Versions 6.0.0-b2 and 5.5.0 released
General:
These releases improve support for non-English languages, display on Retina screens, support for subtitles, iOS apps, fixes many bugs and more!
Download 5.5.0:
Download 6.0.0-b2:
Windows
Linux
OS X
Note: 6.0.0-b2 is for versions of Java from 7 upwards, but we will continue to release all stable versions in Java 7 and 8 variations.
Changes since 5.4.0/6.0.0-b1:
  • General:
    • Language selection is offered on first startup
    • Improved display on Retina screens
    • Improved language selection interface
    • Improved conversion of 3D subtitles
    • Fixed positioning of subtitles in FFmpeg
    • Fixed tooltip consistency
    • Fixed detection of file permissions on Windows
    • Fixed detection of headless state
    • Fixed many minor bugs
  • Renderers:
    • Updated images for Android, PS3 and PS4
    • Fixed AirPlayer support
    • Fixed VLC for iOS support
  • Languages:
    • Added Afrikaans, Hungarian, Persian (Farsi), Serbian, Slovak, Ukrainian and Vietnamese
    • Allow the translation of language names
    • Synchronized translations with crowdin
  • External Components:
    • Updated Maven exec plugin to 1.4.0
    • Rolled back JNA to 4.1.0, which fixes a playback error
Wolfgan
Re: 6.0.0-b2 and 5.5.0 released
Post by Wolfgan »
Thanks for the release!
squadjot
Post by squadjot »
FFMPEG subtitles position is better now, thank you!
N3phastus
Post by N3phastus »
Very good work !
One Small suggestion, if possible at all, I've like 3 principal folders, like Downloads, Series, Movies. For Series ans Movies, need alphabetical order, but in the downloads, would like to see it by Date ... does somebody else think it's important ? Cheers
N3
Paradox
Post by Paradox »
N3phastus wrote:Very good work !
N3
I do not think that would be possible unless you create 2 profiles and have one set to sort by name and the other by date. Which IMO will become a PITA.
A far easier but not full solution is inside your downloads folder create other folders such as January, February, March etc and place the downloads by month you download into the appropriate folders. Or if you download hundreds of files daily name folders such as 20160108 (IE <<< Jan 8th 2016) The other way you can do it is 4 folders for each month IE Jan Week 01, Jan Week 02 etc etc.
The downside to this is it obviously depends on you maintaining your downloads folder and copying the files into the appropriate folders. It will allow you to have one folder sorted by date (kinda) though.
Supermanfan77
Post by Supermanfan77 »
N3
I prefer alphabetical. I usually know what my new downloads are and when they were downloaded.
biger
Post by biger »
Unfortunately, the Hungarian language is missing from the selection menu :(.
biger wrote:Unfortunately, the Hungarian language is missing from the selection menu :(.
This is not a bug. There's a minimum number of translations that's required for languages to show up in the list. Currently this is at 20%, although I think we should raise it some in the future. The idea is that when too little of the language is translated, it's more annoying than useful to users. But, I can see that we have gotten quite a few Hungarian translations already (it's currently 43% translated), so it will be in the list in the next release.
PMcNally
Post by PMcNally »
The language selection prompt is showing up every time UMS opens
PMcNally wrote:The language selection prompt is showing up every time UMS opens
It's only supposed to show up until you select something. What are you selecting?
