Address Already In Use
mandiggy
Post by mandiggy »
Hi. I had been successfully using UMS for a while, but haven't used it in months. Then when I tried today, it seemed to not find my PS3. I completely uninstalled, then reinstalled, but same problem. I have attached the log, which suggests a serious error, and also can't find the web configuration. I know very little about this stuff. Thank you very much!
(1.75 KiB) Downloaded 329 times
Sami32
Re: Address Already In Use
Post by Sami32 »
Hi, i'm not a Mac user, so i don't know if you have a task bar.
Check any javaw processes in you task bar and kill them before running a new time UMS (run only one instance for testing).
Changing the UMS port (server and web ports depending on your use) could also do the trick. You can found them in your UMS.conf file in your profile folder.
