Subtitle position not working with FFMpeg
SuperDre
Post by SuperDre »
No matter what I set as margin (px) (default 20), the position op the subtitle (.srt) does not change. (streaming to PS3). I'm using UMS 6.5.0.
Madoka
Re: Subtitle position not working with FFMpeg
Post by Madoka »
You need to have fontconfig active in the FFmpeg settings. Check (on) Use font settings... Then it will use the settings in the Subtitles Tab where you set the margin, color, size.
SuperDre
Post by SuperDre »
aha, it was off, hope it works now..
<edit> Yep it did the trick.. Wonder why it isn't on by default.
