Problem with 2015 SAMSUNG TV
M.Sadegh.M
Post by M.Sadegh.M »
Hi
thank you for your great program.
I have a samsung tv with this model number :
UA48JU6000
- in this tv when i want to play from UMS and select a file from library and then tap play bottom noting happened on tv.
- but when i use tv and select UMS from input source i can explore and play media.
how could i fix this?
what's the solution?
another question:
how could i add font to UMS , specially persian font.
which type of java is more compatible with UMS? X64 or X32
Java 7 or 8?
my operarion system is X64.
thank you so much. :D
(38.52 KiB) Downloaded 490 times
