2.3.0 external subtitles (Sony Bravia 40EX650)
movies play great but there are no subtitles. the video and srt files are named the same.
what should I do?
what should I do?
Re: 2.3.0 external subtitles (Sony Bravia 40EX650)
viewtopic.php?f=9&t=488
i think its related.
Since i have very basic subtitle needs , i have deleted content of "Subtitles language priority" and "Audio/subtitles language priority", and that works for me.
Alltho.. you might need the above settings if you got files that contain multiple languages/subs ..
I havent found solution for this yet. that link was not very usefull but thanks anyway.
so it does not help if you rename your srt <moviename>-en.srt ?
(and "en" is in subtitle language priority list)
If not, sorry then your right, it's not related.
Maybe try pack and upload debug files
here it is.
EDIT: and some ss's of whats happening on my tv:
http://i50.tinypic.com/2u5wfb8.jpg
http://i46.tinypic.com/wjueiu.jpg
http://i46.tinypic.com/6onds2.jpg
http://i46.tinypic.com/sxcht4.jpg
after the last one, movie starts to play, but without subs, as I mentioned.
- (16.51 KiB) Downloaded 667 times
Are the subs embedded?.. or do you have a srt file next to the movie?
not embedded, just 2 files named the same: 'movie.mp4', 'movie.srt'.
Ok, cause it seems to me that it's getting ignored completely.
Imo, Your file name should be xxx [External Subtitles]
Have you tried:
Movie.mp4
Movie-en.srt
Just curious
Have you tried:
Movie.mp4
Movie-en.srt
Just curious
yes, I tried that to.
Ok, thanks.
Well.. actually i seem to have the same problem with the WD TV Live i just got in yesterday.
Even the player says Movie.avi [External Subtitles] , the movie gets served and not transocded with mencoder.
