[Fixed] error message no renderer were found
I used to get the software to work fine, all of the sudem it stop working and gives me this error message @ no renderes were found
The tv is the same, nothing has changed, anyone has a clue what happened?
I am on windows 8
I am on windows 8
Re: error message no renderer were found
this is the log
02-16 08:16:56 Starting Universal Media Server 2.4.1
02-16 08:16:56 Based on PS3 Media Server by shagrath, copyright 2008-2012
02-16 08:16:56 http://www.universalmediaserver.com
02-16 08:16:56
02-16 08:16:56 Build: eae29ed14 (2013-02-15)
02-16 08:16:56 Java: 1.7.0_13-Oracle Corporation
02-16 08:16:56 OS: Windows 8 64-bit 6.2
02-16 08:16:56 Encoding: UTF-8
02-16 08:16:56 Memory: 742 MB
02-16 08:16:56
02-16 08:16:56 Working directory: C:\Program Files (x86)\Universal Media Server
02-16 08:16:56 Temp directory: C:\Users\Home\AppData\Local\Temp\universalmediaserver
02-16 08:16:56 Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
02-16 08:16:56 debug.log: C:\Program Files (x86)\Universal Media Server\debug.log
02-16 08:16:56
02-16 08:16:56 Profile directory: C:\ProgramData\UMS
02-16 08:16:56 Profile path: C:\ProgramData\UMS\UMS.conf
02-16 08:16:56 Profile permissions: rw
02-16 08:16:56 Profile name: Home-PC
02-16 08:16:56
02-16 08:16:56 Loading MediaInfo library
02-16 08:16:56 Loaded MediaInfoLib - v0.7.61
02-16 08:16:56 Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
02-16 08:16:56 Loading configuration file: AirPlayer.conf
02-16 08:16:56 Loading configuration file: Android.conf
02-16 08:16:56 Loading configuration file: Bravia4500.conf
02-16 08:16:56 Loading configuration file: Bravia5500.conf
02-16 08:16:56 Loading configuration file: BraviaEX.conf
02-16 08:16:56 Loading configuration file: BraviaEX620.conf
02-16 08:16:56 Loading configuration file: BraviaHX.conf
02-16 08:16:56 Loading configuration file: DirecTVHR.conf
02-16 08:16:56 Loading configuration file: DLinkDSM510.conf
02-16 08:16:56 Loading configuration file: FreeboxHD.conf
02-16 08:16:56 Loading configuration file: FreecomMusicPal.conf
02-16 08:16:56 Loading configuration file: iPad-iPhone.conf
02-16 08:16:56 Loading configuration file: Kuro.conf
02-16 08:16:56 Loading configuration file: LGST600.conf
02-16 08:16:56 Loading configuration file: N900.conf
02-16 08:16:56 Loading configuration file: OPPOBDP83.conf
02-16 08:16:56 Loading configuration file: OPPOBDP93.conf
02-16 08:16:56 Loading configuration file: Panasonic.conf
02-16 08:16:56 Loading configuration file: Philips.conf
02-16 08:16:56 Loading configuration file: PhilipsPFL.conf
02-16 08:16:56 Loading configuration file: PopcornHour.conf
02-16 08:16:56 Loading configuration file: PS3.conf
02-16 08:16:56 Loading configuration file: Realtek.conf
02-16 08:16:56 Loading configuration file: Samsung-SMT-G7400.conf
02-16 08:16:56 Loading configuration file: SamsungAllShare.conf
02-16 08:16:56 Loading configuration file: Samsungtv.conf
02-16 08:16:56 Loading configuration file: SamsungWiseLink.conf
02-16 08:16:56 Loading configuration file: SharpAquos.conf
02-16 08:16:56 Loading configuration file: Showtime3.conf
02-16 08:16:56 Loading configuration file: Showtime4.conf
02-16 08:16:56 Loading configuration file: SMP-N100.conf
02-16 08:16:56 Loading configuration file: SonyBluray.conf
02-16 08:16:56 Loading configuration file: Streamium.conf
02-16 08:16:56 Loading configuration file: VideoWebTV.conf
02-16 08:16:56 Loading configuration file: VizioSmartTV.conf
02-16 08:16:56 Loading configuration file: WDTVLive.conf
02-16 08:16:56 Loading configuration file: WMP.conf
02-16 08:16:56 Loading configuration file: XBMC.conf
02-16 08:16:56 Loading configuration file: XBOX360.conf
02-16 08:16:56 Loading configuration file: YamahaRXA1010.conf
02-16 08:16:56 Loading configuration file: YamahaRXV671.conf
02-16 08:16:56 Please wait while we check the MPlayer font cache, this can take a minute or so.
02-16 08:16:56 Finished checking the MPlayer font cache.
02-16 08:16:56 VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
02-16 08:16:56 Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
02-16 08:16:56 Found plugin: net.pms.external.Gs_plugin
02-16 08:16:56 Found plugin: net.pms.movieinfo.MovieInfo
02-16 08:16:56 Found plugin: com.sharkhunter.channel.CH_plugin
02-16 08:16:56 Registering transcoding engine: AviSynth/FFmpeg
02-16 08:16:56 Registering transcoding engine: FFmpeg Audio
02-16 08:16:56 Registering transcoding engine: MEncoder
02-16 08:16:56 Registering transcoding engine: AviSynth/MEncoder
02-16 08:16:56 Registering transcoding engine: MPlayer Audio
02-16 08:16:56 Registering transcoding engine: FFmpeg Web Video
02-16 08:16:56 Registering transcoding engine: MEncoder Web
02-16 08:16:56 Registering transcoding engine: MPlayer Video Dump
02-16 08:16:56 Registering transcoding engine: MPlayer Web
02-16 08:16:56 Registering transcoding engine: tsMuxeR
02-16 08:16:56 Registering transcoding engine: Audio High Fidelity
02-16 08:16:56 Executable of transcoder profile VLC Audio Streaming not found
02-16 08:16:56 Executable of transcoder profile VLC Video Streaming not found
02-16 08:16:56 Registering transcoding engine: FFmpeg DVR-MS Remux
02-16 08:16:56 Registering transcoding engine: dcraw Thumbnailer
02-16 08:16:59 Gs 0.50 using path C:\Users\Home\AppData\Local\Temp\universalmediaserver\gs_plugin tiny mode false init delay 3000 zero_fill false
02-16 08:16:59 Start channel 2.06
02-16 08:16:59 Configuration saved to: C:\ProgramData\UMS\UMS.conf
02-16 08:16:59 Using localhost address
02-16 08:16:59 Created socket: 0.0.0.0/0.0.0.0:5001
02-16 08:16:59 Using the following UUID configured in UMS.conf: 80f84600-c3aa-4f54-819d-2350bd5a3f68
02-16 08:17:03 The server is now available for renderers to find
Choose correct network interface in GUI:
do i have to do something on the firewall?
i am changing the network interface on GUI general cofiguration>force network on interface and i am checking the same network adapter as my wifi connection .
nothing so far
02-16 14:40:34 Configuration saved to: C:\ProgramData\UMS\UMS.conf
02-16 14:40:34 Disconnecting HTTP server from renderers
02-16 14:40:37 Stopping server on host 192.168.199.121 and port 5001...
02-16 14:40:38 Using localhost address
02-16 14:40:38 Created socket: 0.0.0.0/0.0.0.0:5001
02-16 14:40:45 Configuration saved to: C:\ProgramData\UMS\UMS.conf
02-16 14:40:46 Disconnecting HTTP server from renderers
02-16 14:40:50 Stopping server on host 192.168.199.121 and port 5001...
02-16 14:40:51 Using localhost address
02-16 14:40:51 Created socket: 0.0.0.0/0.0.0.0:5001
02-16 14:41:01 Configuration saved to: C:\ProgramData\UMS\UMS.conf
02-16 14:41:01 Disconnecting HTTP server from renderers
02-16 14:41:06 Stopping server on host 192.168.199.121 and port 5001...
02-16 14:41:07 Using localhost address
02-16 14:41:07 Created socket: 0.0.0.0/0.0.0.0:5001
nothing so far
You should make sure port 5001 is forwarded in your router settings.sidneyns wrote:do i have to do something on the firewall?
And you should also go to the General Configuration tab > Network settings (advanced) > Force networking on interface: and pick the network card of the computer you're running UMS on.
Also under that option, you can change Force IP of the server: to your UMS server's network card's IP address just to be safe (IE: 192.168.100.1).
Click save after that and then quit UMS and reload it. Hopefully that fixes your issue.
天 黒影 天
you are a genius..thank you
Thank you kind sir.sidneyns wrote:you are a genius..thank you
天 黒影 天
