Renderer's gui panel not working with Panasonic Viera
Sami32
Post by Sami32 »
sorry for the formulation but i don't really know how to name it, maybe Control Panel ?
Whatever, the photos are more easy to understand ;)
UMS 5.5.0 ==> working
UMS 6.0.0 and later ==> not displaying ( the little window in the left up corner when resized only give an empty window )
ums_dbg_6.0.0.zip
(25.51 KiB) Downloaded 604 times
Sami32
Re: Renderer properties not displayed since UMS 5.5.0
Post by Sami32 »
Oh i didn't know that...it is limited to 3 attachements by message.
ums_dbg_5.5.0.zip
(30.81 KiB) Downloaded 645 times
P.S. I did a clean install every times.
EDIT : Work in progress, @Skeptical did make the GUI displaying all the time and sometime working ;-)
https://github.com/UniversalMediaServer ... issues/880
Madoka
Re: Renderer properties not displayed after UMS 5.5.0
Post by Madoka »
Hmm, I'm running 6.2.2 on 64-bit Windows 7, and I get the control panel on UMS. What confuses me is that sometimes I get the scrolling name of the file I'm playing and sometimes I don't.
Sami32
Post by Sami32 »
Lucky you are ;) I am on Windows XP SP3 and i just get an little empty windows :?
If you mean that when you are playing the same file, sometimes the tittle is scrolling and sometimes not, it's weird.
Did you have the same problem with UMS anterior version ?
Madoka
Re: Renderer's gui panel not displayed after UMS 5.5.0
Post by Madoka »
Ah, we're not on the same OS.
What I mean on my problem is that sometimes when I start UMS and play any number of files, the name never scrolls across; it's just blank. And other times I start UMS, they will, and it will work for as long as I have UMS running that session (before shutting off or rebooting). It's been happening for many, many versions now. I may have finally tracked it down today. I had thought UMS and to be running before turning on the PS3, UMS didn't like IE11 running concurrently, etc, but that wasn't it.
If I have Windows Mail open when I start UMS, it will not scroll. I can quit UMS and WinMail, then restart UMS and it will scroll again. I will do more testing, but I managed to get it going from not working to working so that's good.
