UMS vs Samsung LE46C630
I have recently discovered the PMS was not dead. After trying Serviio, not convince at all, I have look at PMS forum and found UMS. Thanks to have continued this software, very appreciated.
I have two issues questions for you:
- When I read the following audio file, my TV reset!!! Can anyone test it on another TV and with the same TV? Or tell me what is wrong with this MP3?
- Is it possible, and how, to create a playlist easyly?
Thanks for your support
Rmanal
Rmanal
Re: UMS vs Samsung LE46C630
Audio link: https://www.cloud.sfr.fr/?shareObject=3 ... 7461e6ed7e
UMS logfile:
UMS logfile:
10:34:37 DEBUG Sending ALIVE...
10:34:49 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:49 DEBUG Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
10:34:50 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:50 DEBUG Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
10:34:52 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:52 DEBUG Invalid action in SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
10:34:53 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:54 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:55 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:56 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:57 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:58 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:59 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:34:59 INFO Started playing 01-She's In Parties.mp3 on your TV-46C630
10:34:59 DEBUG The full filename of which is: G:\01-She's In Parties.mp3 and the address of the renderer is: 192.168.1.58
10:34:59 DEBUG Connection error: java.io.IOException: Une connexion existante a dû être fermée par l'hôte distant
10:34:59 DEBUG Premature end, stopping...
10:35:04 DEBUG Matched media renderer "TV-46C630" based on address /192.168.1.58
10:35:04 INFO Stopped playing 01-She's In Parties.mp3 on your TV-46C630
10:35:04 DEBUG The full filename of which is: G:\01-She's In Parties.mp3 and the address of the renderer is: 192.168.1.58
10:35:04 DEBUG adding "01-She's In Parties.mp3" to playlist "Joué récemment"
I can't find a way to download the mp3 file, and I don't understand french. What do I do to download the file?
The log you have pasted doesn't help much. Please follow the text in red above on how to post debug files.
In uppper left corner press the "telecharger" buttonNadahar wrote:I can't find a way to download the mp3 file, and I don't understand french. What do I do to download the file?
I did, nothing happened. Is it working for you?
edit: Ok, I tried IE instead of Firefox, and then it downloaded.
I can't find anything special about the MP3 file except that it's VBR. "Most" MP3's are CBR, but VBR isn't exactly rare. Still, it could be that the TV can't handle VBR.
I'd guess that this file is streamed and not transcoded, in which case UMS just delivers the file to the TV and the problem must be in the TV's end, but there's no way to know without the debug files.
One thing, mediainfo does not seem to get the "duration"
When i play the file with VLC, it plays fine.. but the time display is acting weird.
You mean the file could have been badly coded?
For my info, for MP3 with Samsung conf file, there is no transcoding?
How can I retrieve what is transcoded: I have a look in the samsung conf file but it is harder to understand that Chinese
Could bermanal wrote:You mean the file could have been badly coded?
One way is to untick "Do not add engine names to filenames" on the Navigation/Share Settings tab in UMS.rmanal wrote:How can I retrieve what is transcoded
If the filename does not have either "FFMPEG" or "MEncoder" added to the filename..the file is streamed as is.
It's normal that duration is acting up using VBR. I don't think there are timestamps in MP3, so the application will have to try to estimate the duration from the current or average bitrate and the file size. That's why I'm saying this could be the cause; that the TV simply doesn't support VBR MP3.
To find out if it's transcoding or not, follow the red text on top of the page and post debug files.
