How do I know that only I can access UMS?
adam1992p
Post by adam1992p »
I'm getting a lot of media renderers that I definitely don't own and are probably my neighbors. What I need to know is whether or not these unknown renderers have the same access to my PC that I do? How can I be certain that only I'm accessing my files and nobody else? Thanks for your help.
squadjot
Re: How do I know that only I can access UMS?
Post by squadjot »
On the "General configuration" tab, you can add IP whitelist.
Read more about more security options UMS here: viewtopic.php?t=2266
Edit: Be ware that the IP of the device can change. You CAN instead do some filtering by uuid : viewtopic.php?f=9&t=8558
