12s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 canaux
Channel positions : Front: L R
Sampling rate : 48,0 KHz
Frame rate : 31,250 Im/s (1536 spf)
Compression mode : Avec perte
Stream size : 38,7 Mio (1%)
Here is the log
13:53:55 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:53:55 DEBUG Reading UserAgentAdditionalHeader: "X-AV-Client-Info" (default: "")
13:53:55 DEBUG Reading use_cache: false (default: true)
13:53:55 DEBUG Reading hide_recently_played_folder: true (default: false)
13:53:55 DEBUG Reading folders: "C:\Users\Jean-Pierre\Videos,C:\Users\Jean-Pierre\Pictures,C:\Users\Jean-Pierre\Music" (default: "")
13:53:55 INFO Checking shared folder: C:\Users\Jean-Pierre\Videos
13:53:55 INFO Checking shared folder: C:\Users\Jean-Pierre\Pictures
13:53:55 INFO Checking shared folder: C:\Users\Jean-Pierre\Music
13:53:55 DEBUG Reading external_network: false (default: true)
13:53:55 DEBUG Reading CreateDLNATreeFaster: true (default: false)
13:53:55 DEBUG Reading ThumbnailAsResource: true (default: false)
13:53:56 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:53:56 DEBUG use def thumb images/thumbnail-folder-256.png
13:53:57 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:53:57 DEBUG use def thumb images/thumbnail-folder-256.png
13:53:58 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:53:58 DEBUG Reading TranscodeExtensions: "dvr-ms,dvr,mkv,dv,ty,mov,ogm,hdmov,hdm,rmv,rmvb,rm,asf,evo,asx,flv,m2v,mpe,mod,tivo,ty,tmf,ts,tp,m2p,mp4,m4v,avi,wmv,wm,divx,div,flac,mlp,fla,wma,m4a,aac,dts,mka,ape,ogg,shn,mpc,ra,mp2,wv,oma,aa3,gif,png,arw,cr2,crw,dng,raf,mrw,nef,pef,tif,tiff" (default: "")
13:53:58 DEBUG Reading hide_transcode_folder: true (default: false)
13:53:58 DEBUG Reading DLNALocalizationRequired: true (default: false)
13:53:58 DEBUG Reading SeekByTime: "true" (default: "false")
13:53:58 DEBUG Reading MuxNonMod4Resolution: true (default: false)
13:53:59 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:54:00 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:54:00 DEBUG Starting C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe -ss 86 -i C:\Users\Jean-Pierre\Videos\1989 Mareuil.mpg -an -an -vf scale='if(gt(a,1.78),320,-1)':'if(gt(a,1.78),-1,180)', pad=320:180:(320-iw)/2:(180-ih)/2 -vframes 1 -f image2 pipe:
13:54:00 DEBUG Attaching thread: ffmpeg64.exe-2
13:54:00 DEBUG ffmpeg version N-76250-g7c8fcbb Copyright (c) 2000-2015 the FFmpeg developers
13:54:00 DEBUG built with gcc 5.2.0 (GCC)
13:54:00 DEBUG configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
13:54:00 DEBUG libavutil 55. 4.100 / 55. 4.100
13:54:00 DEBUG libavcodec 57. 9.100 / 57. 9.100
13:54:00 DEBUG libavformat 57. 10.102 / 57. 10.102
13:54:00 DEBUG libavdevice 57. 0.100 / 57. 0.100
13:54:00 DEBUG libavfilter 6. 13.100 / 6. 13.100
13:54:00 DEBUG libswscale 4. 0.100 / 4. 0.100
13:54:00 DEBUG libswresample 2. 0.100 / 2. 0.100
13:54:00 DEBUG libpostproc 54. 0.100 / 54. 0.100
13:54:00 DEBUG Input #0, mpeg, from 'C:\Users\Jean-Pierre\Videos\1989 Mareuil.mpg':
13:54:00 DEBUG Duration: 00:15:58.12, start: 0.280000, bitrate: 6313 kb/s
13:54:00 DEBUG Stream #0:0[0x1bf]: Data: dvd_nav_packet
13:54:00 DEBUG Stream #0:1[0x1e0]: Video: mpeg2video (Main), yuv420p(tv), 720x576 [SAR 16:15 DAR 4:3], max. 8000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
13:54:00 DEBUG Stream #0:2[0x80]: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
13:54:00 DEBUG [swscaler @ 000002305f0a0d60] deprecated pixel format used, make sure you did set range correctly
13:54:00 DEBUG Output #0, image2, to 'pipe:':
13:54:00 DEBUG Metadata:
13:54:00 DEBUG encoder : Lavf57.10.102
13:54:00 DEBUG Stream #0:0: Video: mjpeg, yuvj420p(pc), 320x180 [SAR 16:15 DAR 256:135], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc
13:54:00 DEBUG encoder : Lavc57.9.100 mjpeg
13:54:00 DEBUG Stream mapping:
13:54:00 DEBUG Stream #0:1 -> #0:0 (mpeg2video (native) -> mjpeg (native))
13:54:00 DEBUG Press [q] to stop, [?] for help
13:54:00 DEBUG [swscaler @ 000002305f0a0d60] Warning: data is not aligned! This can lead to a speedloss
13:54:00 DEBUG frame= 1 fps=0.0 q=4.2 Lsize=N/A time=00:00:00.04 bitrate=N/A
13:54:00 DEBUG video:11kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
13:54:00 DEBUG Starting C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe -ss 4 -i C:\Users\Jean-Pierre\Videos\1989 Mareuil.mpg -an -an -vf scale='if(gt(a,1.78),320,-1)':'if(gt(a,1.78),-1,180)', pad=320:180:(320-iw)/2:(180-ih)/2 -vframes 1 -f image2 pipe:
13:54:00 DEBUG Attaching thread: ffmpeg64.exe-3
13:54:00 DEBUG [swscaler @ 0000015ec3970d60] deprecated pixel format used, make sure you did set range correctly
13:54:00 DEBUG [swscaler @ 0000015ec3970d60] Warning: data is not aligned! This can lead to a speedloss
13:54:00 DEBUG frame= 1 fps=0.0 q=4.5 Lsize=N/A time=00:00:00.04 bitrate=N/A
13:54:01 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:54:01 DEBUG Starting C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe -ss 4 -i C:\Users\Jean-Pierre\Videos\2014-08 Mayotte.mpeg -an -an -vf scale='if(gt(a,1.78),320,-1)':'if(gt(a,1.78),-1,180)', pad=320:180:(320-iw)/2:(180-ih)/2 -vframes 1 -f image2 pipe:
13:54:01 DEBUG Attaching thread: ffmpeg64.exe-4
13:54:01 DEBUG ffmpeg version N-76250-g7c8fcbb Copyright (c) 2000-2015 the FFmpeg developers
13:54:01 DEBUG built with gcc 5.2.0 (GCC)
13:54:01 DEBUG configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
13:54:01 DEBUG libavutil 55. 4.100 / 55. 4.100
13:54:01 DEBUG libavcodec 57. 9.100 / 57. 9.100
13:54:01 DEBUG libavformat 57. 10.102 / 57. 10.102
13:54:01 DEBUG libavdevice 57. 0.100 / 57. 0.100
13:54:01 DEBUG libavfilter 6. 13.100 / 6. 13.100
13:54:01 DEBUG libswscale 4. 0.100 / 4. 0.100
13:54:01 DEBUG libswresample 2. 0.100 / 2. 0.100
13:54:01 DEBUG libpostproc 54. 0.100 / 54. 0.100
13:54:01 DEBUG Input #0, mpegts, from 'C:\Users\Jean-Pierre\Videos\2014-08 Mayotte.mpeg':
13:54:01 DEBUG Duration: 00:28:12.51, start: 1.000000, bitrate: 30951 kb/s
13:54:01 DEBUG Program 1
13:54:01 DEBUG Stream #0:0[0x3e9]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
13:54:01 DEBUG Stream #0:1[0x3ea]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 192 kb/s
13:54:01 DEBUG [swscaler @ 000001a8988e6920] deprecated pixel format used, make sure you did set range correctly
13:54:01 DEBUG Output #0, image2, to 'pipe:':
13:54:01 DEBUG Metadata:
13:54:01 DEBUG encoder : Lavf57.10.102
13:54:01 DEBUG Stream #0:0: Video: mjpeg, yuvj420p(pc), 320x180 [SAR 1:1 DAR 16:9], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc
13:54:01 DEBUG encoder : Lavc57.9.100 mjpeg
13:54:01 DEBUG Stream mapping:
13:54:01 DEBUG Stream #0:0 -> #0:0 (h264 (native) -> mjpeg (native))
13:54:01 DEBUG Press [q] to stop, [?] for help
13:54:01 DEBUG [h264 @ 000001a8988d0300] Missing reference picture, default is 2147483647
13:54:01 DEBUG Last message repeated 11 times
13:54:01 DEBUG [h264 @ 000001a89831a260] Missing reference picture, default is 65554
13:54:01 DEBUG Last message repeated 15 times
13:54:01 DEBUG [h264 @ 000001a8986c5540] Missing reference picture, default is 65555
13:54:01 DEBUG Last message repeated 3 times
13:54:01 DEBUG [h264 @ 000001a8986c5540] Missing reference picture, default is 65560
13:54:01 DEBUG frame= 1 fps=0.0 q=2.2 Lsize=N/A time=00:00:00.04 bitrate=N/A dup=1 drop=1
13:54:01 DEBUG video:4kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
13:54:01 DEBUG Starting C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe -ss 4 -i C:\Users\Jean-Pierre\Videos\2015_08 Spitzberg.m2t -an -an -vf scale='if(gt(a,1.78),320,-1)':'if(gt(a,1.78),-1,180)', pad=320:180:(320-iw)/2:(180-ih)/2 -vframes 1 -f image2 pipe:
13:54:01 DEBUG Attaching thread: ffmpeg64.exe-5
13:54:01 DEBUG Input #0, mpegts, from 'C:\Users\Jean-Pierre\Videos\2015_08 Spitzberg.m2t':
13:54:01 DEBUG Duration: 01:06:16.16, start: 1.000000, bitrate: 30942 kb/s
13:54:01 DEBUG [swscaler @ 00000236f7e83980] deprecated pixel format used, make sure you did set range correctly
13:54:01 DEBUG [h264 @ 00000236f7e40500] Missing reference picture, default is 2147483647
13:54:01 DEBUG [h264 @ 00000236f7ee0060] Missing reference picture, default is 65554
13:54:01 DEBUG [h264 @ 00000236f7ef1280] Missing reference picture, default is 65555
13:54:01 DEBUG [h264 @ 00000236f7ef1280] Missing reference picture, default is 65560
13:54:01 DEBUG frame= 1 fps=0.0 q=2.1 Lsize=N/A time=00:00:00.04 bitrate=N/A dup=1 drop=1
13:54:02 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:54:02 DEBUG Stopping process: ffmpeg64.exe-2
13:54:02 DEBUG Starting C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe -ss 13 -i C:\Users\Jean-Pierre\Videos\Dumbo.m4v -an -an -vf scale='if(gt(a,1.78),320,-1)':'if(gt(a,1.78),-1,180)', pad=320:180:(320-iw)/2:(180-ih)/2 -vframes 1 -f image2 pipe:
13:54:02 DEBUG Attaching thread: ffmpeg64.exe-6
13:54:02 DEBUG ffmpeg version N-76250-g7c8fcbb Copyright (c) 2000-2015 the FFmpeg developers
13:54:02 DEBUG built with gcc 5.2.0 (GCC)
13:54:02 DEBUG configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
13:54:02 DEBUG libavutil 55. 4.100 / 55. 4.100
13:54:02 DEBUG libavcodec 57. 9.100 / 57. 9.100
13:54:02 DEBUG libavformat 57. 10.102 / 57. 10.102
13:54:02 DEBUG libavdevice 57. 0.100 / 57. 0.100
13:54:02 DEBUG libavfilter 6. 13.100 / 6. 13.100
13:54:02 DEBUG libswscale 4. 0.100 / 4. 0.100
13:54:02 DEBUG libswresample 2. 0.100 / 2. 0.100
13:54:02 DEBUG libpostproc 54. 0.100 / 54. 0.100
13:54:02 DEBUG Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Users\Jean-Pierre\Videos\Dumbo.m4v':
13:54:02 DEBUG Metadata:
13:54:02 DEBUG major_brand : mp42
13:54:02 DEBUG minor_version : 0
13:54:02 DEBUG compatible_brands: mp42isomavc1
13:54:02 DEBUG creation_time : 2014-02-09 17:40:34
13:54:02 DEBUG encoder : HandBrake 0.9.9 2013052900
13:54:02 DEBUG genre : DVD Enfants
13:54:02 DEBUG Duration: 01:01:08.96, start: 0.000000, bitrate: 759 kb/s
13:54:02 DEBUG Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, smpte170m/bt470bg/bt709), 352x292 [SAR 11875:13107 DAR 1045000:956811], 594 kb/s, 25 fps, 25 tbr, 90k tbn, 180k tbc (default)
13:54:02 DEBUG encoder : JVT/AVC Coding
13:54:02 DEBUG Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 159 kb/s (default)
13:54:02 DEBUG [swscaler @ 0000020aa5180580] deprecated pixel format used, make sure you did set range correctly
13:54:02 DEBUG Output #0, image2, to 'pipe:':
13:54:02 DEBUG encoder : Lavf57.10.102
13:54:02 DEBUG Stream #0:0(und): Video: mjpeg, yuvj420p(pc), 320x180 [SAR 62700000:69209329 DAR 588884:178323], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc (default)
13:54:02 DEBUG encoder : Lavc57.9.100 mjpeg
13:54:02 DEBUG Stream mapping:
13:54:02 DEBUG Stream #0:0 -> #0:0 (h264 (native) -> mjpeg (native))
13:54:02 DEBUG Press [q] to stop, [?] for help
13:54:02 DEBUG [swscaler @ 0000020aa5180580] Warning: data is not aligned! This can lead to a speedloss
13:54:02 DEBUG frame= 1 fps=0.0 q=5.1 Lsize=N/A time=00:00:00.04 bitrate=N/A
13:54:02 DEBUG video:9kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
13:54:03 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:54:03 DEBUG Starting C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe -ss 4 -i C:\Users\Jean-Pierre\Videos\Dumbo.m4v -an -an -vf scale='if(gt(a,1.78),320,-1)':'if(gt(a,1.78),-1,180)', pad=320:180:(320-iw)/2:(180-ih)/2 -vframes 1 -f image2 pipe:
13:54:03 DEBUG Attaching thread: ffmpeg64.exe-7
13:54:03 DEBUG Stopping process: ffmpeg64.exe-3
13:54:03 DEBUG ffmpeg version N-76250-g7c8fcbb Copyright (c) 2000-2015 the FFmpeg developers
13:54:03 DEBUG built with gcc 5.2.0 (GCC)
13:54:03 DEBUG configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
13:54:03 DEBUG libavutil 55. 4.100 / 55. 4.100
13:54:03 DEBUG libavcodec 57. 9.100 / 57. 9.100
13:54:03 DEBUG libavformat 57. 10.102 / 57. 10.102
13:54:03 DEBUG libavdevice 57. 0.100 / 57. 0.100
13:54:03 DEBUG libavfilter 6. 13.100 / 6. 13.100
13:54:03 DEBUG libswscale 4. 0.100 / 4. 0.100
13:54:03 DEBUG libswresample 2. 0.100 / 2. 0.100
13:54:03 DEBUG libpostproc 54. 0.100 / 54. 0.100
13:54:03 DEBUG Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Users\Jean-Pierre\Videos\Dumbo.m4v':
13:54:03 DEBUG Metadata:
13:54:03 DEBUG major_brand : mp42
13:54:03 DEBUG minor_version : 0
13:54:03 DEBUG compatible_brands: mp42isomavc1
13:54:03 DEBUG creation_time : 2014-02-09 17:40:34
13:54:03 DEBUG encoder : HandBrake 0.9.9 2013052900
13:54:03 DEBUG genre : DVD Enfants
13:54:03 DEBUG Duration: 01:01:08.96, start: 0.000000, bitrate: 759 kb/s
13:54:03 DEBUG Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, smpte170m/bt470bg/bt709), 352x292 [SAR 11875:13107 DAR 1045000:956811], 594 kb/s, 25 fps, 25 tbr, 90k tbn, 180k tbc (default)
13:54:03 DEBUG encoder : JVT/AVC Coding
13:54:03 DEBUG Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 159 kb/s (default)
13:54:03 DEBUG [swscaler @ 0000020977c90580] deprecated pixel format used, make sure you did set range correctly
13:54:03 DEBUG Output #0, image2, to 'pipe:':
13:54:03 DEBUG encoder : Lavf57.10.102
13:54:03 DEBUG Stream #0:0(und): Video: mjpeg, yuvj420p(pc), 320x180 [SAR 62700000:69209329 DAR 588884:178323], q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc (default)
13:54:03 DEBUG encoder : Lavc57.9.100 mjpeg
13:54:03 DEBUG Stream mapping:
13:54:03 DEBUG Stream #0:0 -> #0:0 (h264 (native) -> mjpeg (native))
13:54:03 DEBUG Press [q] to stop, [?] for help
13:54:03 DEBUG [swscaler @ 0000020977c90580] Warning: data is not aligned! This can lead to a speedloss
13:54:03 DEBUG frame= 1 fps=0.0 q=4.3 Lsize=N/A time=00:00:00.04 bitrate=N/A
13:54:03 DEBUG video:6kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
13:54:03 DEBUG Stopping process: ffmpeg64.exe-4
13:54:04 DEBUG Stopping process: ffmpeg64.exe-5
13:54:05 DEBUG Stopping process: ffmpeg64.exe-6
13:54:05 DEBUG Stopping process: ffmpeg64.exe-7
13:54:22 DEBUG TransportState: TRANSITIONING
13:54:22 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:54:22 INFO Started playing 2014-08 Mayotte.mpeg on your BRAVIA KDL-40Z5710
13:54:22 DEBUG The full filename of which is: C:\Users\Jean-Pierre\Videos\2014-08 Mayotte.mpeg and the address of the renderer is: 192.168.1.11
13:54:23 DEBUG Connection error: java.io.IOException: Une connexion existante a dû être fermée par l’hôte distant
13:54:23 DEBUG Premature end, stopping...
13:54:23 DEBUG TransportStatus: ERROR_OCCURRED
13:54:23 DEBUG TransportState: STOPPED
13:54:27 DEBUG Matched media renderer "BRAVIA KDL-40Z5710 " based on address /192.168.1.11
13:54:27 INFO Stopped playing 2014-08 Mayotte.mpeg on your BRAVIA KDL-40Z5710
13:54:27 DEBUG The full filename of which is: C:\Users\Jean-Pierre\Videos\2014-08 Mayotte.mpeg and the address of the renderer is: 192.168.1.11
13:54:28 DEBUG TransportStatus: OK
13:55:31 DEBUG Sending ALIVE...
Jean-Pierre
Format : MPEG-TS
Duration : 28mn 13s
Vidéo
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 28mn 12s
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 28mn 12s
Bit rate : 192 Kbps
Here is the log
