Missing MIDI File
Missing MIDI File
This is a continuation of my previous post regarding MIDI files. I have followed the instructions as defined in the "Problem Reporting" Guidelines" but it should be noted that I cannot reproduce the bug as I cannot access the MIDI file from within Firefox as the file is NOT displayed in the list of music files. It is the missing MIDI file that I am asking about.
- (153.07 KiB) Downloaded 329 times
Re: Missing MIDI File
It's no bug. UMS won't display files that's not supported.
I've previously experimented with MIDI (it's easy enough to make UMS consider MIDI a valid format and stream it), but none of the renderers I tried could play it. If you want to playback those files via DLNA, render them into an audio format using a quality MIDI renderer and use that format for sharing.
