[Solved] Video Scaler not working :-(
tkoucinauci
Post by tkoucinauci »
Hi, i just installed Universal Media Server 2.5.2.1 (using for years ps3 MS your subjunk build 1.50.2-SB62 version with Panasonic G20 TV), still works great, but i can see now that UMS is even better, fast forward works! :D
Only problem in UMS I have: video scaler not work at all. I put in MEncoder settings: Use video scaler: Width:1920 Height:1080, and even checked Panasonic.conf file and there is: MaxVideoWidth=1920 MaxVideoHeight=1080, still no change in overscan...
All SD videos look pretty ugly, and that includes subtitles...
In a log file, is say that video is using video scaler 1920x1080 but that is not the case...
Is there a solution for this problem?
Txs!
Re: Video Scaler not working :-(
Please post your debug info so I can help :) viewtopic.php?f=9&t=556
tkoucinauci
Txs SubJunk, here is debug info...
(39.78 KiB) Downloaded 549 times
Thanks for the info, I think I have fixed it now. Please try this version:
http://www.spirton.com/uploads/UMS/UMS-tkoucinauci.exe
tkoucinauci
Re: [Solved] Video Scaler not working :-(
Thanks SubJunk, thanks! :D
In this version video scaler works! Please add this fix in new versions... Once more, txs for a great support!
Now i have stuttering problems, but i will test it more, and try my old Panasonic .conf file. I will post result, but video scaler is fixed! :mrgreen:
