UMS having problems with Java 1.7u5
After updating both UMS to the latest 1.1.1 and Java 7 to u5, I have this in my debug (after investigating why nothing would play on my ps3)
After this, nothing was playable, even when selecting AVISynth.
DEBUG 2012-06-14 20:14:53.522 [New I/O server worker #2-3] Caught exception
java.lang.NumberFormatException: For input string: "52855upnpeventcontent_directory"
at java.lang.NumberFormatException.forInputString(Unknown Source) ~[na:1.7.0_05]
at java.lang.Integer.parseInt(Unknown Source) ~[na:1.7.0_05]
at net.pms.network.RequestV2.answer(RequestV2.java:703) ~[ums.jar:na]
at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:313) ~[ums.jar:na]
at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:271) ~[ums.jar:na]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:148) ~[ums.jar:na]
at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) ~[ums.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) ~[ums.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndfireMessageReceived(ReplayingDecoder.java:522) ~[ums.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) ~[ums.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) ~[ums.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) ~[ums.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) ~[ums.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) ~[ums.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) ~[ums.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) ~[ums.jar:na]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_05]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_05]
at java.lang.Thread.run(Unknown Source) [na:1.7.0_05]
Re: UMS having problems with Java 1.7u5
Hi orgon3 I'm using JRE7u5 so I don't think that is the problem. I have a version here to try that will give me more information as to why that's happening, please give the whole debug.log using this version, link.
Also, can you see if it happens with earlier versions of UMS too?
