No folder on Sony Bravia KDL43WD750
Hello!
I just got a brand new TV: a Sony Bravia (KDL43WD750). I am still discovering it.
Usually, I use UMS on my PS4 without any issue. However, I can't use UMS directly on the new TV. When I go to the media menu from the home menu, UMS is available. But when I go in there, the expected folders are not there, just "There are no items to display".
Does anyone have a suggestion?
I attach the debug file in case it can help. Here is a link to the TV : https://www.sony.co.uk/electronics/tele ... 750-series
Thanks.
Thanks.
Re: No folder on Sony Bravia KDL43WD750
Try to add this .conf file to the folder with other UMS renderers .conf files.
Sony-BraviaWD.conf
- (2.67 KiB) Downloaded 512 times
Thanks, I tried it, but there is no change. Actually, I found out that every media server I try doesn't work, so it's not related to UMS specifically.
After a few tests, I feel the issue comes from my antivirus, Kaspersky. When I disable its firewall, UMS still doesn't work, but gives me the message "cannot access the server" instead of "no items to display", while the other media servers seem to work (files listed at least). So I get back to a problem a little bit specific to UMS.
