UMS wont connect while using PIA
Knowl3dge
Post by Knowl3dge »
SO THIS IS AN OFF AND ON ISSUE!!!
I have installed PIA and now UMS has connection issues with my Samsung television. It was working fine up until the latest update. In the past I have uninstalled PIA and reinstalled and everything works fine. It seems that there should be something I can do to make both work together but I'm at a loss.
(28.51 KiB) Downloaded 452 times
BlearySteve
Re: UMS wont connect while using PIA
Post by BlearySteve »
Did anyone ever get back to you about this.
What's PIA?
squadjot
Post by squadjot »
I think it stands for Private Internet Access / VPN
BlearySteve
For me they where working together fine until about 3 days ago.
Darth Ed
Post by Darth Ed »
Try this:
Go to the "General Configuration" tab and locate the "Force networking on interface:" setting under the "Network settings (advanced)" section. Change that setting to "en0 (your LAN IP address)". Then quit and re-launch. If that doesn't work, keep trying any of the settings listed there besides "en0".
BlearySteve
Don't have a selection for eno but I tried whatever was there and nothing worked.
