Check for update button
SuperDre
Post by SuperDre »
Pushing the 'check for updates' button doesn't do anything, please let it show a messagebox that you've already got the latest version or something..
Also when I used it the first time (before I manually installed UMS 1.1.0) the download update progress bar makes the UMS keep on the top of the window position, and stays on top, please fix this as during downloading it isn't possible to check a site or switch to another application.. Also after downloading the update it said 'need to download to run', and all I could do is use the 'close' button, but ofcourse it didn't do anything. After restarting UMS it still was on 1.0, so I had to manually download and install UMS.. Well at least with the current UMS 1.1.0 it remembers the 'check automatically' checkbox as it didn't with UMS 1.0..
Re: Check for update button
Thanks for the feedback, I'll look at making improvements to the automatic updater :)
