Plugin for the HDhomerun for OTA stream
Been toying with this, be nice if there was a media server out there that could transcode from a HDhomerun tuner to a device. Know they're working on adding DLNA support to the Prime right now and according to their technical support a new HDhomerun dual with DLNA will be out this year as well. Would love to find an OTA solution that could be networked to all my TVs from one antenna as I have some with no tuners built in.
,____
||_|__\\__
|(0)___(o)|
||_|__\\__
|(0)___(o)|
Re: Plugin for the HDhomerun for OTA stream
Soooo let me see if i understand this request.
You want the Output from the HDhomerun Prime box, to be an input (some how into UMS... channel? or folder?) to UMS to stream to your other devices?
I think this thing is a hardware version of what UMS is... But for only like.. cablecard ONLY...
If your TV or DLNA device detects it from say "sources" menu then i would use that and bypass the UMS...
Kind of interesting device really...
Universal Media Server Wiki!
Bump on this request.
There already appears to be ways of doing this using ffmpeg and VLC. This is a snapshot of the source code for another project out there called hdhomerunstreamserver on github (https://github.com/zaren678/HdhomerunSt ... reamServer). Below is a snapshot of the code that does the heavy lifting. Keep in mind this is c# .Net, but should easily be adapted to Java.
private string buildVlcArguments()
StringBuilder cmdList = new StringBuilder();
//cmdList.Append("--file-logging ");
//cmdList.Append("--log-verbose=-1 ");
//cmdList.Append("--logmode=html ");
//cmdList.Append("--logfile=" + System.IO.Directory.GetCurrentDirectory() + "\\log.html ");
cmdList.Append("--no-crashdump ");
cmdList.Append("--sout-ffmpeg-strict=-2 ");
cmdList.Append("-V dummy ");
cmdList.Append("-I dummy ");
cmdList.Append("-vvv ");
cmdList.Append("udp://@:" + VideoInputPort + " ");
cmdList.Append("--audio-desync=-50 ");
//cmdList.Append("--network-caching=4096 ");
//cmdList.Append("--udp-caching=4096 ");
cmdList.Append("--no-sout-rtp-sap ");
cmdList.Append("--sout-rtp-caching=3000 "); //TODO supposedly should do something with this for different bitrates but not sure what yet
cmdList.Append("--sout-rtp-sdp=rtsp://:" + VideoOutputPort + "/stream.sdp ");
cmdList.Append("--sout-rtp-mp4a-latm ");
cmdList.Append("--sout-transcode-threads=" + Environment.ProcessorCount + " " );
cmdList.Append("--sout-transcode-high-priority ");
cmdList.Append("--sout-keep ");
cmdList.Append("--sout-transcode-venc=x264 ");
cmdList.Append("--sout-x264-profile=baseline ");
cmdList.Append("--sout-x264-level=3 ");
cmdList.Append("--sout-x264-keyint=50 ");
cmdList.Append("--sout-x264-bframes=0 ");
cmdList.Append("--no-sout-x264-cabac ");
cmdList.Append("--sout-x264-ref=1 ");
cmdList.Append("--no-sout-x264-interlaced ");
cmdList.Append("--sout-x264-vbv-maxrate=" + BitRate + " ");
cmdList.Append("--sout-x264-vbv-bufsize=" + Math.Round((decimal)BitRate / 2) + " ");
cmdList.Append("--sout-x264-aq-mode=0 ");
cmdList.Append("--no-sout-x264-mbtree ");
cmdList.Append("--sout-x264-partitions=none ");
cmdList.Append("--no-sout-x264-weightb ");
cmdList.Append("--sout-x264-weightp=0 ");
cmdList.Append("--sout-x264-me=dia ");
cmdList.Append("--sout-x264-subme=0 ");
cmdList.Append("--no-sout-x264-mixed-refs ");
cmdList.Append("--no-sout-x264-8x8dct ");
cmdList.Append("--sout-x264-trellis=0 ");
cmdList.Append("--sout-transcode-vcodec=h264 ");
cmdList.Append("--sout-transcode-vb=" + BitRate + " ");
cmdList.Append("--sout-transcode-vfilter=canvas ");
cmdList.Append("--canvas-width=" + ResH + " ");
cmdList.Append("--canvas-height=" + ResV + " ");
cmdList.Append("--canvas-aspect=" + ResH + ":" + ResV + " ");
cmdList.Append("--canvas-padd ");
//cmdList.Append("--canvas-pAppend ");
cmdList.Append("--sout-transcode-soverlay ");
cmdList.Append("--sout-transcode-aenc=ffmpeg ");
cmdList.Append("--sout-ffmpeg-aac-profile=low ");
cmdList.Append("--sout-transcode-acodec=mp4a ");
cmdList.Append("--sout-transcode-samplerate=44100 ");
cmdList.Append("--sout-transcode-ab=128 ");
cmdList.Append("--sout-transcode-channels=2 ");
cmdList.Append("--sout-transcode-audio-sync ");
cmdList.Append("--sout ");
cmdList.Append("#transcode{}:rtp{}");
System.Console.WriteLine(cmdList.ToString());
return cmdList.ToString();
Also, there is a Mac version of a realtime h.264 transcoder available here. https://www.silicondust.com/forum2/view ... ng#p106710
