Getting a cineva message on ps3
jaapie18
Post by jaapie18 »
Im using my ps3 for UMS. Now im getting a cineva message at a certain movie. I tried some "fixes" to change the system date and such, but it won't help. Is there also a way to disable internet on the ps3 without that ums disconect.
Supermanfan77
Re: Getting a cineva message on ps3
Post by Supermanfan77 »
It's not an internet issue. Even if you were disconnected from the internet the PS3 would still recognize it as cineavia protected.
The real question is what type of file are you trying to play? If it's anything other than a MKV bluray rip using the original bluray audio (for example a cam rip) there isn't anything that can be done to bypass the cineavia protection. If it is a MKV file as stated above the following options under Audio settings are what work for me.
Use LPCM for audio
Keep AC-3 tracks
Keep DTS tracks
Encoded audio passthrough for AC-3 and DTS.
