Remote UMS access from BubbleUPNP
I have a bit of an issue using UMS via BubbleUPNP from my Android devices. Here's how the error happens.
I connect to my home server remotely via Bubble. UMS shows up just fine. All of my shared folders show. However, none of the folder's contents do. To fix it, I log into my PC remotely and quit, then restart UMS. Immediately after that, my files show in BubbleUPNP no problem. I'm not sure which application is at fault here, I only know that the issue is fixed after a UMS restart.
None of my UMS settings seem to affect this behavior. Also, my WMS server doesn't have this issue, which almost rules out BubbleUPNP. There are no errors by any application. No access issues. I just have to quit and then restart UMS. I'm hoping there is a setting in UMS that will address the issue.
Any ideas?
** edit **
After restarting my tablet AFTER restarting UMS, everything showed up just fine across all of my Android devices. Perhaps the issue might be that these devices are logged out or denied access after a certain amount of time passes? I'll continue to test and be sure.
Any ideas?
** edit **
