LG 42LB671v can't play files with transcode
I cant get file playing on my TV, everything is fine till point I start movie from TV, screen goes black with waiting pointer and wait and wait....movie never start
This what I see in log:
09:53:05 INFO Process C:\Program Files\Universal Media Server\win32\ffmpeg.exe has a return code of 1! Maybe an error occurred... check the log file
09:53:08 INFO Started playing Inside.Out.2015.1080p.3D.BluRay.Half-SBS.x264.DTS-WiKi.mkv on your [LG] webOS TV
When I go to #--transcode--# folder it play file with no transcode in name, video goes just fine but there no subtitles. There a log file from this trials:
12:07:01 INFO Started playing Inside.Out.2015.1080p.3D.BluRay.Half-SBS.x264.DTS-WiKi.mkv on your [LG] webOS TV
12:07:22 INFO Stopped playing Inside.Out.2015.1080p.3D.BluRay.Half-SBS.x264.DTS-WiKi.mkv on your [LG] webOS TV
12:07:28 INFO Exception in thread "ffmpeg.exe-134-1" java.lang.NullPointerException
12:07:28 INFO at net.pms.io.OutputBufferConsumer.run(OutputBufferConsumer.java:55)
12:07:28 INFO Started playing Inside.Out.2015.1080p.3D.BluRay.Half-SBS.x264.DTS-WiKi.mkv on your [LG] webOS TV
12:07:29 INFO Process C:\Program Files\Universal Media Server\win32\ffmpeg.exe has a return code of 1! Maybe an error occurred... check the log file
12:07:33 INFO Stopped playing Inside.Out.2015.1080p.3D.BluRay.Half-SBS.x264.DTS-WiKi.mkv on your [LG] webOS TV
12:07:36 INFO The file I:\DivXMovies\Borba za Britaniju\film.jpg could not be parsed. It will be hidden
12:08:22 INFO Exception in thread "ffmpeg.exe-135-1" java.lang.NullPointerException
12:08:22 INFO at net.pms.io.OutputBufferConsumer.run(OutputBufferConsumer.java:55)
12:08:22 INFO Process C:\Program Files\Universal Media Server\win32\ffmpeg.exe has a return code of 1! Maybe an error occurred... check the log file
12:08:24 INFO Started playing The_Road.avi on your [LG] webOS TV
12:08:28 INFO Stopped playing The_Road.avi on your [LG] webOS TV
12:08:50 INFO Started playing The_Road.avi on your [LG] webOS TV
12:09:09 INFO Stopped playing The_Road.avi on your [LG] webOS TV
12:10:05 INFO Started playing Inside.Out.2015.1080p.3D.BluRay.Half-SBS.x264.DTS-WiKi.mkv on your [LG] webOS TV
12:11:01 INFO Stopped playing Inside.Out.2015.1080p.3D.BluRay.Half-SBS.x264.DTS-WiKi.mkv on your [LG] webOS TV
How to play files with externals subtitles, this already working with some others DLNA servers (Serviio, LG SmartShare) with UMS ?
Re: LG 42LB671v can't play files with transcode
This is list of supported formats from TV:
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO
http-get:*:image/png:DLNA.ORG_PN=PNG_TN
http-get:*:image/png:DLNA.ORG_PN=PNG_SM_ICO
http-get:*:image/png:DLNA.ORG_PN=PNG_LRG_ICO
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/mp3:*
http-get:*:audio/mpeg:*
http-get:*:audio/wav:*
http-get:*:audio/mpeg3:*
http-get:*:video/x-ms-wmv:*
http-get:*:video/x-ms-asf:*
http-get:*:video/x-ms-avi:*
http-get:*:video/mpeg:*
http-get:*:video/avi:*
http-get:*:video/mp4:*
http-get:*:video/x-matroska:*
http-get:*:image/jps:*
http-get:*:image/x-jps:*
http-get:*:image/mpo:*
http-get:*:image/png:*
http-get:*:image/bmp:*
http-get:*:image/jpeg:*
http-get:*:audio/x-wav:*
http-get:*:audio/wma:*
http-get:*:audio/x-ogg:*
http-get:*:video/mts:*
Not sure what the problem is.
Is the TV recognized correctly by UMS? , what conf does it use? LG-WebOS.conf?
What happens if you force the samsung config from this post on to your TV viewtopic.php?f=5&t=4075
Remember to restart UMS to see the effect of forced render config.
The reason i want you to try is that, it seems the TV is able to play MKV's, but MKV is not listed as a "supported format" in the LG-WebOS.conf
I have two detection of same TV. Same IP adress.
One is [LG]WebOSTV.conf and another I have LG-LA6200.conf. How I can tell witch UMS using ?
Seems like it's the LG-WebOS.conf
