Problem with MKV - Transcoding
jbonbeurre
Re: Problem with MKV - Transcoding
Post by jbonbeurre »
Here is the log in trace mode.
When I try to play the movie through UMS, UMS decode it and noting appears on the TV screen. He's all black.
I can read it without problem from an USB key.
UMS try to transcode with ffmpeg.
Here is also a screen capture of MediaInfo.
Not OK.jpg (126.04 KiB) Viewed 7782 times
How can I just say to never transcode anything or some extensions (mkv, avi, ...)
Thank you for your help
(427.92 KiB) Downloaded 432 times
valib
Post by valib »
The video is transcoded because it has embedded subtitles. You can go to the TRANSCODE folder and choose the [No Transcoding] for the video and test it.
jbonbeurre
Thank you.
I will try but how can I do to never transcode anything (with or without subtitles).
I try : StreamExtensions = avi,divx,mp4,mkv,ts,mts,m2ts,mpg,mpeg,mp3 in the SonyBraviaW.conf but that doesn't work.
valib
Post by valib »
In that case you have to also set MediaInfo = false
jbonbeurre
Thanks for your help
