XBOX360 AVI playback problems
slyphnier
Post by slyphnier »
hello everyone
i am not sure since when, but before (ums 5?) avi playback is working fine
until recently i cant no longer fast forward or jump
if i use fast forward or jump, it will return to begining of movie
the time lapse also not right, its like 453hours?(maximum time?)
it play fine, but its pretty useless without fast forward or backward function
i tried from old avi to latest reencode avi... all have same issue/behaviour
how to fix this ?
Re: XBOX360 AVI playback problems
Hi slyphnier, please try old versions and let us know the last version that worked properly, and give logs for that version and a newer one. Old versions can be downloaded at https://sourceforge.net/projects/unimed ... s/Windows/
Then we can see exactly what needs to change
slyphnier
Post by slyphnier »
ok i did reinstall all way back to version 5
then try step by step to new version up to ver. 6.0.0 and it still working properly
so there some changes after 6.0.0 that causing issue
sorry i didnt save log, but i believe devs. can simply replicate the issue, as it effect any AVI files
well i will stay on 6.0.0 for now
thanks
