UMS Cannot find renderers (XboxOne, Xbox 360, and PS3)
I have been using UMS for quite awhile now and have run into an issue where the program doesn't find a renderer. It used to find my XboxOne immediately when I start the program but now it doesn't find even my Xbox 360 or my PS3. I have attached the logs and what I see in the configuration screen as well as the status screen. Thanks for any help.
- 2016-08-22.png (22.87 KiB) Viewed 5144 times
- 2016-08-22 (2).png (86.09 KiB) Viewed 5144 times
- 2016-08-22 (1).png (45.68 KiB) Viewed 5144 times
Re: UMS Cannot find renderers (XboxOne, Xbox 360, and PS3)
Try hitting http:192.168.1.9:9001 directly from you renderer. Seems like a network path issue.
I can confirm, having similar issues. Hitting from any renderer (including a box below another switch) can access the webpage, but there is no content available.
Edit: For whatever reason, it's now connecting to some renderers & media is available (loopback and network). Still won't pick up the PS3
Edit2: Figured it out. Turns out my router had a default uPNP filter that interfered. Cleared the table and things worked.
- (63.6 KiB) Downloaded 409 times
