[PS3/PS4] No Mkv after the Java Update
veeto
Post by veeto »
After some years i've finally update the software and the Java Plugin, now all the formats works expect the MKVs. Both in PS3 and PS4.
This is my version oj Java:
Java(TM) Platform SE 8 U91 11.91.2
and
Java Deployment Toolkit 8.0.910.15
erick diangilis
Re: [PS3/PS4] No Mkv after the Java Update
Post by erick diangilis »
hi which version of the ums you have installed ? is the java 8 or 7 ums ? about the java you can pick this one 8.92 it is a patch for the 8.91 just accept the license agreement and download an official 8.92 acording to your system here's the link to download.
http://www.oracle.com/technetwork/java/ ... 33155.html.
i hope it helps have a good day. ;)
ps: providing logs can also help the developers that work on the ums to find a solution to your problem keep that in mind.
Like erick said, we need logs :)
