Java problems
Java problems
Each time I start my pc windows 10 UMS does not start. I have to delete java and when I start UMS it will install java again and it works fine. When I shut down my pc and styart it up again. Same problem. A Java erro and ums will not start.
What is the solution?
thx
thx
Re: Java problems
If you have downloaded the latest java version 8 then have you installed ums for java 8.
