x265/HEVC files are not transcoding/playing
I'm trying to play an MKV HEVC file to my samsung ES6100 TV but the UMS for OS X doesn't transcode it to a format that the TV can reproduce.
Tv only shows the information of Video Codec Unknown.
I don't know how to make UMS always force transcode HEVC/x265 files.
the GUI has an option called "Force transcoding for the following extensions (comma separated values)"
I tried setting mkv there but it didn't work anyway.
and I wouldn't like to transcode every kind of MKV, only the h.265/x265 ones, cause my TV doesn't support them
any ideas?
any ideas?
Re: x265/HEVC files are not transcoding/playing
It seem that you didn't read the 3 first comment of the thread:
viewtopic.php?f=9&t=556
So your log is just showing your renderer dtection, not very useful in your case...
Next time read carefully, and generate log only AFTER having met your issue.
To make H.265 video transcode, you just need to modify your renderer configuration file (Samsung-ES6575.conf). Setting only the video codec that are really supportrd by your renderer.
For example:
As long as you don't write h265 in the video codec supported list (v:), they will be transcoded.
For example:
Supported = f:mkv v:h264|mp4|mpeg2 a:aac|aac-he|ac3|dts|dtshd|eac3|lpcm|mp3|mpa|vorbis m:video/x-matroska
Your assumption is correct. "Everything" is transcoded by default, so only format/codec combinations that is specified as SUPPORTED aren't transcoded.
This thread is interesting to me. I need h265 and HEVC transcoded, but when I look in my UMS folder there are no *.conf files other than UMS.conf and VirtualFolders.conf. According to what I read elsewhere the Samsung-***.conf file should be in a separate folder that doesn't exist.
I have a very old Samsung DLNA TV. 11 years old. The model is "Samsung LE40C630K". According to the log it uses the Samsung C/D series.
How would I go about creating the config file in the UMS folder so I can delete h265 and HEVC from the supported list?
You're looking in the wrong place. UMS.conf is found in your "profile folder", the renderer configurations files are found in the UMS installation folder in the "renderers" subfolder.
Yea, I was just directed to the wrong folder by another site. Got the list now. That's what you get for trying on your own.
My next problem is that the "# Supported video formats" section looks very different from the one Sami32 posted. Is that because it's 3 years old?
HEVC and H265 aren't mentioned in Samsung-CD.conf or Samsung-ES6575(which was the example Sami32 used)
instead it looks like this for Samsung-ES6575:
# Supported video formats:
Supported = f:avi m:video/avi
Supported = f:mkv m:video/avi
Supported = f:mov m:video/quicktime
Supported = f:mp4 m:video/mpeg
Supported = f:mpegps|mpegts m:video/mpeg
Supported = f:avi|mkv m:video/avi
Supported = f:flv m:video/mp4
Supported = f:mp4|mpegps|mpegts m:video/mpeg
Actually it is "mentioned" in that since no video codec is specified, all are considered supported for the specified container. So, to fix it, you would have to edit the lines with containers that might contain h265 and explicitly list the codecs that are supported.
Example for Matroska:
The above example assumes of course that the renderer does support h264, MPEG-4 Visual and h264 in Matroska containers. Any MKV that doesn't match this, will be transcoded.
To make it work propertly, you should also consider adding supported audio codecs with something like this:
Supported = f:mkv v:h264|mp4|mpeg2 m:video/avi
To be honest I'm out of my depth, replacing lines without a replace X with Y in Z line instruction:Nadahar wrote: ↑Fri May 29, 2020 1:54 am Actually it is "mentioned" in that since no video codec is specified, all are considered supported for the specified container. So, to fix it, you would have to edit the lines with containers that might contain h265 and explicitly list the codecs that are supported.
Example for Matroska:The above example assumes of course that the renderer does support h264, MPEG-4 Visual and h264 in Matroska containers. Any MKV that doesn't match this, will be transcoded.Code: Select all
To make it work propertly, you should also consider adding supported audio codecs with something like this:Code: Select all
# Supported audio formats:
Supported = f:mp3 m:audio/mpeg
Supported = f:wav m:audio/L16
SupportedExternalSubtitlesFormats = SUBRIP,ASS,TEXT,MICRODVD,WEBVTT,SAMI
SupportedInternalSubtitlesFormats = SUBRIP,ASS,TEXT,MICRODVD,WEBVTT,SAMI
I can't answer that because I have no idea what your TV does or doesn't support. But, if we imagine that your TV supports h264 and h262 only in MKVs, with only MP3 audio, I would make it:
That would only make sure that all MKVs that's not either h262 or h264 video and MP3 audio are transcoded, you would have to do this for every container/format that you wanted to correct. Combining avi and mkv one the same line makes no sense to me, so I split them up. I can't imagine a situation where they should have the same parameters, especially taking the MIME-type into consideration. All parameters are "regular expressions" (look it up if you don't know what it is), so the "|" means "or". Thus, "f:avi|mkv" means "format/container is AVI or MKV".
Supported = f:mkv v:mpeg2|h264 a:mp3 m:video/x-matroska
