[SOLVED].MPG and .TS records files don't stream without transcoding
i am not able to stream .MPG files without transcoding on my Panasonic TV, but they are playing fine with my USB key.
And .TS files coming from my recorder (H264-EAC3-Teletext-Audio channels) are not streamed as well.
EDIT : The .TS and .M2TS files make with a converter tools are streaming fine though.
EDIT 2 : I use UMS 5.5.0 with MediaInfo.dll 0.7.83 and UMS 6.2.0 (but without working Renderer's GUI panel) since the later versions are not working fine for me, so i apologize if these problems was solved in the latest version.
TS file put on WeTransfer : (17MB; valid until 24 april )
https://www.wetransfer.com/downloads/d1 ... 840/c4f181
Re: .MPG files and .TS records files don't stream
TS files records was M2TS files with a TS extension, but the main problem was that some M2TS ( 192 byte packets ) are not supported for streaming by my TV, but i am not able to know what caracteristic of the M2TS are giving problems...
So i will just play them in plugging my USB key.
