Subtitle Issue - Samsung TV
dbraojos
Post by dbraojos »
Hi there,
I've just upgraded my UMS version from 5.0 to 6.5.1 and I'm afraid I'm facing an issue when adding external subtitles since then.
The external subtitles are added when I play the video from my Samsung TV, but the accents in the text, like 'á' or 'é' are not displayed correctly, and some funny characters, like '%[', appear instead.
I'm forcing spanish subtitles as I configured in the previous UMS version, but I'm afraid the issue still persists. Would you be so kind to review it? I've attached the trace files.
Cheers!
(61.09 KiB) Downloaded 473 times
dbraojos
Re: Subtitle Issue - Samsung TV
Post by dbraojos »
Quick update: I've just re-installed my previous version and the issue is fixed. So for the moment I'll stay in the old version, anyway, it will be nice to get this fixed in the latest one :)
Cheers
Milhouse
Post by Milhouse »
I have same issue with version 6.5.1. and old TV Samsung (with new J serie OK). I try version 6.3.2 and this version is without problem (on both TV). PLEASE fix it in new version!
Jgus
Post by Jgus »
Same problem, Samsung un46d5500 :cry:
fabio5000
Post by fabio5000 »
Hi, I have a samsung D5500 too and Im face the same problem with the subtitles
I tested the old versions and with the version 6.5.0 the subtitles back to work
so, the problem start with the 6.5.1 version
THanks
Sami32
Post by Sami32 »
Hi fabio5000,
that could be related to this commit: https://github.com/UniversalMediaServer ... 6d579ce85e
You'll need to provide a full TRACE log as explained here:
viewtopic.php?f=9&t=556
Do you get this issue only with SRT subtitles external files ? If yes, do that affect all the SRT files ?
