Samsung Link Not Connecting to UMS
I have a Samsung smart TV that was perfectly fine with UMS up until the other day. The TV did an update that appears to have broken something and now it can almost never see UMS and when it does is unable to connect.
I'm going to investigate the TV side a bit more and see if I can downgrade it.
Has anyone else had this issue and if so have you resolved it?
Its seen in UMS fine and I cant see any issues on the server side logs. Appreciate any help.
Re: Samsung Link Not Connecting to UMS
To be able to help you the best way possible, please follow the Problem Reporting Guidelines
viewtopic.php?f=9&t=556
Attached. Not sure how helpful it is though. I couldn't discern anything from it.
- (53.78 KiB) Downloaded 350 times
Hi, I'm having the same issue.
UMS has all my connections showing but my two TVs don't have it showing up anymore.
I had an older version working AMAZING for the longest time and since I had to wipe and re-install Windows 7 Ultimate I haven't had it working which is really a pain.
I'm attaching my log for your help please.
Thanks in advance.
*EDIT*
I figured out what was wrong. I needed to rejoin my network group and also share my folders on my computer.
ROOKIE mistake, OK, really I was just in a hurry to get UMS up and running late last night and wasn't thinking.
Hope this helps others though.
Thanks in advance.
*EDIT*
