GC issues with Java 1.7.0 u 21 (32 bit; Linux)
Optimus_prime
Re: GC issues with Java 1.7.0 u 21 (32 bit; Linux)
Post by Optimus_prime »
Nice Subjunk, I'd only just got my Linux VM setup when i saw your reply. It just show's i'm just an amateur compared to you :D
I just got lucky, some bugs take me months to diagnose/fix. Thanks though!
elsabio
Post by elsabio »
Yes indeed, thank you for confirming my original contention that this is a jvm issue and not (at least directly) a problem with ums.
Ums video is getting rapidly better; thank you for all the continuing activity, attention and hard work on this very important and pretty unique project.
I still have some problems with high quality audio streaming - which I touched on elsewhere, but now I have been encouraged to install this software on a development machine to investigate the jvm dependency, maybe I'll look into that a bit deeper rather than rely on the upnp plugin for my old Squeezebox (Perl-based) server.
Thanks again.
Mark.
Great, you might also want to check out our latest code (which we will be releasing soon, maybe later today as 3.0a1) because we added much better iTunes integration. I doubt it will fix any playback issues but it allows you to browse your iTunes library by artist, album and genre folders.
elsabio
Post by elsabio »
I'll do that ... though I don't use iTunes, for the most part I'm Linux based (though I have over 10 years Java experience, since 1.1.8, so I'll give it my best shot when I get some time to devote to it.)
Optimus_prime
More help the better, elsabio.
